01-27-2012, 02:37 PM
#2461 | |
Oddometer: 371
01-27-2012, 05:20 PM
#2462 | |
As good as a wink
Wish I could justify the Trailblazer 302 Air Pak - for Swiss-Army factor, a generator/welder/air-compressor/battery-charger? SWEET. But yeah, getting close to that $15k number... Back here on my planet, I'd be more likely to get a MillerMatic 180, a Generac 5kw cart generator, and use the existing Craftsman 5HP compressor and Craftsman battery charger.
Some people see the hand of God in their lives. Others see only His finger. -nod
01-27-2012, 08:21 PM
#2463 | |
Syndicated
Oddometer: 11,286
01-29-2012, 08:30 AM
#2464 |
Cavalera Conspirator
Oddometer: 956
Question...... I am working on a Upside Down Fork Conversion on my DRZ 400 and the frame stop is slightly high and I need to extend it. I was thinking of making a duplicate tab and drilling 2 holes in the OEM frame tab and slug welding it in.
Details I need to confirm are.... 1. What type of steel will be best for this job? 2. The bike is built so how do I protect the electrics from shock? 3. What type of welder should I use and what settings? I have atatched pictures of the job I need to complete. My buddy is a welder and has a welding truck with several welding machines so I have options and a welder that can do the job. I just need to confirm with knowledgeable motorcycle guys first so he doesnt fry my bike electrics, since he is mainly a structural welder. Thank You In Advance for assistance and time spent to reply. ![]()
01-29-2012, 02:46 PM
#2465 |
Syndicated
Oddometer: 11,286
Any old steel will be fine. A scrap steel piece from your buddy's structural welding truck will work. He'll more than likely know the weld settings. There's many ways to attach the extra piece, I would maybe drill some big plug welding holes into the added piece instead of the original tab, if I could remove the triple clamp and stand the frame up vertical. Or cut a rectangular piece, a little smaller length/width, weld to the bottom of the original tab on 3 sides, and grind to suit. Disconnect the battery and unplug the electronic ignition module. Put the work clamp near to the weld, sand off some paint to make a good contact. Maybe repack the bearing? |
01-29-2012, 03:03 PM
#2466 | |
Oddometer: 956
I just talked to him and he said that he can safely TIG weld it with ONLY the battery disconnected. However, I will unplug everything and remove the Ignition Module as well. Should I remove anything else as a precaution? Charging stator,coil, switches, starter solenoids etc...? He says welding a completed bike is no different than welding on a piece of heavy equipment that has a Computer controlled engine of which he said he does all the time. He said that the key is grounding the job correctly at the weld site and using an additional earth ground as well to relieve static "eddy current" I am sending him pics of the job at hand now so he can advise which steel I need to get from him.
01-29-2012, 03:11 PM
#2467 | |
Oddometer: 2,563
Clamp on the frame as close as possible to the steering head.I'd cut a piece the same size as the one on the frame, champher all edges (3 on the new piece and 3 on the frame) and your buddy can run a horizontal bead around the bottom of the frame piece and on top of the added piece. The bead will lay down in the groove leaving more weld surface area than plug welds. Edit: I'm too slow. My DR650 frame is mild steel, any scrap metal he has will work.
01-29-2012, 03:28 PM
#2468 | |
Oddometer: 956
He said he will use the clamps that we are going to use to hold the new tab to the OEM frame tab for the ground, along with a grounding strap to aid in dispersing of static (eddy current) charges I may take this opportunity to remove the steering lock assembly since the new stem doesnt have provisions for the steering lock anyway.
01-29-2012, 04:24 PM
#2469 | |
Syndicated
Oddometer: 11,286
The switches, regulator/rectifier, stator can all stay in place. Unless you want to remove them. In which case that would be the best thing to do. |
01-29-2012, 04:58 PM
#2470 | |
Oddometer: 2,563
01-29-2012, 05:15 PM
#2471 |
Oddometer: 956
I dont mind removing most of the electrical components but will admit I did not wanna remove the stator, starter, and wiring harness. I also admit that I also had visions and thoughts of wiring gremlins later on if I didnt remove the wiring harness even if I disconnected the various components from the wiring harness. I am sure that I sound foolish but I do not have any more time or money to make any mistakes now... So gaining much needed knowledge is extremely valuable at this point.
01-29-2012, 05:32 PM
#2472 |
Oddometer: 2,563
You don't sound foolish, you're just doing your homework. With your weldor clamping right at the weld, you're set; he has it covered.
weldor = person welder = machine Don't drop the welder on the weldor. |
01-29-2012, 05:41 PM
#2473 |
Oddometer: 956
I appreciate all of the help very much...
01-29-2012, 06:00 PM
#2474 | |
Syndicated
Oddometer: 11,286
Post up a pic when it's done. |
01-29-2012, 06:32 PM
#2475 | |
aka Road Monster
1. It's gonna get kinda messy. 2. It'll usually fuck'em both up so that neither one will work.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
