Old 02-13-2012, 06:49 AM   #796
brewtus OP
Buffoonery, Inc.
brewtus's Avatar
Oddometer: 3,001
Sammy had set Pro lines just for them. Nathan rode with them, although Karl and Brian ride Pro in the NATC, and Nathan rides Expert. Nathan did a very good job of not getting totally whupped by two pros. Brian won, followed by Karl and Nathan. It was fantastic to have these guys come down and ride with us.
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
brewtus screwed with this post 02-13-2012 at 08:06 AM Reason: Brian, David, whoever.
brewtus is online now   Reply With Quote
Old 02-13-2012, 10:08 PM   #797
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,631
Still uploading videos, but here are a few shots from yesterday.
More coming........
Gordy is offline   Reply With Quote
Old 02-14-2012, 05:46 AM   #798
lineaway
Oddometer: 2,736
That last picture of Karl is an injustice. It was more than a 10 ft jump and that was a 12 ft hole. Wow the fat guy on a real montesa sure had fun.
lineaway is offline   Reply With Quote
Old 02-14-2012, 06:28 AM   #799
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,631
Originally Posted by lineaway View Post
That last picture of Karl is an injustice. It was more than a 10 ft jump and that was a 12 ft hole. >With no room to stop when he lands!! <Wow the fat guy on a real montesa sure had fun.
That fat guy on the old bike did ride well all day!!
Old 02-14-2012, 07:02 AM   #800
lineaway
Oddometer: 2,736
Section 7, I had a 1, a clean and a clean . Which was better than when I rode it on my Raga. LOL.
Old 02-14-2012, 08:22 PM   #801
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,631
TrevDog
Roper
How would you like to land this?
Karl Davis
....or this?
Old 02-17-2012, 07:35 PM   #802
brianjonesphoto
Single Track Noob
brianjonesphoto's Avatar
Oddometer: 1,559
I continued going through my new to me 4rt. So far it looks like the bike was put away without much thought after each ride. So far I've found the following:
The air filter was full of pine needles
the swing are bearing were dry and loose requiring new link plates
the head bearing were too tight
the fork oil was shiny silver
chain tensioner arm was loose and worn beyond repair
Rear wheel has a flat spot that is likely not fixable, but still rideable
rear rotor is slightly bent
side stand extends too far forward
throttle was sticky and didn't spring back closed
drain plug missing from the airbox
rear wheel bearings knotchy
Here's what I've done so far
ziptie stitched the cracked fender and drilled a relief hole to stop the crack
cleaned the air filer and airbox
changed fork oil
lube and tensioned head bearing
removed fork spring and rear shock to investigate custom wound stiffer springs
Things left to do
Change engine and trans oil
check valves
flush coolant
replace chain tensionor and rear wheel bearings
straighten rotor?
lube swingarm bearings
lube linkage
reinstall shock/spring
bleed brakes/clutch
figure out taller bars
Hopefully my parts arrive on Monday and I can get everything buttoned up and read to ride by next weekend.
Brian
Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa
www.PhotoSupportNW.com
brianjonesphoto is offline   Reply With Quote
Old 02-20-2012, 03:44 AM   #803
NVTS
stupid hipster dufus
Oddometer: 646
NVTS is online now   Reply With Quote
Old 02-24-2012, 06:59 PM   #804
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,631
Last week we had this:
Some kind of tranny problem.
Last night Lineaway came over and helped me put it all back together. It was a long night, but we were determined to get it all done. At least I was!
Thanks Bob!!
A few "issues" remained but it seems like all is good now! I am so stoked that it all worked out and that there are guys like Bob out there willing to share their knowledge and time!!
Old 02-24-2012, 09:16 PM   #805
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,119
Awesome lineaway!! Thanks for helping out a buddy Bob...you rock!!
Good news Gordy! We should get a good break in this weekend!
NMTrailboss is offline   Reply With Quote
Old 02-25-2012, 06:03 PM   #806
brewtus OP
Buffoonery, Inc.
brewtus's Avatar
Oddometer: 3,001
If you didn't ride it like such a Pro, you would not have these issues....
Glad to see you have it back together. You owe Bob a case of beer!!
Old 02-25-2012, 06:35 PM   #807
Doctor Zed
Resident
Doctor Zed's Avatar
Oddometer: 1,341
I installed a new rectifier and thermostat to my Sherco today.
And last sunday I replaced the fork seals.
Now I finally have a fully functional trials bike
She's ready to ride tomorrow even though there may be 4 or 5 inches of snow.
Oh well. It will still be a fun day.
Doctor Zed is online now   Reply With Quote
Old 02-25-2012, 09:57 PM   #808
motojunky
Professional Idiot
motojunky's Avatar
Oddometer: 1,081
Originally Posted by NVTS View Post
I enjoy playing in snow like you're riding in there - seems like it forces you to do things right to get traction. It's less fun when it gets more than a few inches deep though.
Did you give up on the Scorpa?
motojunky is offline   Reply With Quote
Old 02-26-2012, 03:42 AM   #809
NVTS
Oddometer: 646
"I enjoy playing in snow like you're riding in there - seems like it forces you to do things right to get traction. It's less fun when it gets more than a few inches deep though.
Did you give up on the Scorpa? "
Motojunky, I sold the Scorpa to a good friend so I'd always have a riding buddy. He's taking the picture. New carb and it spins like a top. NVTS
Old 02-27-2012, 03:08 PM   #810
nuggets
Fries with that?
nuggets's Avatar
Oddometer: 1,812
I don't actually have a trials bike, so I use my XT225 for one
This video has some stuff that might interest you guys.
Log crossing craziness starts at 1:35. We found a set of three logs in a row and had to try them out. There is also a nice ravine crossing to accidental wheelie with 360 pirouette
I'll quit crapping up yer trials thread now
2001 400 EXC "Punkin" | 2005 Sherco 290 "Tree Climber" | OSET 16.0 | OSET 16.0 hard tail
nuggets is offline   Reply With Quote
Times are GMT -7.   It's 12:09 PM.
