Old 03-22-2012, 09:18 PM   #1
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 531
Thumb R75/6 sidecar suggestions
1974 r75/6 stock bike looking to add sidecar. Simple lightweight for a dog mostly.
No brakes for sidecar. Just a very basic light rig. Almost what you would see on a klr.
Looking for any ideas / suggestions.
What frame / mounting hardware would be best /simple.
More I think about this I am looking for a platform to put a medium dog crate.
Lurking here and love the builds I see on the hacks.
Biebs screwed with this post 03-22-2012 at 09:35 PM
Biebs is offline   Reply With Quote
Old 03-22-2012, 10:33 PM   #2
Ivan Rider
Ivan Rider's Avatar
Oddometer: 602
Don't go too light or you will not be able to keep the wheel on the ground. I've had several Airheads with Ural sidecars and I'm pleased with that combination. I had a sputkin cargo hack on my R80 and it was almost too light. If you thought right turn the chair would fly.
'78 BMW R100/Ural sidecar, '99 Ural Patrol
'03 BMW R1200CLC Solo & Ural sidecar Rig
'06 Honda Big Ruckus Solo & Sidecar Rig,
'08 Ural Retro, '10 Ural ST Solo
http://www.flickr.com/photo s/ivanrider/
Ivan Rider is offline   Reply With Quote
Old 03-23-2012, 05:37 AM   #3
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,182
+1- Ivan has great pics of his airhead rigs somewhere.....
This is my favorite subject, so excuse the long reply:
First,
http://www.russianiron.com/forums/in...howtopic=13923
Check out Vostok Motors- they have a shipment of Dnepr chairs and frames just arrived in CA.
There's another guy on EBay called Cold War Trophies that has Dnepr and Ural chair kits sometimes too.
I saw a steel Jupiter chair on the IBMWR site not so long ago. http://marketplace.ibmwr.org/
The United Sidecar Association has a For Sale section- http://www.sidecar.com/
Your local Craigslist is a source.
The Soviet chairs seem to be going for $1200-2000, so shop around.
http://advrider.com/forums/showthrea...492526&page=56
https://lh6.googleusercontent.com/-5...0/P2240954.JPG
In the Hacks Fleamarket section there was a sub-frame for sale- you'll need one of those. $400 was a good deal for that, BTW. They come up on the IBMWRA site too sometimes. Inmate BMWEuro (Chris) knows a source in Europe- I got my subframe from him. Perry's Sidecars in Texas has a setup for airheads, so does DMC.
I have a Dnepr chair on my R80/7- it's been the most fun I've had since I started riding.....
Plenty of room for a dog, too.
If you just want to get started, you can use a fork brace and wide bars and the steering is OK. You can switch to a leading link setup later- it's pricey, though. I have a tube style lower fork brace, ToasterTan upper clamp, and wide GS handlebars and I don't think the steering is hard at all, and that was only $200 total and easy to put back to original. A VW or junkyard damper is another $25.00. I have an old GSX1100 damper on mine and it's just enough to take the edge off. I can take my hands off the bars all the way down to about 10 MPH without any shake.
I did spend some dough to upgrade my brakes to duel disks, but I'm not sure it was entirely necessary. No brake on the car. I noticed that the Avon sidecar tire I put on the front improved the handling, and I put a cheapo enduro tire on the back with no problems, after the Metzlers that were on there wore out (they go quick!).
Point is, not counting the bike you could probably build an airhead rig for $2000, and I highly recommend it!
The ladies used to check me out...now they just keep an eye on me.
MotoJ screwed with this post 03-23-2012 at 06:13 AM
MotoJ is offline   Reply With Quote
Old 03-23-2012, 08:06 AM   #4
jaydmc
Oddometer: 1,056
Your bike will require a sub frame as the BMW frame tubing is very thin. What many people do is to either buy our Kenna frame with mounts and build thier own box and fender set up or we have had a few people go with our enduro sidecar, remove the seat and mount a dog kennel. The Kenna frame was designed to be able to ship it in several boxes Fed Ex to keep the cost down. The Kenna frame all of the mounting hardware and sub frames for your bike runs $2495, The Enduro with the mounts runs $3170. Our M72D would be my first choice for this $4995. If you want to go used and can find one a Sputnik would work well. A Velorex or spirit Eagle will also work just make sure you run a proper sub frame, we can supply the sub frame for most sidecars for your bike, Most are $675
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 03-23-2012, 09:19 AM   #5
NitroMax
NitroMax's Avatar
Oddometer: 682
My 90/6 with MZ/Superelastik sidecar
with subframe:
which I altered slightly.
Sidecar is light but with a stronger spring and some lead ( as in heavy metal lead ) under the seat it handles very nicely.
I altered a standard SuperElastik sway/torsionbar to fit the BMW setup
Bolts are for fitting purposes only, torsionbar is welded now.
The torsionbar makes a world of difference !! I've got some short movies of the hack without and with the torsionbar, I'll post them as soon as I've found them
Happy to take and send you pics of details if and when you need them !
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 03-23-2012, 10:22 AM   #6
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,182
[QUOTE/]
with subframe:
[/QUOTE]
that looks like my Piekert & Baus subframe. Where did you get it- or did you make it?
Very cool rig, BTW!
Old 03-23-2012, 10:26 AM   #7
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 531
On my way!!
Everyone,
Thanks for the respones and info.
MotoJ - your information is great I have to be on a budget build and if I can get into it for $2k I will be good.
NitroMax - your pictures of the subframe are great gives me exactly what I need
Is there a Sidecar specific Flea -Market or is it the general Flea Market??
"In the Hacks Fleamarket section there was a sub-frame for sale- you'll need one of those. $400 was a good deal for that, BTW. They come up on the IBMWRA site too sometimes. Inmate BMWEuro (Chris) knows a source in Europe- I got my subframe from him. Perry's Sidecars in Texas has a setup for airheads, so does DMC."
Looking for this used subframe.
Also to Jay DMC I see you guys have subframes new - Thanks for your post and I see you support / input on a lot of these threads.
Thanks to All - I am just getting started -
Dnepr car looks like a great setup. More research!!!
Old 03-23-2012, 10:33 AM   #8
NitroMax
NitroMax's Avatar
Oddometer: 682
For sale here in the Netherlands:
CLICK
Old 03-23-2012, 11:06 AM   #9
Biebs OP
BMW Airhead
Biebs's Avatar
Oddometer: 531
CLICK
Whoa!! That looks even better.
Jay at DMC do you have pictures on the subframe - looked at the DMC website no pictures of subframes.
Old 03-23-2012, 11:22 AM   #10
jaydmc
Oddometer: 1,056
Email me and I will send photo's of the sub frame. Our sub frame gives you all 4 mounting points now just the lowers.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jay@dmcsidecars.com
Old 03-23-2012, 12:10 PM   #11
BeeMaa
Hack Pilot
BeeMaa's Avatar
Oddometer: 1,098
Biebs - Welcome to the Asylum.
I would agree with Ivan Rider on not going too light.
A little bit of weight isn't gonna hurt at all.
Good luck with the build and keep us posted.
Cheers.
Eric B
'06 R12GSA/Hack & '10 R12GSA
An armed society is a polite society. Manners are good when one may have to back up his acts with his life. Robert A. Heinlein
BeeMaa is offline   Reply With Quote
Old 03-23-2012, 12:49 PM   #12
hopscotching
On the road...
hopscotching's Avatar
Oddometer: 256
For the the bees knees of airhead subframes
Contact Chris @ http://boxermetal.com/ or pm him "bmweuro"
We used this subframe on my hack
1976 BMW with Ural sidecar
In Dog Beers I've Only Had One!
Ride Report
http://advrider.com/forums/showthread.php?t=901273
Mexico starts on this page
http://advrider.com/forums/showthrea...1#post23188421
hopscotching screwed with this post 03-23-2012 at 12:51 PM Reason: more pics
hopscotching is offline   Reply With Quote
Old 03-23-2012, 02:34 PM   #13
NitroMax
NitroMax's Avatar
Oddometer: 682
Very cool rig, BTW!
Sorry MotoJ, missed your post. I bought it from a guy that didn't use it anymore.
No brandname on it.
Thanks for the compliment !
Old 03-23-2012, 02:37 PM   #14
NitroMax
NitroMax's Avatar
Oddometer: 682
Yes, great subframe ! I'm working on making the mounts for the crossover to the left side of the frame too. It will fit with the battery in place.
I also have a strip of metal ready to weld to the lower clamp near the footrest to connect to the clamp just beneath the saddle for extra strength.
Old 03-23-2012, 07:32 PM   #15
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,182
Everyone,
Hi Biebs,
That subframe sold quick. I was just using that as an illustration. But they do come up if you keep your eyes peeled. Look for the Sticky up top of the Hacks Forum page, and keep perusing the other sites I mentioned.
http://advrider.com/forums/showthread.php?t=492526
If you wanted to fab your own, you can buy just the ball mounts from Blue Moon Cycle or from Oldtimers Garage in Poland. Blue Moon sells Steib ones and OldTimer cuts them right off a salvage Dnepr frame. Then you would have to weld up your own subframe. I like the ball and jaw Dnepr type mounts because it's really easy to get the car dismounted without fooling with clevises. They're not as adjustable though.
You'll need the struts too, if they don't come with the car. You can find those on EBay no problem.
This subframe that NitroMax posted is the ideal type if you want to keep the ball and jaw mounts on a Dnepr or earlier Ural car:
http://motoren.marktplaats.nl/onderd...kert-copy.html
Feel free top PM me if you want. I have loads of pics from my own build. The ones in my thread are only the tip of the iceberg.
http://www.advrider.com/forums/showthread.php?t=713860
MotoJ screwed with this post 03-23-2012 at 07:38 PM
Times are GMT -7.   It's 10:45 AM.
