Old 12-08-2011, 09:03 AM   #61
zundappuk
zundappuk's Avatar
Location: A Brit behind the Siegfried Line in the Eifel
Oddometer: 88
Just to clean up a few Errors..
[QUOTE=gspell68;17429189]
2) Plus, ever notice that the KS-750's frame is one big piece of stamped steel and the R-75's frame is a bunch of bolt-joined sections?!?!? Welding technology was in it's infancy and the tubular steel frame was still not up to off-road rigors
Actually, the KS750 frame is mainly oval section tubes. The Headstock is made from two stampings welded () to give strength.
The R-71 was already obsolete during it's production and was the last flathead BMW ever designed!!! Olny about 3,500 were ever made.
The initial R75 prototypes were flat head. Its only because of the superior KS750 OHV design that BMW changed the configuration.
3) The KS-750 and R-75 weren't designed concurrently. Zundapp (who probably copied theirs from the Gnome & Rhone AX2 design or that other Belgian factory I can't remember right now) rolled out their rig well before BMW even had an R-75 assembly line.
The AX2 is a French design, the Belgian bike you are thinking of is the FN m1000. True, both BMW and Zundapp studied captured machines. But early drawings of what was the then known as the KS700 (with and engine based on the KS600) were already in progress by 1940.
The Germans wanted BMW to start producing the Zundapp design, but BMW insisted they could make their own version in a timely manner. The R-75 was the first motorcycle with hydraulic brakes.
Both R75 and KS750 deployed a cable operated front brake and chair and rear wheel hydraulic brakes by ATE
5) No post-war KS-750's or R-75's were made probably because the factories were destroyed and there were Allied enforced displacement restrictions on motorcycles. I read that there were about 100 civilian model R-75's made in 1948 from leftover parts, though.
Zundapp delivered approx 475 KS750 between 1945 and 1947.
David
zundappuk is offline   Reply With Quote
Old 12-08-2011, 09:23 AM   #62
windmill
windmill's Avatar
Oddometer: 4,084
Originally Posted by zundappuk View Post
Thats a shame,=.
Looks like an early-mid Russian M72. A lot better than the Chinese version, and starting to get a following. Could be worth a go provided the price is right.....
Best
David
The fenders look like the first type used, and the rigid sidecar frame is also from very early on.
Not "valuable", but I wouldn't discount it so quickly, not many early or war era M72's here.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 12-08-2011, 10:14 AM   #63
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 489
Talking
I could use the frame, should be easier to bolt up to my Zundapp than my Danish ACAP that was intended for a Nimbus flat stock frame.
Should anyone happen to do a recovery let me know..... have trailer will drive.
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 12-16-2011, 09:04 PM   #64
fyr OP
iRoast Coffee
fyr's Avatar
Oddometer: 1,282
OK
The build up was exciting... but it wasnt a Zunny or R75
Im missing something. I need a Xmas lift.. Anyone got a present to self lined for this Christmas.... NOS 1939-45 outfit?
Or Parts for..
Me: Im going to pannier up my Ural...
Then save my dosh for the mother lode.
"Best thing though, is I can just sit and stare at it with a big fat cigar in my yap and have that shit eatin grin.."
10 Ypan Patrol-07 Bonnie T100-84 R65
fyr is offline   Reply With Quote
Old 12-16-2011, 10:57 PM   #65
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,701
Originally Posted by GreatWhiteNorth View Post
We've all seen German and Russian WWII military sidecar rigs, but were there Harley Davidson sidecar rigs built and actually used operationally? I've only seen HD motorcycles alone; i.e. without sidecars.
If you are prepared to consider WWI . . . . .
From H-D's own website:
During WWII, Harley also produced the lesser-known XA model, designed for desert use. The government cancelled the contract after the war had moved out of North Africa, and the XA never saw action. Only about 1,110 were built and shipped.
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 12-17-2011, 12:16 AM   #66
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,114
Harley XA
One serious looking rig. Must be rare as hens teeth. Thnx for that.
GreatWhiteNorth is online now   Reply With Quote
Old 12-21-2011, 08:48 PM   #67
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
this is what they look like assembled
Originally Posted by bmwhacker View Post
Очень плохой двор орнаментом.
Этот мотоцикл не стоит порошка чтобы взорвать его в ад.
(Very bad yard ornament.
This bike is not worth the powder to blow it to hell.)
Я не уверен, что это такое .... может быть, IMZ или Dpner?
(I'm not sure what it is .... may be, IMZ or Dpner?)
Кадр коляской, возможно, какое-то значение для кого-то?
(Sidecar frame, perhaps some value to someone?)
Кто-то в прошлом написал "BMW" на поршень с волшебным маркером ... вот как нынешний владелец решил, что это был BMW.
(Someone wrote in the past "BMW" on the piston with a magic marker ... Here, as the current owner has decided that it was BMW._
Итак, я предложил вернуться и haulit далеко за стоимость моего газа прийти и получить его. Даже, что это растяжение ее ценность.
(So, I offered to come back and haul it away the cost of my gas to come and get it. Even that is stretching its "value.)
Так много для моего мечтает о ценных "сарай найти" ... все я нашел, было навоза на сарае пол ...
(So much for my dreams of a valuable "barn find" ... All I found was the manure on the barn floor ...)
I just picked this up after driving by it for months. The seller brought it back from Lithuania. 50's vintage M-72, either IMZ or KMZ. Same sidecar fender and leaf springs. Yours looks like a pretty original military rig by the look of the front fender and the frame loops over the sidecar fender. I think you passed up something with a little value. The M-72s were directly copied from the the R71s for the military, and the quality was much higher than subsequent Urals and Dneprs sold to civilians. As another inmate said, there's quite a following developing for these M72s. You can still get most of the parts you need to restore them, pretty reasonably. I could use that tranny in the pics! That sidecar frame and fender is worth something. So, where is it?
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 12-22-2011, 07:32 AM   #68
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,345
The bike is in So. Ca.
The owner isn't actively trying to sell it. I haven't been able to get him to name a price, other than someone supposedly offered him $2000.00 for it a couple years ago. That amount seems a little high to me. I would drag it home for $500.00 tops but I doubt he'd take that offer.
In a usable condition, what are these things worth?
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 12-22-2011, 06:26 PM   #69
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
the prices sem to be all over the place
......depending on level of completeness and originality. The have a big following in Europe but there's not many M72s over here. I paid under 2K and I'm told that was a pretty good deal. They're obviously not worth the same as a BMW, but a well sorted rig might fetch 7K. If you could get it for $500 you could easly recoup that in parts. Lots of hassle with shipping, etc. If you do buy it please PM me.....
Old 02-07-2012, 02:44 PM   #70
zundappuk
zundappuk's Avatar
Oddometer: 88
At long last the KS is back!
In my garage yesterday after being in storage for 4 years
Old 02-07-2012, 03:50 PM   #71
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: California bound but stuck in NY for a few months
Oddometer: 3,511
We need to know much more! With pictures please.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 02-07-2012, 05:31 PM   #72
fyr OP
iRoast Coffee
fyr's Avatar
Oddometer: 1,282
Aaack, Great Scott!
Such a tease....... we need..........MORE INFO!!!
Old 02-07-2012, 09:21 PM   #73
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,345
Damn!!!!!!!
ABC# 1992
Old 02-08-2012, 09:13 PM   #74
retroone
retroone's Avatar
Oddometer: 1,372
Is that a tank bike on the right
D-Wrec
retroone is offline   Reply With Quote
Old 02-09-2012, 04:12 AM   #75
zundappuk
zundappuk's Avatar
Oddometer: 88
If by that you mean a Kettenkrad, then yes
David
Times are GMT -7.   It's 09:27 PM.
