04-20-2012, 09:09 AM
#31 |
Rookie GSer
Oddometer: 335
http://db.tt/i0nRIGko
I would like to get some protection between the switch and the handlebar, but there's no way that is going to happen here. My desperate attempts of finding a way to relocate it are: http://db.tt/PRdlae1e http://db.tt/Y7UKydMK I'm probably going to use a different switch. Sorry for not embedding the pics, but I'm doing all if this via mobile phone. I don't have a computer at this point. |
04-20-2012, 09:58 AM
#32 |
Oddometer: 73
Those look realy big indeed. How is the light output?
The swivel mount looks neat |
04-20-2012, 10:52 AM
#33 |
Rookie GSer
Oddometer: 335
I've temporarily removed the pics. I'll get them back up later in the day.
Edit: They're back up again. Karbono screwed with this post 04-20-2012 at 11:15 AM |
04-20-2012, 11:06 AM
#34 |
Rookie GSer
Oddometer: 335
04-20-2012, 11:43 AM
#35 |
Oddometer: 73
Do you think you can fit some HIDs in the casing?
04-20-2012, 11:54 AM
#36 |
Rookie GSer
Oddometer: 335
04-22-2012, 07:46 PM
#37 |
< advertise here! >
Oddometer: 138
Installed the lights on my baby GS yesterday. Great product, the usual Givi standard. Came with everything: spots, brackets, harness, relay, fuses, switch, screws, and even covers for the screws. H3 lamps. Big, but very light. I aligned the spots to cover the dark area left by the low beam right in front of the bike (kinda like fog lights). I would like a little more dispersion from the spots (they are very focused).
Pics galore: ![]() ![]() Found a good place for the relay (under the seat): ![]() The switch (mounted on the handlebar): ![]() Here's the original low beam: ![]() Low beam + lights: ![]() Original high beam: ![]() High beam + lights: ![]() A couple shots from the front: ![]()
Enjoy yourself, it's later than you think. |
04-22-2012, 11:07 PM
#38 |
Oddometer: 73
04-23-2012, 07:33 AM
#39 |
Oddometer: 148
Nice! Thanks for posting the pictures, looks pretty good.
How is the vibration when riding, do you notice any shake on the lights when riding at night? |
04-23-2012, 07:42 AM
#40 |
Rookie GSer
Oddometer: 335
Seems like the baby GS has a thin handlebar....
04-24-2012, 06:31 AM
#41 | |
< advertise here! >
Oddometer: 138
They are 22mm I think? The switch was a perfect fit. -------------------- Now what is bothering me is the shadow caused by the brake caliper - you can see it in the pics (left of center of the projected light pattern). I'll try to find a way to correct that.
04-24-2012, 06:34 AM
#42 |
Rookie GSer
Oddometer: 335
04-25-2012, 06:28 AM
#43 |
< advertise here! >
Oddometer: 138
Oh, the famous "tapered handlebars".
05-05-2012, 04:36 AM
#44 |
Rookie GSer
Oddometer: 335
Well, Givi "support" seems to suck. No response from them so far.
05-06-2012, 04:40 AM
#45 |
My bikes Suck!
Oddometer: 873
I think I'm going to pick up a set for my versys using the sw motch high mount light mounts, and retro fit hid in there. Should throw a lot of light then. 55w hid in there should be very bright...
