Thread Tools Rating: Thread Rating: 222 votes, 4.92 average. Display Modes
Old 02-23-2012, 02:26 AM   #1651
Mr. J
Oddometer: 9,655
chrissakes... may as well have a two stroke!
Mr. J is offline   Reply With Quote
Old 02-23-2012, 05:55 AM   #1652
Gummee!
That's MR. Toothless
Gummee!'s Avatar
Oddometer: 28,490
Originally Posted by Geek View Post
It detects the def.. and the "purity" of the def.
If you dilute it or anything it detects it and shuts you down.
It won't let you run it without def... if you did manage to run it out you'd burn out some very expensive components in the 2nd catalytic converter (I've been told).
Bummer.
Is Ford pee the same as Benz pee?
...and are there emissions controls on diesels in CO? If you don't have emissions, has anyone successfully yanked the whole kit and kaboodle?
M
I'm a cyclist that rides motos, not a moto rider that rides bicycles.
Gummee! is offline   Reply With Quote
Old 02-23-2012, 06:11 AM   #1653
chacha
CAT Herder
chacha's Avatar
Oddometer: 2,741
Originally Posted by Gummee! View Post
Bummer.
M
Ford, benz, Chevy all the pee is the same. As long as it is ISO 22241 certified it is the same.
The only thing that differs is how you put it into the tank. I know my chevy just has a filler neck like a gas tank under the hood. I buy the 2.5 Gallon bottles of DEF at the auto parts store for like $11.
The Benz has a special filler neck I believe which means you need a Benz bottle or bring it to the dealer to fill. If I owned the benz I would just buy one original bottle from them and then cut the bottle and use it as a funnel or carefully cut the locking teeth at the base of the bottle cap neck. That way I could unscrew the bottle cap valve so I could refill the OEM bottle with DEF from anywhere.
There are emissions tests out here in CO. My Chevy has an emission exempt sticker on the windshield but I think that is only good for 4 years. I haven't really checked that out yet.
Ducati Hyper 796
chacha is offline   Reply With Quote
Old 02-23-2012, 06:41 AM   #1654
ducnut
Oddometer: 3,316
That's not possible, as it's an integral part of the electronics. There are sensors throughout the exhaust system that monitor emissions and the converter(s) to determine their functioning and re-generation needs. I've been told that the integrated muffler/converter on semi-trucks is ~$5K. I wouldn't be surprised if the Sprinter one is a couple thousand.
'09 Triumph Tiger1050
'96 Ducati 900SS
'02 Suzuki SV650S (hers)
ducnut is offline   Reply With Quote
Old 02-23-2012, 06:50 AM   #1655
showkey
Oddometer: 1,934
Originally Posted by pvangel View Post
Is DEF only on the 07 and up Sprinters or first gen as well?
2010 and newer have DEF and DPF
2008 and newer have DPF (diesel particulate filter)
Two different systems for solve two different problems.
http://www.ourexcellentadventures.co...nsFeatures.pdf
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey screwed with this post 02-23-2012 at 06:57 AM
showkey is offline   Reply With Quote
Old 02-23-2012, 06:51 AM   #1656
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,432
You don't need a special bottle .. but if you have the special bottle it is impossible to spill it.
You can just pour it in.
Here's a video I made the first time I filled it:
Old 02-23-2012, 07:35 AM   #1657
ducnut
Oddometer: 3,316
Originally Posted by geode View Post
I was looking at a new box truck last fall, and the converter hung pretty low and looked vulnerable, the dealer told me it would cost $5k to replace it if I dinged it.
That's exactly what I was told about the semi version.
If it's like automotive converters, the "honeycomb" is ceramic. And, yes. That'll crumble, if the casing is dented.
'96 Ducati 900SS
Old 02-23-2012, 07:58 AM   #1658
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,502
My 6.7L Cummins exhaust, which includes the Catalytic Converter, a DPF (Diesel Particulate Filter), and a NAC (Nox absorbing catalyst), and muffler, retails for roughly $7,000 and is rated for approximately 100,000 miles. The Urea injection systems are slightly simpler introducing an SCR (selective catalyst reducer) in which the ammonia in the urea will react with the particulate and the NOx, however the costs are somewhat similar.
No one said diesels were cheap...
Daniel
2005 KTM 950 Adventure S
2004 KTM 525 exc
2006 Beta Rev3
xdbx is offline   Reply With Quote
Old 02-23-2012, 08:15 AM   #1659
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,919
$7,000 after 100,000 miles? That's not just "not cheap", that's fucking insane. I'm so glad I have a year 2000 PSD.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 02-23-2012, 08:17 AM   #1660
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,432
Cripes.. I hope the MB exhaust system goes further than that.. that'd mean I'd spend $42,000 in 600,000 miles on the exhaust system alone? I could buy another van for that.
Old 02-23-2012, 08:18 AM   #1661
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,919
Cripes.. I hope the MB system goes further than that.. that'd mean I'd spend $42,000 in 600,000 miles on the exhaust system? It'd be cheaper to buy a new van...
I could rebuild my entire engine for less than one change of the system on that.
Old 02-23-2012, 08:20 AM   #1662
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,432
If that were the case.. I'd never let the thing get of warranty. I'd keep trading it in (I have a 100K all inclusive warranty on mine).
If it were anyone but Daniel.. I'd question the numbers.. but he does work in Detroit...
Old 02-23-2012, 08:32 AM   #1663
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,351
Colorado does not have emissions testing. Only some of the counties on the front range have emissions testing.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is online now   Reply With Quote
Old 02-23-2012, 08:39 AM   #1664
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,919
I'm going to be the guy driving a 40 year old van some day.
Old 02-23-2012, 08:57 AM   #1665
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,432
Perfect! If I move to the San Juans I can rip the adblue system out of the van. Then I just need to figure out how to reprogram the computer so it'll start
Thread Tools
Times are GMT -7.   It's 11:17 AM.
