Old 02-04-2012, 09:12 PM   #16
crazybrit
crazybrit's Avatar
Oddometer: 8,039
Originally Posted by EdGear View Post
I thought my email was public, sorry. Please send HTR Oil Cooler info to edgear@mac.com.
Thanks,
Ed
sent
crazybrit is offline   Reply With Quote
Old 02-05-2012, 12:15 AM   #17
EdGear
Edventurer
EdGear's Avatar
Oddometer: 493
Thanks Crazybrit, I discovered something in the instructions that may have saved my bike.
The oil cooler I bought had the lines attached and it appears as though the banjo bolts on the cooler were reversed.
Is the KTM Flow control "100" banjo the same as the "Check Ball" banjo bolt.
To confirm:
Oil Cooler top - KTM Flow control "100" banjo - long line - std banjo - top rocker box
Lower oil cooler - std banjo - short line - Ball check banjo - right side engine
Ed
Get out and ride
2007 KTM 990 Adventure
2006 KTM 640 Adventure
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 02-05-2012, 08:12 AM   #18
crazybrit
crazybrit's Avatar
Oddometer: 8,039
No. If you read the instructions this is impossible. Section a of the instructions says to use the "KTM flow control banjo bolt marked #100" for the long line. Section b of the instructions says to use the "supplied check ball banjo bolt" for the short line.
The HT supplied "check ball banjo" is clearly distinguished, it has a hole drilled in the top and later filled with epoxy.
This is what the instructions say, right??
If you have problems call Bill Senior (tech line) before starting the bike. He designed the product and is very helpful. As already said, calling Bill Junior (customer service) is not what you want to do.
Old 02-05-2012, 09:23 AM   #19
EdGear
Edventurer
EdGear's Avatar
Oddometer: 493
Didn't get the check ball banjo.
I'll just buy a new set of banjo bolts from HTR. I've asked nicely.
Thanks for your help Crazybrit.
Ed
Get out and ride
Old 02-05-2012, 02:06 PM   #20
crazybrit
crazybrit's Avatar
Oddometer: 8,039
Ed
Couple extra tips. Use new copper washers. Or anneal the old ones. The KTM ones are like $4 a pop.
Also the spec for the banjo's is 10nm which is too much torque IMO. Above 7nm it felt to me like they were going to strip but part of this is that the banjo's will oval after repeated tightening and loosening and when they oval they won't take the correct torque and will slip or snap.
I think Bill Sr advises two finger tight with a hand wrench.
Old 02-05-2012, 05:10 PM   #21
EdGear
Edventurer
EdGear's Avatar
Oddometer: 493
Annealed the old crush washers, will do on the two finger tight.
Get out and ride
Old 02-07-2012, 03:52 PM   #22
EdGear
Edventurer
EdGear's Avatar
Oddometer: 493
HT-Racing Service is good
If you've read through this thread I wish I could change the title of the original post.
While I was initially caught up in the service question, from my first impression, I have been able to find good support for HT Racing product from;
inmates here, thanks Crazybrit,
from HTR dealers, thanks Chris Blais at Blais Racing Services and
from Bill Sr. and Bill Jr. at HT Racing, thanks Bill Sr. and Bill Jr.
I got responses from my HTR web queries and voice mails within a day.
I was able to get installation instructions, got help figuring out what I needed and was able order the parts.
Now I'll be able to get out and enjoy the HTR parts that make my RFS a better bike; HTR Power Header, Velocity stack, Powervane and now Oil Cooler.
For disclosure I am not affiliated with HTR but appreciate their work.
Ed
Get out and ride
Old 03-16-2012, 04:33 PM   #23
RuckedUp
RuckedUp's Avatar
Oddometer: 859
Send a message via Skype™ to RuckedUp
Im like really
I asked for a copy of the install instructions on computer format and was told to send them a SASE! Really!!!! I'm done doing business with the 1970's Does anyone have the install instructions in .PDF format?
My SPOT tracker link: SPOT
AKA extsieg
09' Dyna Low Rider
10' KTM 450EXC
RuckedUp screwed with this post 03-17-2012 at 04:41 AM
RuckedUp is offline   Reply With Quote
Old 03-16-2012, 06:36 PM   #24
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 7,581
Just ask a mod to do it.
twinrider is offline   Reply With Quote
Times are GMT -7.   It's 12:04 AM.
