02-13-2012, 05:49 AM
#796 |
Buffoonery, Inc.
Oddometer: 2,273
Sammy had set Pro lines just for them. Nathan rode with them, although Karl and Brian ride Pro in the NATC, and Nathan rides Expert. Nathan did a very good job of not getting totally whupped by two pros. Brian won, followed by Karl and Nathan. It was fantastic to have these guys come down and ride with us.
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. brewtus screwed with this post 02-13-2012 at 07:06 AM Reason: Brian, David, whoever. |
02-13-2012, 09:08 PM
#797 |
Team Listo
Oddometer: 18,303
Still uploading videos, but here are a few shots from yesterday.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More coming........ |
02-14-2012, 04:46 AM
#798 |
Oddometer: 774
That last picture of Karl is an injustice. It was more than a 10 ft jump and that was a 12 ft hole. Wow the fat guy on a real montesa sure had fun.
02-14-2012, 05:28 AM
#799 |
Team Listo
Oddometer: 18,303
02-14-2012, 06:02 AM
#800 |
Oddometer: 774
Section 7, I had a 1, a clean and a clean . Which was better than when I rode it on my Raga. LOL.
02-14-2012, 07:22 PM
#801 |
Team Listo
Oddometer: 18,303
![]() TrevDog ![]() Roper How would you like to land this? ![]() Karl Davis ....or this?
02-17-2012, 06:35 PM
#802 |
Single Track Noob
Oddometer: 1,455
I continued going through my new to me 4rt. So far it looks like the bike was put away without much thought after each ride. So far I've found the following:
The air filter was full of pine needles the swing are bearing were dry and loose requiring new link plates the head bearing were too tight the fork oil was shiny silver chain tensioner arm was loose and worn beyond repair Rear wheel has a flat spot that is likely not fixable, but still rideable rear rotor is slightly bent side stand extends too far forward throttle was sticky and didn't spring back closed drain plug missing from the airbox rear wheel bearings knotchy Here's what I've done so far ziptie stitched the cracked fender and drilled a relief hole to stop the crack cleaned the air filer and airbox changed fork oil lube and tensioned head bearing removed fork spring and rear shock to investigate custom wound stiffer springs Things left to do Change engine and trans oil check valves flush coolant replace chain tensionor and rear wheel bearings straighten rotor? lube swingarm bearings lube linkage reinstall shock/spring bleed brakes/clutch figure out taller bars Hopefully my parts arrive on Monday and I can get everything buttoned up and read to ride by next weekend.
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
02-20-2012, 02:44 AM
#803 |
stupid hipster dufus
Oddometer: 479
02-24-2012, 05:59 PM
#804 |
Team Listo
Oddometer: 18,303
Last week we had this:
![]() Some kind of tranny problem. ![]() ![]() Last night Lineaway came over and helped me put it all back together. It was a long night, but we were determined to get it all done. At least I was! ![]() Thanks Bob!! ![]() A few "issues" remained but it seems like all is good now! I am so stoked that it all worked out and that there are guys like Bob out there willing to share their knowledge and time!!
02-24-2012, 08:16 PM
#805 |
Team Dead End
Oddometer: 4,458
Awesome lineaway!! Thanks for helping out a buddy Bob...you rock!!
![]() Good news Gordy! We should get a good break in this weekend!
02-25-2012, 05:03 PM
#806 |
Buffoonery, Inc.
Oddometer: 2,273
If you didn't ride it like such a Pro, you would not have these issues....
![]() Glad to see you have it back together. You owe Bob a case of beer!!
Work hard. Play hard. Team Dead End. The drinking team with a Trials problem. ![]() 2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ. |
02-25-2012, 05:35 PM
#807 |
Resident
Oddometer: 857
I installed a new rectifier and thermostat to my Sherco today.
And last sunday I replaced the fork seals. Now I finally have a fully functional trials bike ![]() She's ready to ride tomorrow even though there may be 4 or 5 inches of snow. Oh well. It will still be a fun day. |
02-25-2012, 08:57 PM
#808 |
Professional Idiot
Oddometer: 927
02-26-2012, 02:42 AM
#809 |
Oddometer: 479
"I enjoy playing in snow like you're riding in there - seems like it forces you to do things right to get traction. It's less fun when it gets more than a few inches deep though.
Did you give up on the Scorpa? " Motojunky, I sold the Scorpa to a good friend so I'd always have a riding buddy. He's taking the picture. New carb and it spins like a top. NVTS
02-27-2012, 02:08 PM
#810 |
Commutator
Oddometer: 1,176
I don't actually have a trials bike, so I use my XT225 for one
![]() This video has some stuff that might interest you guys. Log crossing craziness starts at 1:35. We found a set of three logs in a row and had to try them out. There is also a nice ravine crossing to accidental wheelie with 360 pirouette I'll quit crapping up yer trials thread now |
