Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 02-27-2012, 05:11 PM   #91
pampaX OP
pampaX's Avatar
Oddometer: 354
and this arrived some time afterwards ... good service for BS motorcycles on germany
you can almost see the content here
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX screwed with this post 02-27-2012 at 05:55 PM
pampaX is offline   Reply With Quote
Old 02-27-2012, 05:13 PM   #92
pampaX OP
pampaX's Avatar
Oddometer: 354
voila
the content looked very good
they're adjustable and foldable and extensible
Old 02-27-2012, 05:14 PM   #93
pampaX OP
pampaX's Avatar
Oddometer: 354
brake lever installed
Old 03-13-2012, 01:48 AM   #94
pampaX OP
pampaX's Avatar
Oddometer: 354
and after over a year - fully painted
and put BM badge and my stickers
Old 03-27-2012, 01:03 AM   #95
pampaX OP
pampaX's Avatar
Oddometer: 354
Vario benelli Clutch lever - not perfect fit but close enough
So the problem with the clutch lever is that the sleeve it comes with is too small for the bolt on the bike
without the sleeve is too big. Also note the original sleeve is not good enough cause the new lever is thicker
Here pic of both sleeves and the bolt
the bolt doesn't go through the new sleeve
solution is to build a thin wall sleeve with same diameter and same height of the lever
haven't got a pic at hand 4 mine tho
Old 03-27-2012, 12:43 PM   #96
imeny
imeny's Avatar
Oddometer: 98
Thanks for the info!!!!
imeny is offline   Reply With Quote
Old 04-26-2012, 08:14 PM   #97
pampaX OP
pampaX's Avatar
Oddometer: 354
Solid Battery Li-iron
A week or so ago my battery left me stranded ... again .. and decided to change the battery for one of these
according to my research it seems to be a good one.
The research was pointed out by alpi here http://www.advrider.com/forums/showp...postcount=1568
well today it arrived so looking forward to try it out. It certainly looks very very small and light
Old 12-22-2012, 04:49 PM   #98
etnguppys
etnguppys's Avatar
Oddometer: 8
I like the looks of the front fender, Make, Model?
etnguppys is offline   Reply With Quote
Old 12-22-2012, 09:24 PM   #99
Padmei
enamoured
Oddometer: 2,489
KLR 650 08 & later model
Padmei is offline   Reply With Quote
Old 12-26-2012, 05:18 PM   #100
pampaX OP
pampaX's Avatar
Oddometer: 354
Its actually a Ktm front fender, bought in Oz but I believe you can get them here. I'll check brand when I get back home
Old 01-01-2013, 11:24 AM   #101
pampaX OP
pampaX's Avatar
Oddometer: 354
Redoing the bracket, disassemble
After a long time after doing first draft bracket I'm now attempting to do an improved version .
Lets start with disassemble
First the bracket out of the bike
The weight of the whole unit
Here having removed the lateral fairing holder, i.e. the part I will start with
Some rust forming on one of the lights for some reason (besides the fact that water is hitting it the other one is not quite as bad)
The rubber mounted light holder bolt
Another take at the main bones of the tower, now without anything else
So what I'm trying to do is
1. to build one main bracket bone like the ones above this time tidier, also lower. The reason to be lower is I'm going to build a separate part to hold dash, road book holder and GPS holder ....
2. reuse the other bits, like fairing holder and indicator even maybe the dash holder
3. allocate space for the fuse box
4. maybe some space for tools
5. devise a way to cover water coming from the front wheel
Old 01-01-2013, 11:41 AM   #102
pampaX OP
pampaX's Avatar
Oddometer: 354
Redoing the bracket, build step 1 main bone cut
So clean out of laser cutter
put main bolts and verify it fits
closer
so far so good, next drill rest of the holes and verify it goes together otherwise redo
Old 02-24-2013, 04:37 PM   #103
Bli55
Ev.
Oddometer: 70
pampaX, loving your thread!!
How about some more laser-cutting goodness? And in more manageable screen size?
Bli55 is offline   Reply With Quote
Old 02-25-2013, 01:11 AM   #104
pampaX OP
pampaX's Avatar
Oddometer: 354
Thanks for your comments
I have a few pics of all put together, version #3 that I need to filter and make available ... will get to do it soon ...
the screen size its not bad some people believe it gets on the way however it doesn't happen. Only problem I have is on rough offroad it may come close to your chest . I want to build a low screen for that sort of application, but need to do more mods to the tower so it doesn't protrude that much if I had a lower screen or it can be moved ...
On the next video you can see one of the problems with the tower as it is now although the wiring seems much better now
Old 02-25-2013, 11:45 AM   #105
aslan
Aslan
aslan's Avatar
Oddometer: 285
Send a message via Skype™ to aslan
kewl vid - top riding skills
excellent little vid Pablo - riding the 'Pram Track' vicariously with you - enjoyable - I'm reminded how much these tracks change with the vagaries of the elements - have to pinch myself to think that I once took an 1150GS through there - thanks for posting
aslan is offline   Reply With Quote
Times are GMT -7.   It's 11:39 PM.
