Old 04-04-2012, 08:24 PM   #796
duck
duck's Avatar
Oddometer: 10,403
Originally Posted by blakey View Post
When replacing fork oil in the above mentioned bike, make sure you know the difference between ATF and brake fluid.
I'll bet it stops really well.
duck is offline   Reply With Quote
Old 04-06-2012, 04:19 AM   #797
husqvarna
Oddometer: 139
Torqueing backwards
When torqueing the flywheel on an 1980 something Husky on its taper with a left hand thread make sure that the aforementioned torque wrench works on left hand threads (click type). Otherwise it's an expensive split on the flywheel. Luckily 1 litre of Red Heart rum to a local hoarder of all things Husky rectified the matter (thanks Mike). Stupid is as stupid does.
husqvarna is offline   Reply With Quote
Old 04-06-2012, 11:05 AM   #798
Welshman
B.U.F.F.
Welshman's Avatar
Oddometer: 1,213
Eiiish Red Heart Rum, you is in Darkest Efrika
Welshman is online now   Reply With Quote
Old 04-07-2012, 12:20 AM   #799
tgeliot
Topher
Oddometer: 1,361
There are torque wrenches that work in only one direction?
Topher
1989 Transalproject. 2008 Suzuki V-Strom 650
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Old 04-07-2012, 09:00 AM   #800
MiteyF
MiteyF's Avatar
Oddometer: 2,055
Fixed my picture...
http://dl.dropbox.com/u/70871541/201...2014.21.13.jpg
NOTE:
not for the squeemish
JJ
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
johnjen screwed with this post 04-07-2012 at 01:17 PM
MiteyF is offline   Reply With Quote
Old 04-07-2012, 06:38 PM   #801
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,982
Originally Posted by MiteyF View Post
Fixed my picture...
NOTE:
JJ
JJ, I hope this is the before treatment photo. You had this stitched and other care needed?
---Albert Einstein
disston is online now   Reply With Quote
Old 04-07-2012, 07:39 PM   #802
MiteyF
MiteyF's Avatar
Oddometer: 2,055
Yes, surgery was Thursday. Tendons reconnected and stitched up
Sorry JJ!
Old 04-08-2012, 04:50 AM   #803
Derailleur
Oddometer: 21
When soldering connections onto the switch which has replaced your ignition be sure to put the protective rubber boot back on the switch before you solder, or at least before you leave to cross the city, otherwise said switch with exposed contacts will touch the tank and short out your ignition circuit blowing the fuse, multiple times.
Good thing I had a stock of spare fuses with me, although now down to 7.5A instead of 10A as I ran through the stock of 10A. It is now all insulated up.
Obligatory Bike list
2008 cbr 125 daily beater, tourer, track bike, 1986 vt 1100sc(paint it & sold), 1982 cb450sc(done & done, love drivers dontcha)
Derailleur is offline   Reply With Quote
Old 04-12-2012, 01:25 PM   #804
syntec4
syntec4's Avatar
Oddometer: 1,421
When the can of Expanding foam you are using to repair the insulation in a panel in the workshop keeps on getting blocked up. Do not take said can outside in frustration, stand it on top a one of the Jeeps you have awaiting restoration and shoot it 'to show that F*((r who's boss. Satisfying as it was pulling the trigger, the resulting nearly full can of foam does go a very long way. A very long way.. Whilst you're cleaning it off the outside walls of the barn, and compressor and, we'll you get the idea, you will have plenty of time to re-consider your decision to shoot aforementioned can.
My Smugmug
syntec4 is offline   Reply With Quote
Old 04-12-2012, 06:58 PM   #805
Marco Moto
Voyager
Marco Moto's Avatar
Oddometer: 1,297
^^^ Dood! ^^^
-Marco Moto
Marco Moto is offline   Reply With Quote
Old 04-13-2012, 07:27 AM   #806
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,410
Originally Posted by syntec4 View Post
Maroon!
(do it again and post video )
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 04-14-2012, 11:27 PM   #807
Alton
Oddometer: 293
Don't skimp and buy OSB when you should be using particle board, melamine, or plywood. 4 coats of primer later you know exactly why the particle board or melamine was a better choice, even if the OSB was 60% the cost of the cheapest of the others.
Alton is offline   Reply With Quote
Old 04-15-2012, 02:07 PM   #808
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,391
Note to self;
If you fall for the KLR pricing of the vaneer foamed back no-glue wood flooring from Manards. Buy carpet tape. Cut 1/2 the tounge off the long side. And install as directions show, but add a strip of carpet tape under the "groove" side as you lay it down.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 04-15-2012, 04:10 PM   #809
tgeliot
Topher
Oddometer: 1,361
What application are you thinking of? If it's somewhere where appearance matters and strength doesn't, then I agree, particle board or melamine or even high quality plywood would be better than OSB. But if you care about strength or resistance to occasional moisture, particle board is a poor choice.
Topher
Old 04-16-2012, 03:23 AM   #810
K0m4
K0m4's Avatar
Oddometer: 553
After having driven through the rain to the dock where your boat is moored, don't leave the bike for a few days wet under a waterproof cover in a marine environment while you're out enjoying the sun that finally showed itself.. Your cover will turn into a steam sauna and the virtually new chain will start to rust instantanously, and degrade to the point of no salvation.
Suzuki DL1000 -07 || Suzuki TL 1000 S -99 || Suzuki GSX 1100 E -82
Introduction/ride report: what's in an adventure?
K0m4 is offline   Reply With Quote
Times are GMT -7.   It's 10:19 PM.
