Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 04-19-2012, 06:37 AM   #3001
NMEXPAT
NMEXPAT's Avatar
Oddometer: 349
Originally Posted by oalvarez View Post
how do you turn on your heated grips? did you have to drill a hole to insert a toggle? curious as to how you finished the switch part of the install.
The install and removal is super easy, no drilling no permanent mods to the bike.
The temporary aerostich heated grips simply velcro onto and above the normal grips. Yes they make the diameter larger, but it's easy to get used to. Yes there's one more set of wires near the triple clamp, but you can route the wires so that it is still a clean look.
The switch is similar to an old school lamp switch. It's inline with the wires and located near the left hand grip. You simply install the heated grips, run the wires to the power source and you're done. To turn on just slide the switch. The main downside is that you need to remember to turn them off otherwise your battery will be drained. This is also easily solvable by using a relay with a hot wire trigger.
Actually, if someone had an awesome relationship with their dealer I don't see why anyone would need to buy the DP heated grips. You could permanently install heated grips and run them to the multi head grip switch and get the dealer to turn the option on. I don't see why non DP grips couldn't be connected to the Multi controller since all heated grips basically function the same although there might be slight difference in resistance. This would be similar to all the guys connecting their GPS to the standard GPS plug.
Since I live in Houston, where "winter" is at most only 2.5 months with summer conditions the rest of the year removable heated grips for $45 were the most cost affective option for me. I didn't pursue hooking grips into the standard plug / controller because I'm too lazy and I'm not sure my dealer is cool enough to turn the option on. Plus if there ever was any electrical problems in the future they most likely would lazily point to the non DP accessory.
I just took mine off a few weeks ago and stored them in the garage. IF you're thinking about heated grips, seriously give the $45 Aerostich a thought.
NMEXPAT is offline   Reply With Quote
Old 04-19-2012, 07:23 AM   #3002
AceRph
Affluenza Free!
AceRph's Avatar
Location: Where the stupidest people on earth run things
Oddometer: 24,635
Originally Posted by AceRph View Post
Ordered an Duc enduro seat. I hope it's not too tall.
Got the new seat & rode it about 75 miles on Monday. Much better in terms of rider space. I can put my toes on the pegs. The new seat is pretty firm, but the back part is nice and wide. It's a lot easier to move around on, so sliding forward for turns is not a problem. The Rocky seat's shape tends to hold you in one place.
I was able to flat foot the bike w/ my knees bent on the Rocky seat. The new seat is not too high; I can put both feet firmly on the ground. I have a 33" inseam.
If you ride up close to the tank for more than a few minutes w/ the enduro seat, you get the same numbness as you do w/ a bicycle seat that has the nose above level. Sliding back on the flat portion or standing on the pegs for a few minutes returns your nerve endings to normal.
All-in-all, an improvement over the Rocky.
Equal to all of you of roads and good luck! - krokodil al-kashi
“We are turning into a nation of whimpering slaves to Fear—fear of war, fear of poverty, fear of random terrorism, fear of getting down-sized or fired because of the plunging economy, fear of getting evicted for bad debts or suddenly getting locked up in a military detention camp on vague charges of being a Terrorist sympathizer.” —”Extreme Behavior in Aspen,” February 3, 2003
"The State sees the spectre looming ahead of terrorism and anarchy, and this increases the risk of its over-reaction and a reduction in our freedom." - Stanley Kubrick
AceRph is offline   Reply With Quote
Old 04-19-2012, 08:34 AM   #3003
SayItAintSo
Wanna be
SayItAintSo's Avatar
Oddometer: 129
Thanks for the update.
SayItAintSo is offline   Reply With Quote
Old 04-20-2012, 07:57 PM   #3004
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,553
Top speed
Just out of curiosity.... just how fast can my stock 2011 Multistrada go, last year on a lonely highway I cranked it up to 200 kph (124mph) and had a few gears left. What ever it is I'm never going to see it but it makes me wonder.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 04-20-2012, 08:29 PM   #3005
TIGERRIDER007
TIGERRIDER007's Avatar
Oddometer: 868
oil change
Trying to find info on do it yourself oil changes, can anyone point me in the right direction?
Or, answer, how much does it cost to do it your self? What oil is suggested? Are there other oil filters besides ducati you can use?
Again, just gathering intel...thanks!
Scott
06' Triumph Tiger (my lifer)
05' Husqvarna TE510 (yeller and blue)
TIGERRIDER007 is offline   Reply With Quote
Old 04-20-2012, 09:12 PM   #3006
Tillerman
DucDude
Tillerman's Avatar
Oddometer: 30
MTS 1200 seat alternatives
Got the new seat & rode it about 75 miles on Monday. Much better in terms of rider space. I can put my toes on the pegs. The new seat is pretty firm, but the back part is nice and wide. It's a lot easier to move around on, so sliding forward for turns is not a problem. The Rocky seat's shape tends to hold you in one place...
If you ride up close to the tank for more than a few minutes w/ the enduro seat, you get the same numbness as you do w/ a bicycle seat that has the nose above level. Sliding back on the flat portion or standing on the pegs for a few minutes returns your nerve endings to normal...
I get tailbone pain after a few hours on the Multistrada which first reminded me of this 2010 MTS review
"...Rider accommodations are generous in the vertical dimension, (but) it becomes clear that tall riders may wish for more wriggle room between the stepped seat and that tapered-steel handlebar. The ensuing riding position focuses body weight on a point directly below your tailbone..."
I feel its the vertical riding position (taken here) that causes my pain on the MTS since I didn't have it on my Yamaha FJR1300:
The 9° forward leaning angle and the extra bit of room to slide backwards on the FJR seem to make it a lot easier on the coccyx...
Anyone know of an aftermarket seat for the MTS1200 that extends to the rear and replaces both rider and pillion seat?
Tillerman screwed with this post 04-20-2012 at 09:36 PM Reason: typo
Tillerman is offline   Reply With Quote
Old 04-20-2012, 10:02 PM   #3007
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,084
I think it's electronically limited to 150mph.....
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 04-21-2012, 08:01 AM   #3008
nomiles
Sledge-o-matic
nomiles's Avatar
Oddometer: 4,005
I just picked up a white 2010 MTS S Touring today. 4100 miles. Original tires are still round. Showroom condition w/ top box & Termi & more extras. It was raining pretty hard today so just a short scoot up the road. Tomorrow should be a good day for a real shake down ride.
I'm very excited & lucky to get it.
NICE nice nice! got a glimpse of in in a WARPED pic and after some daze of thinking about I tracked ya down. Congratz! Roger. Be safe on that baby.
Everybody is someone else's weirdo.
nomiles is offline   Reply With Quote
Old 04-21-2012, 08:05 AM   #3009
AceRph
Affluenza Free!
AceRph's Avatar
Oddometer: 24,635
Thanks B. We missed you last weekend.
Old 04-21-2012, 09:08 AM   #3010
nomiles
Sledge-o-matic
nomiles's Avatar
Oddometer: 4,005
My torn rotator cuffs suck.
Have FUN with that beauty! I know you will.
Old 04-21-2012, 05:32 PM   #3011
kma_jg
Oddometer: 15
http://www.motorcycleinfo.co.uk/inde...pageId=2198961Here you go
kma_jg is offline   Reply With Quote
Old 04-21-2012, 07:57 PM   #3012
TIGERRIDER007
Oddometer: 868
Thanks for the oil change link!
Scott
Old 04-24-2012, 10:25 AM   #3013
ZLTFUL
Optimistic Pessimist
ZLTFUL's Avatar
Oddometer: 476
So I think my next 2 investments are going to be the MRA Touring screen and Motech crash bars.
I already ordered the bag liners and have a tank bag on the way. I also have a fuse box I need to wire in along with a few weatherproof 12v power outlets. I am going to wire my radar detector in permanently (actually use it less for radar detection and more for the emergency alerts it provides. I also have my GPS that I will be mounting up...less for direction and navigation and more for the information services it provides.
I am also selling off my high end desktop replacement laptop and replacing it with an ultrabook for travel. I am considering running 12v to my top box for the laptop charger as well. Although, some of these small solar kits seem rather appealing too...
Got some plans for this beast. Looking forward to travelling as much as possible and maybe some day being able to travel most of the time...
2012 Ducati Multistrada 1200S Touring
2013 Husqvarna TE310R
Avatar courtesy of www.mybadco.com
Ducati in The Rockies 2014 RR
ZLTFUL is offline   Reply With Quote
Old 04-24-2012, 03:54 PM   #3014
ChrisK7
ChrisK7's Avatar
Oddometer: 249
Maps for Bazzaz?
I'm still having trouble getting my 2010 MTS to run right in the 2k to 4K range.
I've installed a D&D can with the MIVV cat eliminator pipe and a Bazzaz FI unit. I was able to get the mapping from another guy on the forums that he set up on his with an Akro system and got it close but still not quite right.
My question is does anyone know of a place where we can share maps for the Bazzaz units or have one they can shoot me in an email or download somewhere?
I've heard mixed reviews on the self mapping unit that Bazzaz sells so I'm hesitant to buy one just yet but would really like to try some other maps.
I've heard of the Fat Ducs but I think the Bazzaz unit does the same thing as them while allowing you to tune the maps.
Does anyone have any tips or info on this bike with the Bazzaz?
'14 KTM Adventure 1190R 12 KTM 990 SMT ,09 KTM 530 EXC (plated), 09 Kawasaki Brute Force 750
ChrisK7 is offline   Reply With Quote
Old 04-24-2012, 04:07 PM   #3015
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 2,536
Semi-unrelated, but I'm seeing more dyno reports which suggest that the db killer in the MIVV decat pipe robs the motor of horsepower (restricts exhaust). Check out Ducati.MS for some great ECU/fueling related threads. Personally? The FatDucs do a great job helping the closed loop fueling down low on a stock exhaust bike.
See ya,
2014 Ducati MTS1200S
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, KTM 1290 SDR, and some BMWs as well.
oalvarez is offline   Reply With Quote
Times are GMT -7.   It's 01:50 AM.
