Old 04-06-2012, 01:48 PM   #1
HannibalSmith OP
HannibalSmith's Avatar
Oddometer: 35
1200S Suspension on a 95' Dyna....
So because I have to do everything the hard way.....
I've got 1200S suspension (adjustable MOCO stuff) has anyone else attempted this?
Which Caliper would you use?
Special thanks goes out to John Wesley! You are the man!
(Mods please move this if it's not in the right spot, many thanks.)
HannibalSmith is offline   Reply With Quote
Old 04-06-2012, 02:36 PM   #2
Motomedic
Motomedic's Avatar
Oddometer: 1,827
A) there might some compatibility issues with the axle/wheel- Sportster triple clamps are much narrower than Dynas, and the brake rotor/caliper relationship is critical.
B) Use the older Hayes calipers, whose mounts match the forks.....
Feike
Said James to Red Molly, Now Nortons and Greeves and Indians won't do- they don't have a soul like a Vincent '52
Motomedic is online now   Reply With Quote
Old 04-06-2012, 03:16 PM   #3
HannibalSmith OP
Oddometer: 35
Thanks for the input!
Guess I should have mentioned, my bike is a Super Glide which has the Narrow Glide front end. This should be a direct fit. I'm uncertain of the difference in weight though. Both calipers are 2 pots and mount the same. The only difference is where the line goes in.......
Old 04-07-2012, 04:16 PM   #4
HannibalSmith OP
Oddometer: 35
Update
So I mounted the rear shocks. Apparently the Dyna is quite a bit heavier in the rear as it was slammed with them on the hardest settings....
Comparison-
On the bike-
So guess I need to send them off!
Old 05-20-2012, 05:34 AM   #5
HannibalSmith OP
Oddometer: 35
And wer're done!
I'll figure out the rear when time allows. It handles great!
Old 05-21-2012, 12:05 AM   #6
AZbiker
Crunkin' with crackers
AZbiker's Avatar
Oddometer: 6,910
Negative.
A narrow glide is a narrrow glide is a narrow glide.
Spring rates might be a little low--going to a Dyna suspension on a Sportster is a pretty typical upgrade for us larger guys.
If the bike bottoms out a lot, OP may want to consider FXDX suspension instead, or Race Tech.
rubber side down,
derek
http://azbiker.smugmug.com
Got SmugMug? If not, save some cash and use my code: McYdbycdcvM5Q
AZbiker is offline   Reply With Quote
Old 05-21-2012, 04:29 AM   #7
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 5,584
It isn't just the weight that is compressing the shocks (though it is a factor) , it is the leverage that the different mounting position is applying to them.
Cool setup by the way.
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My HD Scram-ster build
Help Save a Pit-Bull
Ginger Beard screwed with this post 05-21-2012 at 05:57 AM
Ginger Beard is offline   Reply With Quote
Old 05-21-2012, 05:08 AM   #8
Mattbastard
Lazy ass
Mattbastard's Avatar
Oddometer: 1,584
Originally Posted by AZbiker View Post
Negative.
BAM!
Dyna's are about 150lbs more than that Sporty.
Mattbastard is offline   Reply With Quote
Old 05-21-2012, 10:28 AM   #9
AZbiker
AZbiker's Avatar
Oddometer: 6,910
Hannibal--FXDX shocks are pretty nice too. You should be able to find some on eBay because some )(*&()% took them off to put on 10" 412's.
rubber side down,
derek
Old 07-17-2012, 07:27 PM   #10
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,306
Send a message via AIM to johnwesley
sorry I didn't see this earlier. you can just get springs for the rear shocks. It is a leverage issue the sport mounts back at the axle. Same for the front some heavier springs and you should be good to go.
the blacked out forks look good
here is how the rear shocks mounted
johnwesley is offline   Reply With Quote
Old 07-17-2012, 09:08 PM   #11
malott442
Loud, yet refreshing
malott442's Avatar
Oddometer: 390
thread title vs. body. So disappointing. Was expecting diabolical carnage! (BMW 1200s)
malott442 is offline   Reply With Quote
Times are GMT -7.   It's 11:15 PM.
