Old 04-06-2012, 06:18 PM   #1411
marguyo
marguyo's Avatar
Oddometer: 32
versys adventure
http://ridaventure.ca/viewtopic.php?...rsys+adventure
sorry its my 1 er post and i not perfect in english , this is my bike
marguyo is offline   Reply With Quote
Old 04-06-2012, 07:00 PM   #1412
jdrocks OP
Gravel Runner
Oddometer: 4,499
mario, the photos are blocked in your link. your buddies sure like your bike, email me some photos.
jdrocks is online now   Reply With Quote
Old 04-06-2012, 07:18 PM   #1413
marguyo
marguyo's Avatar
Oddometer: 32
i send to you many picture ,enjoy ...
thank you for your help
Old 04-06-2012, 09:03 PM   #1414
DRjoe
DRjoe's Avatar
Oddometer: 5,151
Post them up here jd so we can all dream of our own
Old 04-07-2012, 04:48 AM   #1415
jdrocks OP
Gravel Runner
Oddometer: 4,499
will do. have an all day ride today, but tonight or tomorrow you'll see Mario's spoke wheel rat Versys. this Quebec rider has been very busy.
Old 04-07-2012, 08:22 AM   #1416
tragerbon
tragerbon's Avatar
Oddometer: 131
Thats sweet, really like that the original fairing set up is used.
Hello Kawasaki...can you hear us now !
QUOTE : marguyo
my mount for a 2012 kawa versys 2007.20 000 km, 34 inch seat height, 9in 3/4 ride height, weight approx 440 lbs
Autonomy 400 km test without too misaire, change rear wheel 18 inch, 21 inch suspention av drz 400 e, sw Motrec crash bar, luggage givi suport, home made aluminum suitcase 11 lbs for 38 liter each, LIFTED hand guard for the wind, carry handle heating, released 12 volt dash, 2 denali protection rad home made, home made skid plate,
roughly resembles a ca ca!
Bike free : (
tragerbon is offline   Reply With Quote
Old 04-07-2012, 04:55 PM   #1417
jdrocks OP
Gravel Runner
Oddometer: 4,499
Originally Posted by Balkan Boy View Post
I was curious to see another ADVersys so here are Marguyo's pictures.
I'd like to know from witch bike those wheels and forks came.
I'm getting closer and closer to doing something similar to my Versys.
I'm fed up with other motorists and cops on the main roads.
Cheers.
geez, you dudes are an impatient bunch. if i understand Mario correctly, he built his bike, assisted on another, and is ready to start a third mid month.
Mario says via PM that he watched the ER6C and V649HP builds, sold his Buell, bought the Versys and got to work. he did a great job, the man has skills.
as for the rest of you still on the sidelines, this guy is ready to start his third bike.
Old 04-07-2012, 05:15 PM   #1418
jdrocks OP
Gravel Runner
Oddometer: 4,499
one thing that Mario requested was that any minor issues with the French to English translation be cleaned up, oh well, tragerbon only speaks the corrupted Tejas version of spanglish and didn't get that memo. i guess everyone understands what Mario fabricated himself for this build.
i've said previously that the easiest way to go big on the suspension is to use the 49mm Showas (DRZ400) in the Versys clamps, keep the rest of the front end. several builders have said they plan to do this, but Mario is the first to come back with a photo.
if i understand Mario, the wheels are DRZ (18/21). maybe he can clarify on the source.
plenty of work went into this bike, nicely done.
QUOTE : marguyo
Old 04-07-2012, 10:51 PM   #1419
marguyo
marguyo's Avatar
Oddometer: 32
yes this is rear wheel 18 in drz stock with adaptor for sproket and disk breake,front is same adaptor for fit drz fork in stock versys clam,i made a long bolt for wheel ,and a shim for rotor brake and spacer ,i made too and adaptor for fix to lower triple clam a fender of my 07 klr (see on google *klr africa express* i built last year is lock same zebra)
i made skide plate 100% home made in alu 1/8 plate and fix on crash bar with clam
85 % built in solo, only metal work is made by a shop with my blue print .i change with a man change for change buell ulysse 06 48000 km for versys 07 15000 km .my firts fit i change only 2 wheels ;front is 100% made 21 in wheel with many parts for fit in stock fork and use only 1 caliper brake,rear made too 100% 17in wheel fit with no cushion same of mx bike with stock disk brake,
is run great ,but only 5.5 on fork travel is low for hard use in trail ,cranking adjustment to max is ok
after i made this bike and finish last week
15 april 2012 am start and other project bike for a friend , i remove front for change for drz front fork same of my bike rear stay 17 in mx wheel and fit crash bar and skid plate ,and made too side case in 1/16 alu with braket for fit on givi rack
probaly the front wheel a sale with all braket for a bolt on kit ,the price are not fix today
a post 4 pict at jd rock for this set up
in french i little bit better
all have two wheels which deserves to be run
Old 04-08-2012, 07:38 AM   #1420
2fast4u
Oddometer: 747
Marguyo's bike is pretty NICE!! What's cool about these build's is anything goes. I put a set of crf 450 wheels on my build first but was worried about the front tire hitting the bottom triple tree so stuck with the ninja wheels with a tall fat tire.
Took my bike for a short test ride (No front brake, throttle cables to short,no grips, just couldn't wait) and i think it's going to work out for my needs just fine. Hope to have it in the wind by the end of the month.
2fast4u is online now   Reply With Quote
Old 04-08-2012, 07:45 AM   #1421
jdrocks OP
Gravel Runner
Oddometer: 4,499
your english is fine, everyone can understand what you're saying, no apology necessary. just get your photo hosting set up and your can directly include your photos.
i think you should be thinking about a cush hub rear wheel setup. there is an aftermarket DRZ400 cush hub available, and also on the Japan spec DRZ model...or else just adapt a different wheel like the DR650 rear.
what is your cost in Quebec (USD) to machine the 52mm to 49mm adapters for the lower Versys fork clamp? these...
mine were machined with a self trimming/self positioning flange on top and slotted at the clamp pinch location to assure concentric clamping. were yours done the same way?
i've been asked several times, including recently, about the front 20mm axel, it requires an odd length when using the DRZ400 forks. rather than search the world for a manufactured axel, i used the high tensile 20mm swingarm bolt from the Versys/Ninja and threaded it to the correct length, then cut it off. easy and cheap. it still needs a sleeve for the right side, but you can find one of those.
post those zebra KLR photos in "thumpers", that will cause a stir. looks like you did a knockoff of the Expedition soft pannier mount.
Old 04-08-2012, 07:54 AM   #1422
jdrocks OP
Gravel Runner
Oddometer: 4,499
yup, anything goes, pick your flavor.
the ER6 builders need to remember to pick up a set of the longer Versys cables, both throttle and clutch. strangely the ER6 clutch cable is of larger diameter than the Versys cable, helping to explain why the Versys cable has a higher failure rate.
i've had mine out mid build without brakes too. your resistance fades away when it gets to a certain point, ya just have to get on and try it out.
Old 04-08-2012, 09:29 AM   #1423
marguyo
marguyo's Avatar
Oddometer: 32
for shim 49 at 52 mm i use same of your set and made .5 mm shim for up for 2 set i pay 100 $ ,for bolt a made a custom bolt same at drz with 3/4 in more long in center and oposit at the tread 3/4 in more long too
for put many pict tonight i open and accompt in photo bucket and put all picture of my parts
after diner a go to a small run ,the temp out side is little bit cool 2 deg celsius only and snow falling too
marguyo screwed with this post 04-08-2012 at 02:13 PM
Old 04-08-2012, 09:40 AM   #1424
donny662
donny662's Avatar
Oddometer: 373
A cush hub alternative would be a sprocket from Kush Sprockets. I've never used a Kush sprocket, but it looks like a neat alternative.
https://kushsprockets.3dcartstores.c...cket_p_67.html
Calvin: I think people worry too much about the little things. All they do is make themselves unhappy that way. Why get an ulcer over things that don't really matter?
Hobbes: Like that book report you're supposed to be writing now on the book you haven't read?
Calvin: Exactly. Case in point.
donny662 is offline   Reply With Quote
Old 04-08-2012, 01:57 PM   #1425
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,710
Originally Posted by pjm204 View Post
I only have 2 issues with that suggestion. 1, where have you found a strut spring compressor for a car that will fit between the coils? 2, I know I tried using the harbor freight one on a 350lb KLR spring and the tool failed, this spring is over double that spring rate.
I'm too young and too beautiful to die.
The one shop I found that said they will do it wants at least $50
Heavy duty zip/cable ties.....and that's as far as I am going to on this "loaded" topic.
S.t.t.G. is offline   Reply With Quote
Times are GMT -7.   It's 12:09 PM.
