04-24-2012, 10:25 PM
#796 |
In need of repair
Oddometer: 1,431
Talking to EddieB while working on the bike > limited concentration > to scope creep > grumpy wife.
Padmei, need any lessons on barrel / piston removal? ![]() I was supposed to be just replacing the leaky head gasket, but the base moved, & then it became apparent that the last person there had used a bit of silicon gasket in the o rings, barrel base & pushrod seals. The pushrod seals are fairly old looking in any event. Looks like time for another parts order. |
04-25-2012, 12:14 AM
#797 |
enamoured
Oddometer: 2,491
Can you see my mirthful face Nutso? (My wife just asked concernedly why I'm smiling into the laptop)
Ah I know the feeling so well. It's like reading a Wilber Smith in front of the fire with a pipe glowing & saying to oneself "I'll just read one more page... after this chapter..." I too will be gracing the doorstep of Motobins online store later to order some head gaskets, o rings & gasket sealer. I haven't yet been educated upon the source or product of 'silicon grease' that is so popular overseas. I struck a similar problem asking all my electrician friendies & wholesalers what "di-electric grease' was. All I got was raised eyebrows (from them - they didn't actually reach over & push mine up with their fingers - it's a figurative thing- kind of. Been a long day |
04-25-2012, 01:17 AM
#798 |
Armature speller
Oddometer: 6,777
I'd like to note that Padmei doesn't actually have a fire, it's a DVD of one playing on loop on the old 21" tv, the armchair is a My Little Pony beanbag and the pipe is off an R1...
04-25-2012, 02:11 AM
#799 |
Oddometer: 2,209
if he filled it up it would prolly be 60 bucks....can def feel the weight difference when the pd is full
aka BMWST?
04-25-2012, 02:16 AM
#800 |
In need of repair
Oddometer: 1,431
$94 to fill the tank from dead empty. I did a couple of $67 fills on the way round..
04-25-2012, 02:20 AM
#801 | |
AKA Woodman
Oddometer: 465
04-25-2012, 02:26 AM
#802 |
enamoured
Oddometer: 2,491
04-25-2012, 02:35 AM
#803 | |
AKA Woodman
Oddometer: 465
Both CRC products. Got em on the shelf. |
04-25-2012, 12:47 PM
#804 |
enamoured
Oddometer: 2,491
Thanks that's cleared that up. I wonder why I've never seen them mentioned in Kiwi threads?
04-25-2012, 01:17 PM
#805 |
Armature speller
Oddometer: 6,777
Damn. Repco in town only had Di-electric grease in dinky little squeeze packets good enough for one connector for $2 or so last time I looked.
Must look again... None of the electrical shops knew what I was talking about. Must be my accent. |
04-25-2012, 05:28 PM
#806 | |
In need of repair
Oddometer: 1,431
![]() I found that putting the grease on just ended up attracting dirt, rather than keeping corrosion at bay.
My '91 R100GS thread is here My Ride photos are here It's just better when there's twins involved....
Box'a'bits screwed with this post 04-26-2012 at 12:40 AM |
04-26-2012, 02:36 AM
#807 |
Guzton
Oddometer: 124
di-electric grease
try Pan pacific (electrical wholesaler) i'm sure they've got some possibly in toothpaste sized tubes.
nutso ,give me a ring, may have some bits that may assist engine assembly. cheers T
"Generally speaking , you aren't learning much when your lips are moving". |
04-27-2012, 11:36 PM
#808 | |
enamoured
Oddometer: 2,491
Are you taking lots of pics Nutso? I know you've been out there today. |
04-28-2012, 12:48 AM
#809 | |
In need of repair
Oddometer: 1,431
May also do the camchain, which was reputed to have been done before I bought the bike (but if that's the case, then why am I getting that timing shimmy between jugs?). |
04-28-2012, 12:57 AM
#810 | |
enamoured
Oddometer: 2,491
More info needed re timing chain. I was wondering if mine was up for renewal. I should research checking it for wear I spose. That's why I've got 2 bikes. Working on bikes is the biggest motivation for riding them I reckon. |
