Old 04-08-2012, 12:05 PM   #3046
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,679
Originally Posted by dirtdiver View Post
Gents, I just turned over 8K miles on my 530 while riding with DeepSea down in baja.
At the end of our trip I noticed that my front sprocket is looking wet from oil. Any ideas?
DD
http://www.dirttricks.com/ktm_dome_washer.htm
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Old 04-08-2012, 12:31 PM   #3047
dirtdiver
Oddometer: 2,039
Originally Posted by bigborefan View Post
Is that as easy as removing the nut that holds on the sprocket and replacing the washer immediately underneath?? That seems too easy.
DD
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 04-08-2012, 12:37 PM   #3048
dirtdiver
Oddometer: 2,039
Will the tranny oil leak out when I pull that bolt? DD
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Old 04-08-2012, 01:14 PM   #3049
jesusgatos
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,405
DD
yes
no
jesusgatos is offline   Reply With Quote
Old 04-08-2012, 01:49 PM   #3050
dirtdiver
Oddometer: 2,039
Thanks!!. You guys are the best!
DD
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Old 04-08-2012, 07:15 PM   #3051
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
I noticed this today after riding my 450 XCRW some. Is this normal? It doesn't look like there should be a screw in that hole but could be. I'm new to KTM and I'm worried about this so some help would be very heart warming for me right now because I just got this bike and really don't want to have to break her down already.
Image and video hosting by TinyPic
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 04-08-2012, 09:24 PM   #3052
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,599
That's the drain hole for the spark plug socket well. It's supposed to be like that so water that gets on the head can drain instead of pooling around the sparkplug.
Old 04-08-2012, 09:39 PM   #3053
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,865
Is that liquid water, oil or fuel?
If it is water it is nothing to worry about (could just be there from its last wash) , fuel could mean a lose spark plug, and oil could mean the tappit cover is leaking into the spark plug hole some how (OK so I'm grasping at straws with the last one, I doubt it is oil)...
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 04-09-2012, 07:22 AM   #3054
antpatterson
XR650L_High_Runner
Oddometer: 378
Well it is the color or oil but if it is water why would it be black? Is this something I should be concerned about? Should I just replace the spark plug?
XR80r
2008 XCRW450
Old 04-09-2012, 08:49 AM   #3055
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,679
I am a 2 stroke guy. My four stroke philosophy is to keep throwing oil at it, then ride it till it blows, then you at least know what to fix, or your mechanic does....
Old 04-09-2012, 09:46 AM   #3056
Subaru297
Oddometer: 118
You should check that the spark plug is not loose. Make sure it is tight and then clean off the gunk and ride it again. If it leaks again and you are sure it's not water getting in the spark plug cavity then you might want to check for oil leaks from within the valve cover.
Cheers
Subaru297 is offline   Reply With Quote
Old 04-09-2012, 04:40 PM   #3057
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 914
Put my new Dirt Tricks CCT in last night hoping it would cure the ticking noise. It's still there and at this point I have no idea what it could be. I decided I'll live with it for now and just ride it. So today I took it out for a spin and ended up like this.
In case you were wondering, getting it stuck in a creek did not cure the ticking noise.
onetravdown is offline   Reply With Quote
Old 04-09-2012, 09:24 PM   #3058
mtrcycllvr
Nerdly pseudo adventurer.
mtrcycllvr's Avatar
Oddometer: 185
Putting a dent in a plastic gas tank?
So, this is probably the wrong SPECIFIC thread, but since the bike and frame is an '08 530, it seems as good as any.
I bought one of the very nice safari mondo tanker gas tanks, and it's served me pretty well over the years. Sure as heck it's helped many of my friends as much as myself..
My problem is that if I spend too much time in tight technical work or, say, stopped in line with the buds I end up boiling over.
Anyway, I finally picked up a fan kit a few weeks ago and got a catchtank on order. The fan part installed in moments and looks very nice..
You know where this is going, right? With the very nice fan kit installed, the stock tank fits fine, and I can GET the big tank on, but it's not right.. It really stresses the radiator forward and the wear point is the fan motor and the WIRING to the fan motor.
Everyone I talk to says, just heat the tank up till you can reform it a bit.. Okay - who REALLY knows how to do that? What material is the tank, technically and whats the pliable working temperature range I should be aiming for?
Is it likely I can get 10-12 square inches up to a working temperature that would let me permanently "dent" the material with a 1000 watt heat gun?
I have an IR temp meter with the little laser pointer, which is pretty cool if you ask me... Anyway, I'm confident I can accurately measure the surface temp at least.. But I have no idea what sort of working temperatures I should be aiming for and I'm not so confident a 1000 watt heat gun can get that much surface area into whatever the best working temperature might be.
I need to "depress" this area:
....about 1/2 to 3/4 inch - probably doesn't help to have the corner transition right there, but it's such a large radius that I don't think it'll be a big deal..
So, anyone more experienced than me have any thoughts or advice?
Thanks in advance!
-ET-
1987 Yamaha Venture XVZ-13 (A project...) Wanted, one wrecked VMAX.. PM me!
2001 KTM-300EXC (Sold for cheap, and SO regretting it!!!)
1999 Honda VTR-1000 (the pavement weapon and ass beater..)
2002 KTM-LC4 640 (Eats gravel roads for breakfast..)
2008 KTM-530 EXC-R (The 'sexy beast')
mtrcycllvr is offline   Reply With Quote
Old 04-09-2012, 09:59 PM   #3059
ian408
Oh?
ian408's Avatar
Oddometer: 14,584
I have the '09 with the same tank and fan. So far, no rubbing.
However, if I was going to heat it up, I would use a heat gun and hold it 8 or 10 inches away and slowly warm the area up then when it's hot enough, dimple it.
Now you got me worried--I should check mine for rubbing
ian408 is offline   Reply With Quote
Old 04-09-2012, 10:14 PM   #3060
mtrcycllvr
mtrcycllvr's Avatar
Oddometer: 185
Huh.. Well, mine clearly interferes - wonder if the tank guys modified their mold to make room?
Still looking for what sort of plastic it really is and what sort of working temp I'm looking for - I'm not quite prepared to just heat it up and push till I mistaken shove my thumb through it..
-ET-
Times are GMT -7.   It's 06:38 AM.
