Old 02-25-2012, 12:41 PM   #1
More CowBell OP
gotahave moreCowbell
More CowBell's Avatar
Oddometer: 208
TL125 super hard clutch pull, "Now What"
I got a 74 TL125, it runs great. I want to set it up for my daughter but the clutch pull is way too hard. I got a an easy clutch but didnt make hardly any differance. Can I put in lighter springs? Has anyone else did something to lighten it up?
13 KTM 350EXC, uncorked, race bike with a plate
07 YAMAHA FZ6. would trade for the right KLR650
05 Montesa 4RT. SOLD
More CowBell screwed with this post 02-25-2012 at 12:43 PM Reason: spelling
More CowBell is offline   Reply With Quote
Old 02-25-2012, 01:14 PM   #2
Twin-shocker
Oddometer: 1,673
I take it you have already fitted a new cable?
Old 02-29-2012, 07:21 PM   #3
welder
welder's Avatar
Oddometer: 1,523
lengthen the actuating arm on the cases
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 03-03-2012, 09:55 PM   #4
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,578
Oil the cable and grease the moving parts, it will make an amazing difference.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 03-04-2012, 09:38 AM   #5
Twin-shocker
Oddometer: 1,673
Not as much as renewing a damaged or worn cable...................
Old 03-06-2012, 10:12 AM   #6
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Or putting on a new cable from Motion Pro, an EZ Pull and lengthening the arm.
buls4evr is offline   Reply With Quote
Old 04-12-2012, 11:20 AM   #7
trialxls
Oddometer: 4
You can solder /screw a lever extension...
trialxls is offline   Reply With Quote
Old 04-12-2012, 11:38 AM   #8
trialxls
Oddometer: 4
Wink
Hi,
I tried to answer with a photo, but I am not sure I'm allowed, because it's my first post; I just found this forum today: I am french and offen on honda-125xl dot com forum...
You can solder or screw an arm extension on engine side: I did it on my XLS to get more progressivity ...
Old 04-12-2012, 03:20 PM   #9
Shercoman
Oddometer: 457
If a new cable and lubing everything doesn't work....
We used a Magura hydraulic clutch kit on my wifes 400EX to fix this issue.
Pulls with one finger now.
Probably no kit for this bike but a simple bracket to mount the slave cylinder would be easy to make.
Shercoman is offline   Reply With Quote
Old 04-12-2012, 11:53 PM   #10
Twin-shocker
Oddometer: 1,673
Chinese pit bike hydraulic clutch kit may well fit, and is only about 1/10 of the cost of the Magura ones.
Old 04-13-2012, 10:41 AM   #11
Shercoman
Oddometer: 457
Where do you buy those?
Times are GMT -7.   It's 10:18 PM.
