Old 04-08-2012, 06:13 AM   #1
mpatch OP
Oddometer: 987
motionx GPS users???
anybody else notice that once you get some larger maps downloaded that the memory used goes up almost 3x what it should be? The app size is about 30mb and I have downloaded about 170mb in maps yet the app is using 500mb of memory when it should be closer to 200mb.
mpatch is offline   Reply With Quote
Old 04-08-2012, 06:43 AM   #2
EmmEff
Oddometer: 1,728
Did you try clearing the cache completely? I suspect you have remnant data.
2001 F650GS Dakar
2008 DR-Z 400S
EmmEff is offline   Reply With Quote
Old 04-08-2012, 08:06 AM   #3
mpatch OP
Oddometer: 987
yes I have tried everything and I have been in contact with MotionX support and they have noticed the same anamoly with larger maps
Old 04-08-2012, 10:00 AM   #4
EmmEff
Oddometer: 1,728
Interesting... I guess I haven't used it enough to experience this.
2001 F650GS Dakar
2008 DR-Z 400S
Old 04-08-2012, 10:22 AM   #5
mpatch OP
Oddometer: 987
Seems that once you break the 100 mb or so size this happens
Old 04-08-2012, 02:19 PM   #6
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,681
This isn't to do with Apple's new Retina display is it? I fear my 16 gig 4S may soon be running out of space as all my apps update to Retina versions.
Old 04-08-2012, 03:26 PM   #7
mpatch OP
Oddometer: 987
No I'm using the iPhone 4. I have been in contact with motionx for a couple of weeks about this issue and they thought the last update fixed the issue, it didnt I was just checking to see if anybody else had noticed.
Old 04-08-2012, 11:07 PM   #8
abhibeckert
abhibeckert's Avatar
Oddometer: 1,700
That's interesting!
According to the MotionX app, I have about 510MB of downloaded tiles, and 61MB in the map cache. But Settings -> General -> Usage reports 1.5GB of storage by MotionX.
I'll be sending them an email for sure, the more vocal we are the more likely they are to fix it.
abhibeckert is offline   Reply With Quote
Old 04-09-2012, 02:23 PM   #9
abhibeckert
Oddometer: 1,700
MotionX support responded to my email overnight:
Hi Abhi,
Thank you for contacting the MotionX team. Our team is aware of the issue you described, we believe we have a fix in place for this issue in the most recent version of MotionX GPS.
After updating the app please launch the app and fully close the app about 5 times. To fully close an app, double click the home button to open the multitasking tray. Then, press and hold an app icon until they begin to shake. Touch the red button that will appear on the app icon and it will close. (Make sure not to do this on the home screen, just the multitasking tray, or you will delete the app entirely). After you have opened and closed the app about 5 times please have a look at the size of the App, does it still look bloated?
If it does, can you please download the free computer program iExlorer http://www.macroplant.com/iexplorer/
Once you have the program on your computer connection your iPhone to the computer via USB and open iExplorer. Select Apps->MotionX GPS. Now please look at the Library, and then to your Caches Folder. Do you see a large file in this folder?
I look forward to hearing from you.
I have run through their fully-close-and-relaunch-five-times process, and it restored about 100MB of the extra disk space.
Now I'm trying to use iExplorer to find where the extra disk space is... but it's incredibly slow going (iExplorer sucks!). I'll keep everyone updated. :-)
Old 04-09-2012, 02:32 PM   #10
mpatch OP
Oddometer: 987
They also had me use iexplorer and it kept crashing on me
Old 04-09-2012, 03:16 PM   #11
KiloBravo
Armchair Adventurer
Oddometer: 771
My usage is opposite GPS-Drive is largest, have voice direction if that makes any difference.
Looking forward to your posted answers from MotionX.
KiloBravo is offline   Reply With Quote
Old 04-09-2012, 03:54 PM   #12
mpatch OP
Oddometer: 987
GPS drive will let you store up to 2 GB of maps. Clear your map storage and it should drop back to normal. To check how much you have cached got to menu then settings then to map settings an look at storage used and if you want you can clear stored maps and change how much you want memory you want to use to store maps.
Old 04-09-2012, 05:26 PM   #13
KiloBravo
Armchair Adventurer
Oddometer: 771
Storage used 130.1 cleared checked General > Usage > GPS Drive 124MB now.
Thanks.
Old 04-09-2012, 05:43 PM   #14
mpatch OP
Oddometer: 987
Thanks.
That still seems pretty large considering the app is only like 20mb. Let me play with mine for a min and see if it's an issue with both of the motionx apps.
Old 04-09-2012, 05:52 PM   #15
EmmEff
Oddometer: 1,728
But the size of the app is irrelevant. It's the size of the maps downloaded and cached that constitutes the bulk of the reported size.
2001 F650GS Dakar
2008 DR-Z 400S
Times are GMT -7.   It's 05:07 PM.
