Old 02-15-2012, 07:01 AM   #121
justplainray OP
ucancallmeray
Oddometer: 260
thank you
Originally Posted by Pipo Zaro View Post
Great Job...!!!!
Amazing.
the bike has been fantastic on dirt and gravel surfaces, handling is outstanding.
paved roads are just as fun, cornering is precise even with the knob-like tire tread.
sustained highway speeds to 65 mph are tolerable and necessary to get to where the fun is.
rear tire lasted 3800 miles (mostly paved), front tire still has useful tread.
still hoping to make a trip to Prudue Bay, AK as soon as I can get away from the rest of my life for a month or so.
justplainray
justplainray is online now   Reply With Quote
Old 09-23-2013, 06:15 PM   #122
old2wheeler
Former nb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 720
Originally Posted by justplainray View Post
I used POR-15 Black Velvet
http://www.por15.com/BLACK-VELVET/productinfo/BVG/
inside and out, baked on.
Hope it is half as good as they say it is.
The tear-down pictures date from Sept to Dec 09.
I'm actually in the reassembly stage right now.
More to come
justplainray
It is good to 450 degrees F. Average MC exhaust tempo is 600+ degrees F.
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 09-24-2013, 05:34 AM   #123
justplainray OP
ucancallmeray
Oddometer: 260
[QUOTE=old2wheeler;22398763]It is good to 450 degrees F. Average MC exhaust tempo is 600+ degrees F.
Actually, the manufacturer claims temps to 1200 F
http://www.por15.com/BLACK-VELVET_p_50.html
but it did not hold up as well as expected.
I'll be recoating the pipes this year with something else.
justplainray
Old 11-28-2013, 06:51 AM   #124
layzrider
Layzrider
layzrider's Avatar
Oddometer: 202
ready to ride with some new tires
layzrider is offline   Reply With Quote
Old 11-28-2013, 11:04 PM   #125
Baroquenride
Oddometer: 959
Dude, I SO want to see this bike in person! I love it! Let's ride sometime.
2000 Honda VFR800, 2008 Husqvarna TE-610
Baroquenride is offline   Reply With Quote
Old 11-29-2013, 06:22 AM   #126
layzrider
Layzrider
layzrider's Avatar
Oddometer: 202
I am around
Just getting over being sick. Need to get into shape to ride. Hope to ride soon. I like to ride either GP east of Sunset or Tillamook Forest. Let me know.
Old 10-26-2014, 03:17 PM   #127
gummycarbs
Oddometer: 70
Here's the same view of the actual installation.
Can you explain how the bike rests on the center stand? I mean, what stops the centerstand from folding forward? Are the side frame tubes resting on the center stand's cross tube?
I've been working on a similar design, but my it would put the bike's weight on lower frame tubes, and it looks like they're welded in that area. Makes me a bit nervous.
gummycarbs is offline   Reply With Quote
Old 10-27-2014, 06:50 AM   #128
justplainray OP
ucancallmeray
Oddometer: 260
That is correct, cross tube rest against lower frame tubes.
No problems to this day.
BTY am the in process of re-painting the frame as the silver paint failed big time.
Also converting to fuel injection using MicroSquirt controller, ignition controll included.
No more faulty Honda modules.
Will post progress photos soon.
WOW that bike was really clean.
justplainray
Old 10-27-2014, 03:45 PM   #129
gummycarbs
Oddometer: 70
Good to know it hasn't caused any problems, thanks.
If I recall correctly, it was POR15, brushed on. For what it's worth, I sprayed my frame recently with Kustom Shop white epoxy primer, then Rustoleum satin black with Valspar hardener (isocyanates, nasty stuff, but supposed to make it UV and solvent resistant). I've found that the Rustoleum chips really easily, and I wish I'd just shot a cheap single-stage 2k paint instead. The epoxy primer, on the other hand, seems extremely rugged and hasn't come off in any of the chip locations.
This is the first I've heard of the MicroSquirt, sounds very interesting!
Times are GMT -7.   It's 05:56 PM.
