Old 04-01-2012, 11:43 AM   #11
Charliedog43
Charliedog43's Avatar
Oddometer: 20
Turn signal connectors
Just a thought, if you don't have a wiring diagram, the connector with the green wire is the connector for the right turn signal-with the black/white stripe wire being the ground. The other connector, obviously, is for the left turn signal. The rear connectors should be located in a vinyl wrapped pack above the battery-the same two connectors, the same color coding. And parts for 1996 on model years should work with no problems-different colors for the plastic maybe. Parts from model year 1995 and older might, or might not, work-no guarantees. Good luck.
Larry aka CharlieDog
Bristol, TN
Charliedog43 is offline   Reply With Quote
Times are GMT -7.   It's 09:59 PM.
