Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - Mexico, Central & South America
Thread Tools Search this Thread Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
Old 05-29-2010, 09:33 AM   #16
Omarin
Omarin's Avatar
Oddometer: 46
Thumb
Bajafool we are pleased to inform you that we have solved the issue with the map E32 not working with the new versions of Roadtrip and Mapinstall for Mac and the new versions of Mapsource and BaseCamp for PC, you can purchase your map now.
regards
Omar Ortiz
Director
Cartografía GPS
http://www.cartografiagps.com
http://cartografiagps.blogspot.com
Omarin is offline   Reply With Quote
Old 06-11-2010, 09:29 PM   #17
bajafool
Oddometer: 30
Omarin,
Thanks for the update. I apologize for the slow response to you.
bajafool is offline   Reply With Quote
Old 06-15-2010, 06:00 PM   #18
mtndragon
Traveler
mtndragon's Avatar
Oddometer: 295
I used the E32 maps for a short trip down to Northern Baja last weekend. They worked great, the whole transfer into Basecamp for Mac was easy, and the mapset had even the smallest goat trails. Good stuff.
Thanks, Omar.
www.mtndragon.com
mtndragon is offline   Reply With Quote
Old 06-19-2010, 09:18 PM   #19
bajafool
Oddometer: 30
Mtndragon,
The issue that I was discussing with Omarin was that Garmin made some software changes earlier this year to improve security that caused his Mexico map and the Mexico map produced by BiCiMapas to lock (e.g. you could no longer view the maps on your computer or reload them to your Garmin GPS).
The only way to view/upload the maps was delete Map Install v.2.15 and use Garmin MapInstall for Mac v.2.11 or earlier. If using a PC, you had to use a Map Source that was earlier than version 6.15.9 (i.e., v.6.15.7). In addition, the update of Garmin´s United States and Europe map, would lock your maps on your computer.
Base Camp for Macintosh was affected similiarly. If you updated from Base Camp 2.1.1 (Mac) to Base Camp 3.0.1 (Mac) your map would become unviewable.
So, do you have the latest versions of Map Source for PC or Map Install and Basecamp for Macintosh? Are you using the latest version of Cartograficas E32 2010? Is everything working OK?
I want to buy the latest Cartograficas E32 map for Macintosh. I do, however, want to ensure that it will work in every way with the latest versions of Garmin Map Install, Base Camp and Road Trip for Macintosh. Do diligence, do diligence, do diligence.
Old 06-20-2010, 07:12 AM   #20
mtndragon
Traveler
mtndragon's Avatar
Oddometer: 295
Bajafool-
I am running the latest versions of Basecamp, Mapinstaller, and Mapmanager, as well as the latest version of the E32 maps. Everything worked very well, and it was seamless. I did purchase the Windows version of the E32 maps, and then converted it for Mac, as I wanted to have a Mapsource version of the E32 Maps as well. I was/am a little hesitant to completely use the Mac/Basecamp side, as I am very use to Mapsource. Basecamp for Mac still crashes a bit, and won't send data straight to my Zumo, but for the last Baja trip I did, and the current trip into the Sierra Nevada that I am on, Basecamp worked, and I see myself using the Mac side and Basecamp more and more in the future. I actually prefer sending the necessary maps to the GPS with Mapinstaller, and the latest version of the E32 maps played well with everything.
www.mtndragon.com
Old 06-20-2010, 10:02 AM   #21
bajafool
Oddometer: 30
Mtndragon,
Thank you for the feedback. I definitely am more impressed with the quality of the Cartograficas E32 map when compared to the BiCiMapas Mexico GPS Atlas. I guess it is time to get on with ordering a map. By the way, over on the Garmin Mac thread in the "Layin' down tracks" forum, there is a brief discussion of the demise of Road Trip and info on the latest (last week) update to Base Camp for Mac. See this link at pages 106 to 107: http://www.advrider.com/forums/showthread.php?t=331421
Old 08-18-2011, 01:10 PM   #22
WilderRider
WilderRider's Avatar
Oddometer: 1,803
Or has anyone tried this map for just Baja? any thoughts?
http://gpstrailrides.com/
At just $40 for the peninsula, sounds like a good alternative for just doing that part.
RISK: "The loftier your goals, the higher your risk, the greater your glory."
WilderRider is online now   Reply With Quote
Old 08-18-2011, 01:35 PM   #23
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
e32 maps
I have used all and for best high quality 24k topo, nothing beat's Omar's E32 maps. Its is worth more but detail level of all trails, streams,creeks and topo contour lines does not even compare to others. if you want simplicity and will just ride "main fire roads and hiighway in baja" the larry's lbmaps is the way to go.
i you want routing for highway in all of Mexico, bicimapas will be the one you need.
LURKER
pepetrueba is offline   Reply With Quote
Old 08-18-2011, 07:13 PM   #24
Hill Climber
Oddometer: 363
+1 for E32
I can confirm that Omar's maps have a ton of trails that you won't find on any others. I've been up and down the Baja many times and always refer to E32 if I'm looking for off the beaten path trails.... You just have to understand that "Vereda" means "Trail" and "Brecha" means "Dirt". You'll soon figure it out !!
08 ktm530
12 ktm990Adventure
Hill Climber is offline   Reply With Quote
Old 11-24-2011, 05:16 PM   #25
r_jacksondiesel
r_jacksondiesel's Avatar
Oddometer: 41
I just bought the E 32 and it really looks like a high quality map. I am new to the GPS scene, but will really get to know it in a couple more weeks when I go spend a month in Baja. I rode last year and my partner had a Bicimapas on his GPS. This looks a lot better, especially off the highways. The Bicimapas showed some of the backroads, but he had to zoom in so close it wasn't very funcional. I am also loading birdseye sattelite images of the trails I plan to be riding. I really like that feature!
r_jacksondiesel is offline   Reply With Quote
Old 11-24-2011, 06:25 PM   #26
jimmex
Guero con moto
jimmex's Avatar
Oddometer: 2,783
E32 saved my ass in the Sierra of Sonora/Chih. Also worked well in Baja.
jimmex is offline   Reply With Quote
Old 12-01-2011, 11:01 AM   #27
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
been using bicimaps for 1/2 yr now it works well enough. some roads are off but it being routable is key for me...then again that doesn't always work for small towns. i think i'd use both if i was in remote areas (E32 taking over at this point)
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-01-2011, 11:05 AM   #28
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,110
Originally Posted by Misery Goat View Post
what are you using for Central and South America?
I thought Bici was the only game in town.
I have a Zumo 550.
http://www.advrider.com/forums/showthread.php?t=649144
Alaska
Old 01-16-2012, 08:20 AM   #29
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 325
E-32
What is the easiest way to install the E-32 onto a PC then to a Garmin 60cs? Some instruction please for the gps semi-illiterate
I'm not day dreaming, I'm prerunning
21 days exploring Baja
http://advrider.com/forums/showthread.php?t=922187
Moto Vaquero screwed with this post 01-16-2012 at 08:26 AM
Moto Vaquero is offline   Reply With Quote
Old 01-16-2012, 08:39 AM   #30
Hill Climber
Oddometer: 363
How to
Check here: http://www.cartografiagps.com/mape32/faqs.htm
08 ktm530
12 ktm990Adventure
Times are GMT -7.   It's 09:05 AM.
