02-17-2012, 06:51 AM
#46 | |
ODAT ADV Seeker
Oddometer: 159
99HD ROAD KING 2006 BMW F650GS |
02-17-2012, 11:58 AM
#47 | |
Oddometer: 92
Also use a set of soft Wolfmans Tetons which are good for a small trip in drier weather. Top box is also a caribou mounted on thier top rack and a Wolfman enduro tankbag. And a SW Motech Bags connection tent bag as a roll bag on the back seat if needed. GS is excellent, love it, this is my 4th adventure bike and this one is the best ! |
02-19-2012, 04:42 AM
#48 | |
Oddometer: 279
http://www.aerostich.com/packing-it-...addlebags.html |
02-19-2012, 06:48 PM
#49 |
Oddometer: 279
BarkBusters, Touratech Shift Pedal & Foot Pegs
Added a few farkels today. Thought I would tell you my thoughts.
The BarkBusters went on pretty easy. The instructions were in english but the pictures to show you the details were too small and dark. I need to play with them a little more to see if I can adjust them upwards more. Problem is, there is not a lot of room to adjust before they hit the dash. ![]() ![]() You have to remove the ABS switch housing in order to install the bar risers that come with the kit. You don't have to extend any of the cables. The kit also comes with it's own set of bar end weights. ![]() Next up were the foot pegs. These come from Touratech and there are two models. One model retains the stock distance between footpeg and shifter. The other model moves it forward so the footpeg is closer to the shifter. I got the stock replacement. When standing on the pegs, I have to have my heel on the peg to reach the shifter. I wear a size 10 shoe. If I had to do it over again, I would get the one that moves your foot closer to the shifter. The foot peg should be in the middle of your foot when standing. Stock - ![]() Touratech ![]() Finally, The shifter -- I had bent mine when I dropped it once. I was surprised at how soft the metal was. Additionally, the stock shifter toe part doesn't compress. So, if it hits the ground it bends. The Touratech toe part has a spring on it and folds in when it hits the ground. Stock - ![]() Touratech - ![]() There you have it. Have fun farkeling ! |
02-25-2012, 01:11 PM
#50 |
Colonel Blood
Gimmie Storage!
In prep for a TAT ride this summer I decided to 'find' some storage room for stuff like tubes, bead breaker, tire irons, tools, etc. Since I have Wolfman racks fitted the logical spot is something attached to the left side rack, under the left 'muffler'. The first thought was to use 4" PVC but since I have scrap aluminum and a TIG welder I decided to go that route. Just installed the final product:
![]() You can see the 1" X 1/4" mild steel strap welded to the rack. This is primary support for the box, secondary support is through the plate on the left side. The plate will be bolted to the box and to the rack, using tabs I welded there. ![]() This is clear of the swingarm arc as well as the possum scraper and will be mostly hidden by the Wolfman bags. Of course, no good idea survives the first road trip so an upcoming trip to FL will be the test.
Growing old ain't for sissies! |
02-26-2012, 01:56 PM
#51 |
ride enything but HD
Oddometer: 789
I run out of room in the garage so I park Her bike in living room.
MOTORCYCLES-->created to keep us from choking the idiots around us "w strone slonca..........." www.rapidroadrescue.com |
02-26-2012, 03:55 PM
#52 | |
Oddometer: 126
Really nice job on the alu box.
Can you see me now? dr200 f650gs r60/6 ttr125 crf230f crf150f amf(moped) |
02-26-2012, 10:27 PM
#53 |
Oddometer: 69
02-27-2012, 08:45 AM
#54 |
Butler Maps
Oddometer: 14,580
same seat i assume
http://seatconcepts.com/products#ecw...roduct=8776231
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
02-28-2012, 09:59 AM
#55 |
Oddometer: 11
Hi everyone
First post and first adventure bike. Recently got a G650GS and trying to squeeze some miles to get to know the bike. Im enjoying the ride, though must say that I would need a bit more time to get used to the riding style. No modifications or accessories yet, and Im still trying to figure out what is actually needed, what fits, what works, and trying to not fall into the trap of getting inappropriate gear. initial observations - I didnt expect that the seat can actually get noticeably hot while riding. Im not sure if its the heat of the engine or if its just our weather here (asia - start of summer). Front suspension also seems to be on the soft side. At the break-in maintenance check, Im considering having the fork oil replaced to something thicker (bit odd - when i checked the manual, i couldnt find the fork oil specs.) cheers!
Guuunnniitttt |
02-29-2012, 02:55 AM
#56 | |
Oddometer: 279
Anyway, the fork oil in your GS is 7.5 wt. Some people say they notice a difference with 10 wt. If you really want to see a difference in your front end, consider changing out the shock springs. Good Luck. |
02-29-2012, 09:50 AM
#57 |
brake bleed
I dont know of any precautions but I would get some speed bleeder screws to make it easier. Also it takes a long time to bleed them because the circuit is quite long in the ABS unit I suppose.
02-29-2012, 09:51 AM
#58 |
02-29-2012, 10:57 AM
#59 | |
ODAT ADV Seeker
Oddometer: 159
03-02-2012, 11:47 AM
#60 |
Oddometer: 789
Only one known US bike with red/black seat.
