Old 02-22-2012, 12:18 AM   #5521
Schrauberklaus
***ifyer
Schrauberklaus's Avatar
Oddometer: 229
Originally Posted by HeadTrauma View Post
There are ways to scab together adapters, but it's all likely to perform worse than either OEM setup.
If the Adapter is well made then its most of the Time the new Engine or the Carbs are not correct ajust that make the power worse .
Air flow over two seperate Intake Ports is different to the Airflow over 1 Split type Port .
Carbs need to ajust for that .
Klaus
___________________________
Honda XL 600 R(S) 84 , Honda XR 600 Dual Carb. 87
Honda XR 280 R Sumo 04 , Honda XR 250 Baja 98
Yamaha Speed MX ( 2 Stroke ) 01 ,CRF250L 13
Schrauberklaus is offline   Reply With Quote
Old 02-22-2012, 07:28 AM   #5522
bdcorrigan
bdcorrigan's Avatar
Oddometer: 338
Did Zombiestomp do some kind of single carb conversion a while back to his RFVC?
bdcorrigan is offline   Reply With Quote
Old 02-22-2012, 07:42 AM   #5523
brucifer
brucifer's Avatar
Oddometer: 1,627
It seems like he did but I'm not sure.
At one time, I had an XR650L engine in my '84 XL600. I used a 38 mm Mikuni flat slide carb with a universal Uni foam filter clamped to the carb. It worked fine. The filter did rub on the shock spring though.
The Mikuni barely fit between the tank and frame. I'm pretty sure the stock XR650L would not fit.
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 02-22-2012, 07:47 AM   #5524
brucifer
brucifer's Avatar
Oddometer: 1,627
Here's a couple pics of it.
It had an XRL front end on it at the time as well.
Old 02-23-2012, 12:18 PM   #5525
67FLAT4
Oddometer: 17
Fork Seals
So I've never done fork seals before, but am good with a wrench. I'd like to order parts and have them ready for when I pull the forks. I've got 2 ?s first is what parts should I replace looks like part 22 on the phish are any other parts needed? and how much oil to put back in?
my fork seals are leaking. (I did seach this thread on fork seals)
67FLAT4 is offline   Reply With Quote
Old 02-24-2012, 05:27 AM   #5526
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Oddometer: 130
Here's my $200 basket case XL600. I repainted the tank with an Elsinore theme. Some top end work, new cam chain and intake valves, thats about it. I can start it on the 5th kick (no decomp release). Torque like a John Deere. But too big and no electric start for trails riding. So this will become a retro-motard as I now have an 04 DRZ400E as my trail/dirt bike.
Well, there would be a photo if I knew how to post it.
Andyvh1959 is offline   Reply With Quote
Old 02-24-2012, 03:32 PM   #5527
lookfar
from the land of OZ
Oddometer: 253
Have a look here.
http://advrider.com/forums/showthread.php?t=919
Stu in FNQ
The early bird catches the worm, but the second mouse gets the cheese.
Growing old is mandatory... growing up is optional.
1985 XL600R
1988 XR600
lookfar is offline   Reply With Quote
Old 02-25-2012, 04:44 AM   #5528
georgej
Oddometer: 155
Thanks for the reply shortlife.I'm planning on replacing all the cables,changing the brake fluid etc.I'm going to try and take the black paint off the frame also.Hopefully the Honda red is baked on and durable.I paid $1100 for the bike and plan on spending another $300-$500 setting her up to ride. I figure for under $2000 I'll have a pretty nice bike for playing on dirt roads.
georgej is offline   Reply With Quote
Old 02-25-2012, 09:54 AM   #5529
sh0rtlife
Oddometer: 467
the honda paint is fairly tough stuff but....id expect to have to repaint anyway....if you want something tough and dont feel like powder coating see if you can find someone who sells tractor paint..the international harvestor red is close enuf..and tough as nails but you may need to hit up an ag store for it
sh0rtlife is offline   Reply With Quote
Old 02-25-2012, 12:14 PM   #5530
georgej
Oddometer: 155
I'm not too awful worried about the black on the frame.I'm more concerned about the black on the carbs and making sure all the cables and front brake line is good.The bike doesn't look that bad.As long as she's functional I'll be happy.Cosmetics come second.
Old 02-26-2012, 07:33 AM   #5531
BRPtourer
Oddometer: 152
If the paint on the carbs is just cheap spray bomb stuff a good carb cleaner will usually take it off. I prefer Berkibile 2+2 Gum Cutter in the blue and red can, some of the others like Gumout and store brands seem pretty weak.
BRPtourer is offline   Reply With Quote
Old 02-26-2012, 09:44 AM   #5532
sh0rtlife
Oddometer: 467
CRC red can is tough stuff too..gumout leaves an oily residue behind...brake clean will do as well but you better have all the rubber off or void hitting it lol....it tends to swell up rubber for a lil bit before it urns back to normal
something i should note for ANYONE striping paint....a brake fluid soak is generaly safe on 95% of most items..with the exception being certain plastics..specificly that of turn signals and tail lights...but is ultra safe on other plastics..as ive been using the same tub (a cut down antifreeze jug) for doing 24 and 25th scale model cars for over 15 years..and only had it soften the plastic a few times..but after a wash its as good as new..ive used brake fluid to remove paint from tins, plastic bike fenders, pretty well everything under the sun..but it will disolve most tail lights
Old 02-26-2012, 03:27 PM   #5533
Watcher
Oddometer: 40
When we first got the 86 I didn't know much about the oil flowing to head issue and ended up running around on the bike for 20 or 30 minutes with no oil, none, getting to the top end. I had been wondering if that did any damage, and after riding around for 500 miles or so she started getting hard to start. Pulled the engine out and found the cam and rockers were ground up. The Center journal in the head had scoring as did the mating journal in the rocker cover although that was much lighter.
I did find what looks like a decent head, valve cover, and rockers over on E-bay, so those are on the way, but I am still looking for the cam. I could send the original to Megacam but the total cost is somewhere north of $270 ( the center has to be repaired which adds to the cost as well as California Tax). So I am looking for a less expensive alternative; for reference, the prices listed on the fiches for a new one is around $140, which of course are no longer available.
This was posted over in the thread Early (85-87) XR600R/XL600R Camshaft options ???
Originally Posted by RED1 View Post
It may be a bit more expensive but if you change cam covers and some rockers you can use the later model cam,I did it on an XBR500 or GB500 to you guys, as you know it is the same engine as the early singles without the auto decomp, I wanted a manual decomp as i made it into a 600 with higher comp for a race engine and I had a later model cover and cam.
So I am wondering if anyone else has gone this route and what if any modifications would have to be done. There seem to be plenty of rocker covers, rockers, and cams available for anything newer than 87. If not I am still in the market for a cam.
I know about when the ride begins, I just don't know when it's going to end.
Watcher is offline   Reply With Quote
Old 02-26-2012, 03:48 PM   #5534
mcma111
mcma111's Avatar
Oddometer: 8,011
Watcher,
As far as finding an OE XL600 cam goes your up the creek without a paddle. I just checked E-Bay England and Germany. No cams there either. Your only option is a Mega Cycle regrind/repair.
BTW...They will not warranty the cam unless you do the rockers also. By the time all is said and done it's $500.00 for the cam and rockers. BTDT
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-26-2012, 04:47 PM   #5535
the_tulip
Oddometer: 13
Kickstarter decompressor lever
Trying to remove the kickstarter decompressor lever to replace the seal. Can't seem to figure it out. Can anyone help me out here? Here's some pictures. Thanks.
Here is the inside of the kickstarter decompressor lever, do I have to remove that pin?
the_tulip is offline   Reply With Quote
Times are GMT -7.   It's 10:51 PM.
