02-23-2012, 02:12 PM
#136 | |
Oddometer: 414
Sounds like cheap bits...the driver must have worked OK to shear the bits. I'm thinking the driver with better bits would have worked well. Tech23
CRF 150/230/ Supermoto Conversion 2004 Suzuki DR 650SM 2000 Harley Davidson FXDWG |
02-24-2012, 02:25 PM
#137 |
Oddometer: 2,074
$89 2 stroke generator
3 months ago while living in my camper in Arizona my battery went dead so I hopped on my motorcycle and picked up this little 2 stroke 800/900 watt generator and a battery charger at HF. Nearest I can tell it's an exact copy of a Yamaha ET800, the simplest generator imaginable. I've put well over 100 hours on it so far and I'm quite pleased with how it works including the low noise level. It'll be on sale for $89 again March 9-11.
http://www.harborfreight.com/engines...tor-66619.html |
02-24-2012, 04:56 PM
#138 | |
A proud pragmatist.
Oddometer: 2,859
Even bent an old Proto 3/8 drive Phillips bit on my very old Blue Point Impact a few days ago and that p....d me off it was my Grandpa's.Ouf....the Bing bolts heads survived but still stuck and I just can't heat "them" up.
Have tools, will travel!
02-24-2012, 10:27 PM
#139 |
Oddometer: 411
The chain breaker on sale for $10 cut my beat-to-hell 525 chain like a hot knife through butter. Hard to argue with that.
Formerly gainfully employed, now a starving student. Go Bruins! |
02-25-2012, 06:26 AM
#140 | |
Planning.....
Oddometer: 5,242
Ride safe enough.... |
02-25-2012, 07:08 AM
#141 |
Oddometer: 163
This chain hoist and I-beam trolley worked really well for pulling the motor from a British Sportscar. I needed the 2-Ton trolley since the I-Beam in my garage is fairly wide, but there are 1,2, 3 ton varieties.
http://www.harborfreight.com/1-ton-chain-hoist-996.html http://www.harborfreight.com/2-ton-c...ley-40493.html ![]() ![]() Can't find much wrong with their 1000 lb engine stand either. http://www.harborfreight.com/1000-lb...and-32916.html
02-25-2012, 07:12 AM
#142 |
Oddometer: 119
I've been using the same ramp for our dirtbikes since 2005. Had 2 250lb guys and a SV650 on it once, was a bit nervous but it was fine. Has been money well spent,
02-25-2012, 07:14 AM
#143 |
Oddometer: 2,074
02-25-2012, 12:43 PM
#144 |
Not so Gnarly
Oddometer: 3,976
I had a 1000 w Chicago generator from HF a few years back and just couldn't keep it running. I have since purchased a Honda 2000 w and been extremely pleased with it. Big price difference.
Most everything else I have purchased at HB has been outstanding. I could easily bought a lemon and I no longer see that particular model listed on their site.
Doo Done |
02-25-2012, 10:06 PM
#145 |
Oddometer: 71
bought a 1/2 inck=h inpact to remove wheels - would not greak the lugs loose-JUNK
Bought some air blowers to connect to air hose ends fell off also yellow air line busted a major leak The best thing I got from there is a set of picks with orange handels on it I like them $5 will never go back
Not old enough for a Harley |
02-26-2012, 12:05 AM
#146 |
Mine busted after 4 years... 80.00 well spent. I used it to load my moms civic, Mercedes, my bikes, atvs, and a dunebuggy
02-27-2012, 07:42 AM
#147 |
Once you go Triple...
Oddometer: 20,409
Anybody have any experience with this bearing separator:
![]() How about this one: ![]() I'm mainly looking for a tool to do steering stem bearings but it may also come in handy for other work. Cheers
'12 Tiger 800XC '07 TE510 '02 Sprint ST '99 XR650L '99 Speed Triple |
02-27-2012, 04:48 PM
#148 |
b00b
Oddometer: 251
Great experience’s with most of what I have bought from HF. And nice thing if it breaks then it can always be turned into a "specialty tool" or so called art. Plus its cheap so who gives a fuck? But I can't do it anymore.. I can't bring myself to ever go into another HF again. Reason being I was standing in line and there was a American Flag for sale. Where was it made? In china. I truly felt sick. No more HF for me.
Here I sit broken hearted, tried to shit. But only farted 1979 Schwinn 10 speed |
02-27-2012, 06:49 PM
#149 | |
"Cool" Aid!
Oddometer: 41,488
![]() None the less, I still frequest HF. More and more USA made items are there to be had. Jim
02-27-2012, 06:54 PM
#150 |
Oddometer: 9,781
