Old 01-30-2012, 02:45 PM   #2446
WIsixfitty
ceiling unlimited
Oddometer: 2,328
hf start causes havoc with my mp3 player if the whip is close to or touching any part of the player or cord.
sideways and smiling
WIsixfitty is online now   Reply With Quote
Old 01-30-2012, 03:04 PM   #2447
ER70S-2
ER70S-2's Avatar
Oddometer: 6,949
My buddy was welding his alum prop, HF continuous AC. I went to the basement and heard the sprinkler system water hammering. The HF was repeatedly kicking the solenoids, 40 feet away.
I unplug the sprinkler clock now.
fwiw: transformer Miller Syncrowave 250
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 01-30-2012, 03:13 PM   #2448
bobbed06
Cavalera Conspirator
Oddometer: 1,236
What is HF?
bobbed06 is offline   Reply With Quote
Old 01-30-2012, 03:28 PM   #2449
ER70S-2
ER70S-2's Avatar
Oddometer: 6,949
High frequency. Since welding isn't lightning, the arc won't start without scratching the surface. This is ok on stick welding and MIG; but if you scratch your tungsten to start the arc with TIG, you might contaminate either the weld or the tungsten you're welding with. This isn't acceptable, TIG is super clean and we want to keep it that way.
This is where HF comes in. Instead of scratching the surface, we just hit the pedal (throttle control) with the torch tip close to the weld (1/8" or so). Now the arc will jump that space riding the HF current and ZAP we have an arc without touching the surface.
2013 WR250R
Old 01-30-2012, 03:37 PM   #2450
bobbed06
Oddometer: 1,236
OK, and even though this HF signal will switch the sprinkler system on 40 feet away or wack out an MP3 player its still safe for my for my motosickle electrics with the battery and CDI removed?
Old 01-31-2012, 06:59 AM   #2451
GSWayne
Old Guy nOOb
GSWayne's Avatar
Oddometer: 3,097
Yes (if you don't put the ground clamp somewhere stupid)
The welding didn't damage the electronics that was affected.
Your bike electronics are almost surely better hardened than the sprinkler controllers or MP3 players because a normally working bike is not a good RF environment. There are spark plugs firing many times a second which are a significant EMI source and vehicle electronics in general are engineered better than sprinkler controllers.
It isn't the conditions its the decisions
Don't bring a motorcycle to a car fight
GSWayne is offline   Reply With Quote
Old 01-31-2012, 10:44 PM   #2452
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Sounds like your guy knows where to put the work clamp to provide a low impedance circuit path.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 01-31-2012, 10:48 PM   #2453
bobbed06
Oddometer: 1,236
Yes, He did say he would attatch the ground right at the clamp holding the additional tab. .
Old 02-01-2012, 06:21 PM   #2454
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,114
What is HF?
High Frequency in TIG welding is high voltage 30,000 volts that is produced at the start of a TIG weld in DC and is used the entire time you weld in AC. It is used in AC because the arc turns off 60 times per second as the current reverses from positive to negative and back. The high frequency helps keep the arc on and helps establish it. It is possible to TIG weld DC- without high frequency by scratch starting the tungsten to the work piece.
Yes it will mess with electronics but as stated if you disconnect the battery and set your ground close to were your welding you should be fine.
High frequency is just like static electricity with high voltage and low amperage. It will shock you but wont kill you. Just keep your body out of the welding loop.
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar is offline   Reply With Quote
Old 02-03-2012, 10:32 AM   #2455
badweatherbiker
badweatherbiker's Avatar
Oddometer: 706
I have no clue how to weld, i bought an arc welder 10 years ago i think it is a 70 0r 80 amp elder and i have never even turned it on. In fact its still in the box wrapped in plastic.
Having said that Im looking at my FZ6 and thinking i would really like to have some sideracks so i could mount some hardbags. I miss them since i sold my Ulysses and i only have a tail bag to pack my junk in everyday.
Where the hell do i start? I know nothing about welding.
1996 Kawasaki KZ1000P (currently being rebuilt)
World class nutritional supplements, weight loss, meal replacement shakes, quality energy drinks, pre and post workout supplements!
Earn extra income, become a distributor or just purchase:
Advocare products-www.advocare.com/12084065
badweatherbiker is offline   Reply With Quote
Old 02-03-2012, 01:46 PM   #2456
Colorado970
Colorado970's Avatar
Oddometer: 1,087
To start: What kind of machine is it? A stick welder or MIG welder?
Whatever the brand, if you unwrap it there may be some sample welding supplies in there to start on, but probably best to unwrap it first.
"It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity."
Colorado970 is offline   Reply With Quote
Old 02-03-2012, 02:26 PM   #2457
badweatherbiker
Oddometer: 706
I think its a simple stick welder, it has some rods with it and some handheld eye covers. Im gonna break it out this weekend and take a look because its been a while. Hope it doesnt throw all the breakers!
Old 02-04-2012, 04:45 PM   #2458
KTM640Dakar OP
Motorsick
Oddometer: 2,114
Have fun and let us know how it goes.
The Lincoln Electric Welding School
http://www.lincolnelectric.com/en-us...ng-school.aspx
Old 02-04-2012, 05:28 PM   #2459
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,081
If you are close to Ocala, try and contact Phillip Kunts on here. I can't speak for him, but he has skills and may be willing to share some of the basics. Pretty good guy, and good dirt rider as well as being a weldor/fabricator.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 02-05-2012, 10:04 AM   #2460
mike-s
2 squeaky wheels
Oddometer: 609
I was like that, then i just thought to hell with it and read up on the basic idea, watched a few videos on youtube to get a bitof a "practical" observation going without having an instructor and off i went.
I'm still shithouse at doing stick, and need to work higher amps to really get it working, but have fallen in love with using my gasless MIG, that thing is surprisingly awesome to use, I love the feeling of accomplishment i get after i do a good job putting components together. Aside from buying the welder in the first place, that auto-darkening helmet purchase was the best thing i've done in my garage.
Oh and throw away the handheld faceshield, that's no good anywhere but in a chinese sweat shop. Get either a full mask with a flipdown visor, or (preferably) get a solar powered auto-helmet. That way you can tune the darkness levels to the task at hand and you aren't stuck with a single filtering strength that may be too dark or not dark enough for what you are trying to do. And you can line up the weld and then just go go go instead of lining up, holding still, flipping the visor with one hand and hoping it's still in the same spot you left it.
mike-s is offline   Reply With Quote
Times are GMT -7.   It's 01:28 PM.
