04-02-2012, 07:07 PM
#1096 |
Jellyfish Proctologist
Oddometer: 1,952
04-02-2012, 10:07 PM
#1097 |
I need supervision
Oddometer: 1,050
The current model Range Rover is not body on frame. The new model will be 1k lb lighter through the extensive use of alloy in the body. Due out as a 2013. There are also over 7 new engines being developed IN HOUSE to replace the current Ford and Peugeot power plants.( currently the biggest limiting factor to production, cant get enough engines to meet demand. especially with Evoque)
04-06-2012, 05:30 AM
#1101 | |
Stuttgart Germany
Oddometer: 1,076
Hope is not a course of action. |
04-06-2012, 06:03 AM
#1102 |
Oddometer: 4,266
04-06-2012, 06:42 AM
#1103 |
Oddometer: 2,012
nice concepts, but not defenders... :-(
Never stop exploring |
04-06-2012, 07:03 AM
#1104 | |
Something witty...
Oddometer: 3,616
Mav ------------------------- All the gear.. no idea! |
04-06-2012, 08:38 PM
#1105 | |
ǝǝʞuɐʎ
Oddometer: 4,655
I know that some look down upon the IFS/IRS that Land Rover is using in the LR3/LR4/RRS and the Range Rover, but it's very functional. At least, it works well in my LR3.
04-25-2012, 11:06 AM
#1106 |
between
Oddometer: 8,707
Am I asking for trouble with this? Daydreaming.
![]() "Seller's Description and Comments RHD, 200tdi, 5 speed, legendary 4WD prowess and runs great. Turbo DIesel engine has 70k miles.Total miles 110k. New clutch installed. Towing capacity is 7000 lbs. This vehicle gets around 30mpg on the highway making it a great commuter vehicle and manage 20+ mpg city and under tow.Very clean interior . Tires are in very good condition.Well maintained, Bulkhead and frame are great, recently wax oiled. British OD green. Clear Virginia title. Located in Front Royal, VA. $13,500 OBO. Biodiesel ready. I also have a 5 door tub and conversion parts for sale separately. to convert to a family SUV." http://www.autotrader.com/cars-for-s...19946917&Log=0
ˇNo contaban con mi astucia! |
04-25-2012, 11:42 AM
#1107 |
Noshing...
Have to wonder how a RHD car on UK plates got to the States. Anyhow...
Things that can get bad: Bulkhead rot - that flat military green can hide a multitude of sins, check the bulkhead (the thin strip of metal running down just in front of the doors and under the windscreen) for rot - tap it, twat it, thump it or use a magnet however you like. Just make sure that it has no metal-moth holes. Fried cylinder head - 200TDI's are better for this than 300's - mine was a 24carat bastard 'till I figured it out and skimmed the head - once they get hot and boil up the heads tend to warp easy. Like I said, it happens way more often on the 300's (due to a shitty waterpump gasket arrangement) but not unknown on the 200TDi. At 76Kmiles, the standard checks on the Turbo, both gearboxes, both Diff's, all 4 uj's are prudent (not to mention the front CV joints) as are chassis and cross-member rust checks. Get under there and *look*. That paint looks very new and may exist underneath too. There's a lot of overspill from the oil filler, so I'd ask how it got there just to rule to rule out a blocked crankcase breather masking blown valve seals or such. Ask when the timing belt was done last - they can be sensitive to poor replacement and a belt failure causes a mess (DAMHIK): ![]() Short of that, I'd buy it if it were over here - I need a LWB landy. CAVEAT: Spares here are 2-a-penny, cheap and plentifull but I have no clue about spares prices and availability in your area (or the US in general come to that), I suspect high and low respectively. Provided the basics look good - go for it. If you know Landies, you'll already know most problems are easily fixable though. It's why we love 'em. Many of the green-laners and triallers here rate the 200TDI unit as the one to go for over the 300 and if you see a old series diesel converstion here, the chances are that the old lump (2.25petrol or any of the many old deisel lumps) has been pulled in favour of a 200TDI. It just works. And works well. damoace screwed with this post 04-25-2012 at 11:47 AM |
04-25-2012, 02:02 PM
#1108 |
Regular user...problem???
Oddometer: 1,593
D90
Getting shiny from the inside!
04-28-2012, 06:01 AM
#1109 | |
Something witty...
Oddometer: 3,616
Was thinking of starting to bring in ex-Army Landies to the US - they'd be lower mileage and LHD but probably nearer $20k...
04-28-2012, 07:31 AM
#1110 | |
between
Oddometer: 8,707
| Thread Tools | |
