Old 12-29-2011, 10:55 PM   #106
Masa
Masa's Avatar
Oddometer: 301
Originally Posted by alshaffer View Post
Anyone have any info on these?
I believe those protectors are the ones in this post, scroll down to see installation:
http://www.advrider.com/forums/showt...33#post5977033
IMHO looks like much harder to install. 85sx's has square bottoms and fits "nicely".
Masa is offline   Reply With Quote
Old 03-17-2012, 11:00 AM   #107
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 953
better pictures and parts list
Recently I had a question about this modification. I shot some better pictures as well as scanned my invoices that have the list of parts for the job (as I did it). Hopefully this will be helpful to someone doing this. I have had zero issues with water spray after doing this and no air flow problems either. If you use spacers like I did to lower the fender below the triple clamp,( rather than raise the brake line harness that is attached to the top side of the lower triple as one rider did) you may have contact with the tire under full compression (at the rear most part of the fender). You could trim the fender, or simply adjust your suspension settings as I did. Also IF you use spacers you will need 30mm bolts to come up through the fender (and spacers) into the bolt holes in the lower triple. I used 4 stainless washers not listed on the invoice as well.
Here are the parts:
Here are shots of the brackets I made to reinforce the fork protectors since the holes do not line up (one out of three does). This is 3/4" by 1/4" aluminum from the hardware store.
I made this side longer on the side to attach the abs line with a zip tie.
I trimmed the stock clip off the abs bracket and trimmed the fork protector to fit around what was left.
Since this was originally a thread about Brake Line Routing with a High Fender I have included shots of how I routed mine without disturbing my stock brake line harness. For reference I have a 2009 with ABS.
Thats it. It wasn't a difficult job. I made the brackets at the bottom of the fork protectors by measuring the front and sides and using a vise and a hammer to bend the material. Then filed the edges with a big flat file. The insides of the forks will get rubbed by the brake lines, and I used 3M clear film to prevent any more damage after I noticed the anodization being rubbed off (visible in one of the shots).
I've learned so much from my mistakes. I'm thinking of making a few more.
09 KTM 990 Adv
Lycan1 is offline   Reply With Quote
Old 03-17-2012, 01:44 PM   #108
plumbtired
plunging into the farkle
plumbtired's Avatar
Oddometer: 184
Thumb Nice job.
Might want to consider routing the brake lines outside the forks. Didn't theses bikes required pipe fittings?
RidnChina
If they all worked right I'd be retired
08 990
98 DR
plumbtired is offline   Reply With Quote
Old 03-17-2012, 04:08 PM   #109
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 953
Originally Posted by plumbtired View Post
Might want to consider routing the brake lines outside the forks. Didn't know these bikes required pipe fittings?
Cheap, fast fix that was done because I had a 2 week bike holiday starting the morning after the other parts came in. It works so I left it alone. Don't fix it if it ain't broke.
The lines work very well where they are (other than the fork contact) and are less likely to snag in a crash IMO. Others have routed on the outside and still had the rubbing issue. Once you put on the clear tape it really isn't an issue.
09 KTM 990 Adv
Old 06-18-2014, 11:30 AM   #110
Brown Town
Brown Town's Avatar
Oddometer: 195
Originally Posted by Garand View Post
Here is a pic of the "clamp" Sheepy is speaking of.
Here is the parts diagram as well
Numbers 22 and 24 in that drawing
part numbers:
60013025100 - BRAKE HOSE GUIDE FRONT 03
60013025050 - RUBBER FOR BRAKE HOSE GUIDE03
Is there a left side break hose guide as well or just the right side?
-BT
Brown Town is offline   Reply With Quote
Old 06-18-2014, 12:53 PM   #111
JoeMongo
¿Por dónde?
JoeMongo's Avatar
Oddometer: 532
Same part. Just buy two of each.
'08 990 ADV, '03 DR-Z400S
Anything worth doing, is worth overdoing.
JoeMongo is offline   Reply With Quote
Old 06-18-2014, 02:00 PM   #112
Brown Town
Brown Town's Avatar
Oddometer: 195
But then it's facing the wrong way (in instead of out).
Just bend it to shape?
-BT
Old 06-18-2014, 02:18 PM   #113
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 953
See Above
Post # 107 third and forth pictures. No need to bend anything, they work fine as is.
09 KTM 990 Adv
Old 06-18-2014, 03:23 PM   #114
Brown Town
Brown Town's Avatar
Oddometer: 195
It doesn't push your lines towards your tire too much? Man just holding it up to mine and it looks sketchy without some modding.
-BT
Old 06-18-2014, 04:21 PM   #115
Lycan1
Grizzly herder
Lycan1's Avatar
Oddometer: 953
65,000 kms. On it with zero issues now. Even in mud so bad my wheel was nearly locked and no problems. On the side where the opening faces the tire I cinched a zip tie to tighten the wire opening, preventing the rubber insert from pulling out.
09 KTM 990 Adv
Old 06-18-2014, 04:55 PM   #116
Brown Town
Brown Town's Avatar
Oddometer: 195
I just bent it slightly in the opposite direction and it's now similar to the right side in distance from the tire.
The zip tie is a great idea–almost mandatory.
Thanks for the help!
-BT
Old 07-04-2014, 10:51 AM   #117
DIRT DERRICK
Oddometer: 11
Zen Overland has started doing kits, Mine was a prototype but I think it looks Spot on!
I will post some pics tomorrow!
DIRT DERRICK is offline   Reply With Quote
Old 12-08-2014, 07:47 PM   #118
Deathb4Mullets
Oddometer: 8
Any word on the kits?
Deathb4Mullets is offline   Reply With Quote
Old 02-04-2015, 06:55 AM   #119
kleinholz
kleinholz's Avatar
Oddometer: 10
Zen Overland 990 High Fender Kits
Hi folks,
I searched an eternity for a bracket for the fork guards. Fortunately Zen Overland finally came up with a great looking solution I really like. (Pictures to be found below or on the net, search for "Zen Overland High Fender Kit")
Only problem is, my bike is a 2012 ABS model and Gabriel told me their brackets won´t fit ABS bikes because of the sensor mount.
He would give it a go to design them for our bikes too but needs a bike as a template to do all the measuring.
He could design brackets fitting the SX85 protectors and the closed ones from the 690 Enduro I believe.
I´m living in Austria so it´s not possible to borrow them my bike but if there´s anyone out there living near them it would be great if you could help! I´m sure Gabe would have some nice reward for you
Really like dealing with them (not affiliated in any way). Gabe guided me through the whole decision process for the Kriega soft luggage. I couldn´t decide between the US30 or the US20 and also needed a backpack. He put everything I needed for my daily commute in the pockets to figure out which would fit best! Great guy!
You could be our all hero if anyone of you could make this possible!
Regards
Kleinholz
kleinholz screwed with this post 02-04-2015 at 02:09 PM
kleinholz is online now   Reply With Quote
Old 02-04-2015, 08:57 AM   #120
Zen Overland
Zen Overland's Avatar
Oddometer: 87
Our fork guard brackets
Machined from aluminium angle. The bolts that go into the fork leg are countersunk so the plastic fork guards sit flush, and the holes for the fork guard are tapped.
We also made replacement spacers to go under the fender, to pack it away from the triple clamps a bit. Like the stock KTM spacers but with another 10mm or so clearance.
The project we did was for a non ABS bike, but it would be great to make a kit for the ABS version.
We have these brackets in stock if anyone needs them.
www. ZEN Overland .com
Adventure and travel motorcycle equipment in the UK
MEFO tyres - Andy Strapz - Rigid Industries LED - Black Dog Cycle Works - Kriega
Zen Overland is offline   Reply With Quote
Times are GMT -7.   It's 01:07 AM.
