Old 04-15-2012, 07:52 AM   #16
CaseyJones
Ridin' that train
Oddometer: 530
That looks like a dead ringer for what I got almost dropping my Big Ruckus clone coming off the trailer.
And that was a lot lighter...maybe 175 pounds.
Doesn't take much, as you get older...worst of it is, I got an infection. Had on dirty riding pants when I did it and I didn't change or wash the scrape under the pant-leg. Laid up ten days with a leg like a sausage...
2007 Burgman 650 Executive...my last hurrah
2011 Xingyue XY300t-4 - Needs a new home
2011 Znen BigRuck clone...why'd I do it?
2005 Honda BigRuckus...The Last Word; the Armageddon AdventureRide.
CaseyJones is offline   Reply With Quote
Old 04-15-2012, 01:50 PM   #17
Tarka
Confirmed Urallist
Tarka's Avatar
Oddometer: 1,613
Gawd,it DOES look painful.
Hope it fixes up soon.
I'd only waste my money if I didn`t spend it on all my bikes......
Tarka is offline   Reply With Quote
Old 04-23-2012, 04:17 PM   #18
CurveLover
CurveLover's Avatar
Oddometer: 65
Ouch. Glad that didn't turn out much worse!
I deal with wet grass constantly as I have to park my Linhai 300 on it. It became evident very quickly that extreme caution is necessary, and forget that front brake while on wet grass. Might as well be on an oil slick. Even brand new Michelins don't help much in that case. Grass, loose gravel/sand, oil spots, wet roads and especially wet pavement painted markings are all things to avoid entirely if possible. And if you can't avoid them, then I try to use the back brake almost entirely on them- if having to brake at all while on those elements. I am also very careful with applying too much front brake pressure if I find myself in a curve going too fast, even on dry pavement. Best solution is to slow your ass down before ever touching that curve.
I don't guess this is mentioned from this angle much, but when a tire looses traction on any slick element, all of a sudden your braking power to the wheel increases exponentially. It will lock up that wheel without hardly any pressure at all on that brake, because the counter pressure of tire traction to keep the wheel spinning is lost. So you effectively have mega brakes at that point.
CurveLover is offline   Reply With Quote
Old 04-29-2012, 04:56 AM   #19
SpannerX
SpannerX's Avatar
Oddometer: 87
cut off
Woman rolled a stop sign and I ended up with a broken leg for my effort. Vespa now needs a bit of work. Haven't been down back to see it. I got the chrome hardware, seems like most of the time it is titanium now. I think I'd like the titanium instead.
'05 KLR 650
'80 P200E
SpannerX is offline   Reply With Quote
Old 04-29-2012, 08:04 AM   #20
JerseyBiker
Scootarazzi
JerseyBiker's Avatar
Oddometer: 1,239
Originally Posted by hexnut View Post
The bruise has expanded somewhat. 348 lbs of scooter ploping down on your leg is not good grass or not.. yeah it hurts.
Sorry Hexnut. Hope it is feeling better now. Heal fast.
JerseyBiker is offline   Reply With Quote
Old 04-29-2012, 08:05 AM   #21
JerseyBiker
Scootarazzi
Oddometer: 1,239
Damn that looks painful.
Hope they give you good meds for the pain.
Heal fast.
Times are GMT -7.   It's 11:50 AM.
