Old 03-12-2012, 02:54 AM   #2986
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
Originally Posted by mcfear View Post
well theres no vacuum leaks that i could find,
i bought and tried a 180 main jet and that made it at least run without the choke on, but its still not right.
thinking im just gonna hand over the money for one of my other forums sponsors to tune it properly.
sounds like its fucked i'll give ya 500
iam just not ready to be an adult
[QUOTE=troy safari carpente;24254589]
... the XR is the greatest off road motorcycle ever constructed. There's nothing it can't do, hasn't won or will not outperform.
digga1111 is offline   Reply With Quote
Old 03-12-2012, 03:14 AM   #2987
mcfear
now known as many things
mcfear's Avatar
Oddometer: 2,587
and then the rest and we have a deal haha.
as much as i hate to say it, i wish i still had my DR.
i spent less on that bike and it ran better then this has.
http://adventurerider.com.au/
My International Travel Blog
http://www.mcfearsadventures.blogspot.com.au
Originally Posted by tHEtREV View Post
mcfear is online now   Reply With Quote
Old 03-12-2012, 03:18 AM   #2988
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
1200 final offer
cash buyer
all your problems will be solved
http://youtu.be/8tSo4IICBTY
Old 03-13-2012, 05:29 AM   #2989
KASUYAHO
Road Hog
Oddometer: 3,647
McFear,
Your pilot jet is clogged and by putting in a richer main jet has over come part of this problem.
I bet it is hard to start and has some hesitation off idle and the idle is inconsistant.
And my guess is you have set the idle high to get it to idle.
If you turn down the idle till it near stalles then turn in the mixture screw and if the engine keeps running
and the mixture screw does not make much difference that shows the pilot jet is clogged.
Just go by a new pilot jet ( 68S ).
Do you know the proper way to adjust the mixture screw ?
KASUYAHO is offline   Reply With Quote
Old 03-13-2012, 06:01 AM   #2990
mcfear
mcfear's Avatar
Oddometer: 2,587
cheers mate,
will buy a new pilot jet,
i think i do, i read about it on the pig pen.
if i take the baffle outta the pipe, will the 180 jet be more suitable or would i be better suited putting the 175 back in?
Old 03-13-2012, 06:37 AM   #2991
KASUYAHO
Road Hog
Oddometer: 3,647
Yeh i would go back to the 175 main jet, the engine will be more responsive.
Have you downloaded the genuine Honda manual for the bike ?
A tip is too to set the float height at 16mm not 18mm as the manual states.
In regards to the stock carby, it has to be tuned richer than a pumper carby,
easy way is to keep turning out the mixture screw until the flat spot dissapears.
Old 03-13-2012, 10:58 PM   #2992
mcfear
mcfear's Avatar
Oddometer: 2,587
dropped the bowl again today and checked the pilot jet, its not blocked. but it is a 65, not a 68s. i asked at honda for a 68s and they said the only thing they could order was a 68, which i reckon would be better then a 65 but they knew nothing about a 68s.
so if i go back to a 175 and replace the 65 with a 68 then adjust my pilot screw that "should" make it all good?
if i take the baffle outta the pipe would the 180 be better then the 175?
Old 03-13-2012, 11:17 PM   #2993
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,431
1 got 175 /65 stock carb stock pipe .sidecover mod
bike runs fine snap on the throttle
it also ran ran well with the biggun on same carb settings
cant help ya Mcface
try Glens idea .....pull carb down and clean it .....blow jets out
Sean-0 is offline   Reply With Quote
Old 03-14-2012, 12:38 AM   #2994
TB650
Would be Adventurer
TB650's Avatar
Oddometer: 795
The 68 pilot jet is similar to the 68s. They both share the same main orifice size for the discharge nozzle, but the 68s has smaller emulsion holes on the sides of its tube. The smaller holes on the 68s pilot jet reduces the amount of air that mixes with the fuel before the emulsified mixture is discharged through the jet's nozzle.
I took my 68s out once and lost it dont ask
Nick Doyle helped me set mine up when I put the T4 exhaust on and said a 65 is better than a 68 not a 68s (he should know he built all of Ballards and GHRs) He also set mine up with a 175 main took a 185 out and it has a HRC kit and more engine work than most.
Most Honda shops dont know about the 68s unless you have the part number And here is the Honda P/N: 99105-MBN-0680
TB
XTZ660, WR250R Prerun bike awesome!, ex GHR XR650, A second XR650R and the mighty CT110
www.rideadv.com.au
TB650 is offline   Reply With Quote
Old 03-14-2012, 12:58 AM   #2995
mcfear
mcfear's Avatar
Oddometer: 2,587
well that means that my carby should have been running properly.
only thing i can think of now is the timing must be out still.
it was put back together by a mechanic, but will check it myself this weekend. if thats wrong then i can either assume that the the mechanic put it back together wrong, or when i got it reground, they didnt index it properly and the lobes have been reground wrong.
Old 03-14-2012, 02:34 AM   #2996
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,238
It's possible that the cam timing is out..
But if you can ride it with the choke on and it runs fine above 2000rpm say, then it's probably either an air leak or a problem with the carby maybe even a crack in the slide.
Does the carby have a drain plug? If it does, drain it into a clear glass and see what's in there. If there's water in your fuel, it'll stuff up your idle. It is also the first thing to come out of your tank should you have the tap on reserve as it's heavier than petrol.
Other than that, I got nothing
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 03-14-2012, 02:50 AM   #2997
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
checking the timing is pretty easy, are you doing this yourself?
Old 03-14-2012, 02:59 AM   #2998
mcfear
mcfear's Avatar
Oddometer: 2,587
yeh i will be checking the timing myself, its easy enough to do.
i have done basic mechanicing at tafe, so can do engine work without issue, but gearbox and carby issues scare me haha as i have done nothing before in that area.
Old 03-14-2012, 03:16 AM   #2999
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
talk me through it. how do you do again? line up the mark on the fly wheel or some thing?
Old 03-14-2012, 03:25 AM   #3000
digga1111
bann ed
digga1111's Avatar
Oddometer: 3,545
if you get lost have a look here http://www.borynack.com/xr650r/xr650rmanuel.pdf
next to the inlet boot on the head on the earlier models there is a little bolt. is that bolt installed. what did you do to check for a vacuum leak?
Times are GMT -7.   It's 08:53 AM.
