Old 02-11-2012, 06:11 PM   #406
JimmyTheHog OP
Low Speed Adventurer
JimmyTheHog's Avatar
Oddometer: 741
Skid Plate
I installed the new skid plate today too ~ after some minor rework. I had the rear mounting holes off by almost an inch - Oops - Oh well, it was an easy rework.
Installation takes one bolt / nut in the front, and two bolts underneath with mounting bracket to the frame.
The install... Front bolt first makes it easy to get your hand behind the frame mount to install the nut on the bolt.
Jim
09 R12GSA, 2013 SC3 Adventure
http://advrider.com/forums/showthread.php?t=657449
http://www.carduccidualsport.com
JimmyTheHog is offline   Reply With Quote
Old 02-11-2012, 07:32 PM   #407
Danger4u2
'04KX500isDanger4u2
Danger4u2's Avatar
Oddometer: 693
Are you considering it done? Or are there other items your still working on. More tweaks? May I ask why you used an 883 and didn't start with the 1200 sporty? You've done well, I like it.
Go faster than everyone.
Only worry about what's in front of you.
Danger4u2 is offline   Reply With Quote
Old 02-11-2012, 09:28 PM   #408
JimmyTheHog OP
Oddometer: 741
No, its close but not quite done. Here's the list of remaining tweaks / components:
- Headlight mounting brackets - gets rid of the hose clamps-to-fork tubes mounting. On order
- Kickstand - The one i made is from another bike and lengthened. Im making a new one from scratch now that i designed
- Tweak the design of the front blinker brackets - so same blinkers front & rear can be used. Currently both different
- Anodize the rear rack, tool kit plate, and skid plate - clear anodize
- Paint the tank black w/ silver sides and top, and black scorpion logo & red letters "scorpion"
- And lastly, a 5.5 gal gas tank - Im on the wait list to have this made, but wont be done until later this year.
Then I will claim it "done". Im exhausted just thinking about it
I went with the 883 because I found a good deal on a clean one. If I would have found a nice 1200 when i was looking, I would have bought it instead.
Jim
Old 02-11-2012, 09:44 PM   #409
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,031
Looking great, Jim!!!
Add a Li Ion battery to that list and drop another 10 pounds of the bike.
Old 02-11-2012, 10:27 PM   #410
JimmyTheHog OP
Oddometer: 741
You just reminded me - I forgot to add that i just installed one today. It cranks great (much needed with the 1250 and cams) and its noticably lighter having removed those 10 lbs from up high. That, plus adding the skid plate weight down low, was a noticable change.
There seems to be some reliability debate on these though - cold weather issues ? Maybe it was for the earlier models ? Not sure, but for a 10 lb savings, Im willing to give it a try and see how it does.
You can see it in this picture a bit better...
Jim
Old 02-12-2012, 06:30 AM   #411
merc16
Oddometer: 320
Laugh
I can't wait to hear details about the kit for this.
merc16 is online now   Reply With Quote
Old 02-12-2012, 07:45 AM   #412
Straightedge
Skin Donor
Straightedge's Avatar
Oddometer: 36
Cuh-lean. Wish my bikes looked this good...
Straightedge is offline   Reply With Quote
Old 02-12-2012, 08:11 AM   #413
JN3n
JN3n's Avatar
Oddometer: 181
Is RaceTech building your new tank ?
I like your bike . The cool factor is way up there...
JN3n
JN3n is offline   Reply With Quote
Old 02-12-2012, 08:52 AM   #414
JimmyTheHog OP
Oddometer: 741
No, its Evan Wilcox Hand Formed Metal. He does one-off's and limited production stuff. He's at www.wilcoxmetal.com.
Does RaceTech make tanks ???
Jim
Old 02-12-2012, 08:59 AM   #415
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,031
Cool!!
I went with a Ballistic battery after hearing about all the problems with the Shorai. The battery on my BMW project was 14 pounds and I put a 2.5 pound battery back in.
Old 02-13-2012, 07:36 AM   #416
JN3n
JN3n's Avatar
Oddometer: 181
I met the guy who made your tank at the San Jose swap meet . Nice Guy
RaceTec is in Oxnard and he has been making gas tanks, race car goodies etc. for along time . He makes beautiful and functional tanks flat track bikes I have built. Fred @ RaceTec 805- 486-6500
JN3n
Old 02-13-2012, 07:32 PM   #417
JimmyTheHog OP
Oddometer: 741
Thanks much for the lead ! I had asked Storz who the tank fabricator was, and they "respectfully" declined to answer. I'll give him a call. Since he already has the form or whatever he uses to shape the tracker tank, it may be an easy mod to add some more volume. Im sure Evan will do a nice job though too.
Thanks again!
Jim
Old 02-14-2012, 07:59 AM   #418
JimmyTheHog OP
Oddometer: 741
New shift lever hot of the mill. The previous one was a combination of two levers - a new machined lever + an existing spline piece pressed and pinned together. I did this since we didnt have a serration broach tool at the time.
Jim
Old 02-27-2012, 08:34 PM   #419
RustyStuff
RustyStuff's Avatar
Oddometer: 846
How tall is the bike?
1980 Suzuki GS450 Confused bitsabike.
1990 Kawa KDX200 Desert sled.
RustyStuff is offline   Reply With Quote
Old 02-29-2012, 08:06 AM   #420
JimmyTheHog OP
Oddometer: 741
It has a ~35.5" seat height, and is ~33" with me on the bike. I cant flat foot it, but both feet can touch the ground without too much stretch.
Jim
Times are GMT -7.   It's 07:08 AM.
