04-24-2012, 05:37 PM
#41731 | |
No Pretensions
Oddometer: 277
Jaco Smith did a nice gallery of his install--you can see it here. https://picasaweb.google.com/1161725...eat=directlink Your tank should have come with some foam pads; wrap them around the frame, and zip-tie them onto the frame. The tank will fit snugly with the foam, the single bolt, and using either the coat hanger (or homemade cross members) to hold the tank in the front. Your tank should not rest against the fins. (You do still have the Front Fuel Tank Rubbers, right? Part #17611-MG2-000. If so, the Clarke tank should be nice and snug.) I can't comment about the bubbles, &c. in the plastic moulding. My tank is very well made. PD
The Good Lord gave most of us 10 digits; mine are all thumbs. |
#41732 |
Oddometer: 88
On the right side of the frame just below the dipstick is a black hunk of metal with fins on it sticking out. It looks for all the world like it's meant to radiate heat out and so cool the oil in the frame, which would mean it probably gets hot while riding. If it's something completely different, well, there's a reason I'm asking questions and not answering them.
XRL rider in east San Diego county |
04-24-2012, 05:41 PM
#41733 |
I'm Going Racing!!!
Oddometer: 18,440
Voltage regulator. as long as its not touching. even if you put a piece of rubber hose in between just so u dont have metal to plastic contact
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died. |
04-24-2012, 05:43 PM
#41734 | |
No Pretensions
Oddometer: 277
I have about a finger's width (1/2"??) of air space between the plastic Clarke tank and the fins. Personally, I have never experienced problems. On the other hand, ambient temperatures haven't been above 50ºF here in like 14 years, so I shouldn't comment. Many others have this same tank; I will defer to them. PD
04-24-2012, 05:46 PM
#41735 |
Oddometer: 88
Ok yeah found it's called a regulator/rectifier, for the electrical system, probably doesn't get that hot. Thanks for the answers anyways, forgive my ignorance, I had the day off and I've been drinking.
04-24-2012, 05:53 PM
#41736 |
I'm Going Racing!!!
Oddometer: 18,440
NP, just wasnt sure what u meant by radiator.. thought maybe u had an R
04-24-2012, 08:03 PM
#41737 |
Yea, its a friggin L
Oddometer: 1,759
Speaking of the rectifier..a question for the electrical wizards:
I want to try and relocate my rectifier, and because of this, also hopefully switch it out for a smaller one. Is there any way to determine the voltage bleed off of the stock XRL, to then find if (a smaller) one from another Honda can be subbed? BP |
04-24-2012, 08:06 PM
#41738 | |
Duel
Oddometer: 2,194
http://www.advrider.com/forums/showthread.php?t=184236
__________________ "If you can't be a Professional, at least look like one." |
04-24-2012, 08:11 PM
#41739 |
The Hurt Locker
Oddometer: 276
Here's my newest $20 addition to my piglet. DIY Digital oil temp gauge!
2005 KTM 300 EXC - Titled and plated. gldsmc.org malignity screwed with this post 04-25-2012 at 01:32 PM |
04-24-2012, 08:34 PM
#41740 | |
Duel
Oddometer: 2,194
http://www.advrider.com/forums/showthread.php?t=719093
04-24-2012, 08:42 PM
#41741 | |
Just...one...more...
Oddometer: 334
04-24-2012, 09:14 PM
#41742 | |
Oddometer: 1,759
BP |
04-24-2012, 09:28 PM
#41743 |
Oddometer: 161
Explanation of what you've done?
On the grocery getter buell s3t. |
04-24-2012, 10:26 PM
#41744 | |
Oddometer: 208
Rum is the bad boy of booze. The pirates of the Caribbean weren't drinking vodka. The British navy wasn't run on "amaretto, sodomy and the lash." The smugglers who risked death to bring in illegal alcohol to the thirsty citizens of the U.S. during Prohibition weren't called "spritzer runners." |
04-24-2012, 10:39 PM
#41745 | |
No Pretensions
Oddometer: 277
I get it that the rectifier changes the 3-phase AC signal into DC (the opposite of an inverter, right?), and the regulator ensures that the proper voltage gets sent to the battery for recharging. By installing a more efficient unit, would that simply reduce the amount of resistance sent to the Reg/Rec unit (thus both reducing heat discharge as well as making make more wattage available for other uses)? What I am wondering is whether a more efficient Reg/Rec would free up some wattage, to power some more heated gear. I know that somebody is going to pile onto me with a lecture about volts, watts, and amps. I am all ears--please instruct. PD
