Old 02-12-2012, 01:17 PM   #1
mikem9 OP
Wanderer
Oddometer: 1,233
Custom Scramblers
Would you mind posting your pics of your custom scramblers or pics of others you find interesting? Possibly interested in taking some kind of old twin and making into a scrambler, or taking old scrambler bike and customizing.
Questions: - Pros and Cons of low pipe vs. high scrambler pipe? Saw a custom bike the other day (google Hammerhead Jack Pine). Was a Triumph modern classic Bonneville made into a Scrambler. Started with a high scrambler pipe but went back to customized low pipe - said it was better to keep the center of gravity lower and kept the bike thinner. But, how do the low pipes do in water crossings?
mikem9 screwed with this post 02-12-2012 at 01:32 PM
mikem9 is offline   Reply With Quote
Old 02-12-2012, 08:40 PM   #2
Cowboy
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,309
Hmmm . . . I'm in the middle of a similar project, basically converting an antique Honda CL450 scrambler into a custom, sort of a cafe/bratstyle cross. I'll be interested to see what others find and post here as well.
Here's a bratstyle scrambler custom I found:
Cowboy is offline   Reply With Quote
Old 02-12-2012, 08:44 PM   #3
Cowboy
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,309
Here's another I found on Pipeburn. (be sure to follow this link if you like it for more pics. BTW, Pipeburn is a great place to see all kinds of customized bikes you might drool over.
Old 02-12-2012, 08:48 PM   #4
Cowboy
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,309
Just ran across this one. (more pics here)
Old 02-12-2012, 09:00 PM   #5
Cowboy
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,309
I remember watching Joey Cocks build this one over at SOHC4.net back in '06.
It's a large part of my inspiration for my own current project, which has a nearly identical CB450 tank on a CL450 frame. (Joey started with a Cb450 frame and added CL pipes, then set about customizing them.) I suppose I should post a photo of my own bike, but I'm not about to wander out into the snow to get to the garage on this snowy evening!
If you want to see Joey's build thread for this lovely little cafe style scrambler, it can be found here.
Old 02-12-2012, 09:10 PM   #6
Cowboy
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,309
I doubt that low pipes would have much trouble in water crossings. I've seen hundreds of trucks back into the water to unload boats, and blow bubbles with their exhaust pipes while the boat was unhooked. Doesn't seem to cause a problem.
I can tell you that the scrambler pipes on my CL450 certainly do make the bike feel a bit wide when you stand on the pegs. You don't notice it when you're sitting. The trouble with the hammarhead Jack Pine bike is that it had high pipes on both sides, which would be even worse than the standard scrambler, where both pipes run down one side. It also had the pipes uninsulated, and unshielded. Those pipes running past your legs would get damned hot without heat shields!
I doubt that you would notice a scrambler being top-heavy, though low pipes would, by definition, keep the weight down lower. For my purposes, I like high pipes because they are not as likely to start a fire in tall dry grass. (I live in a desert where fires start easily.)
Old 02-12-2012, 11:33 PM   #7
redprimo
Oddometer: 458
I thnk the most eligant looking highpipes ever put on a scrabler were done by Norton on the P11. I love the single pipe on each side and they way they hug the side cases and then tuck in to the frame a bit as they pass by your leg. they cut a very lyrical line and sound sweet. Sorry I don't have any pics so you'll have to do a google search to see some if your not familiar with a P11.
redprimo is offline   Reply With Quote
Old 02-13-2012, 04:14 AM   #8
eldomike
Who Cares
eldomike's Avatar
Oddometer: 930
Photobucket http://tinyurl.com/oebr5yk
eldomike is online now   Reply With Quote
Old 02-13-2012, 07:29 AM   #9
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,347
god I love high pipers.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is offline   Reply With Quote
Old 02-13-2012, 08:27 AM   #10
mikem9 OP
Wanderer
Oddometer: 1,233
Thanks - I see what you mean. Good looking bikes:
Old 02-13-2012, 08:37 AM   #11
Speed King
Speed King's Avatar
Oddometer: 1,635
Not mine, but I love it.
Speed King is offline   Reply With Quote
Old 02-13-2012, 08:57 AM   #12
mikem9 OP
Wanderer
Oddometer: 1,233
Beautiful old Triumph!
Speaking of high pipes vs. low, I rode a nearly stock modern classic Triumph Scrambler. When I stood on the pegs, it did feel "fat" on the side of the pipes. I envision possibly using a scrambler concept as an Adventure bike, or big beast dual sport. I just remembered this guy from a ride I went on a while back. Flux's Big Adventure IV. I think it was an XS650.
Here is a vid of that bikes doing a water crossing with the low pipes. 4th bike to cross in the video:
[IMG][/IMG]
Old 02-13-2012, 10:20 AM   #13
DiabloADV
Semi-Occasional
Oddometer: 2,304
For it to be a "scrambler" doesn't it need more than just high pipes? A bike with low clipons and cafe seat, but high pipes, is a cafe racer. Not a scrambler.
A scrambler (IMO) has to at least *hint* of offroad capabilities. Upright riding position, a little extra fender clearance and high pipes...it's a collection of styling elements that makes a bike a scrambler. A scrambler isn't so much a class of bike as a composition of design choices.
Anyhoo...my modded CL175 project is finally off to the powder coater and bead blaster. Hope to have it assembled in a few weeks and will post some pics.
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is online now   Reply With Quote
Old 02-13-2012, 11:27 AM   #14
mikem9 OP
Wanderer
Oddometer: 1,233
Agree. I think some of the pics above are just to illustrate various design elements found on scramblers. From wiki-pedia's definition:
"A scrambler motorcycle, or just scrambler, is a type of all-terrain motorcycle. Streetbikes were modified to overcome cross country terrain. Also known as dirt bike
Characteristics
The main characteristics of a scrambler were high mounted exhaust pipes (for crossing streams or muddy roads), wider handlebars with a crossbar (for added strength) and all-terrain tires. Everything that wasn't strictly necessary was stripped down to lower the weight of the motorcycle."
I think generally speaking, they were the offroad bikes, dual sport etc. designed before the two stroke revolution in the 70's. Often twin cylinder motorcycles. If you recall, early offroad and MX races were called "Scrambles".
My thinking is that maybe with adding improved suspension, some of them may be decent adventure bikes. 650 or 750 twin, stripped down, but still street legal. Thoughts?
Old 02-13-2012, 12:00 PM   #15
pbarmy
pbarmy's Avatar
Oddometer: 1,818
pbarmy is offline   Reply With Quote
Times are GMT -7.   It's 09:21 AM.
