Old 04-18-2012, 04:18 PM   #46
CDNbiker
Lost in Space
CDNbiker's Avatar
Oddometer: 499
Originally Posted by jungleplant View Post
Nice i would like to see that too, hey i just shipped the blinker re locator for ya so they get to move , we are in touch with Mitsubishi about getting the parts to make the extensions for you guys , thanks mike
Thanks Mike
And for your viewing pleasure, I found the link for the Vespa
http://jalopnik.com/5135543/beautifu...e-wooden-vespa
"The memories of a man in his old age are the deeds of a man in his prime" - Pink Floyd
CDNbiker is offline   Reply With Quote
Old 04-18-2012, 04:45 PM   #47
jungleplant OP
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,843
Originally Posted by CDNbiker View Post
Thanks Mike
VERY cool. nice Rack too!
www.manracks.com
jungleplant is offline   Reply With Quote
Old 04-22-2012, 06:46 PM   #48
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
only got a few prototypes left this ones on fleabay
www.manracks.com
Old 04-25-2012, 03:34 PM   #49
chupa88
Oddometer: 66
Tail light rack and blinker relocator?
Can you post a pic of what the tail light rack looks light when installed and the blinker relocator as well?
chupa88 is offline   Reply With Quote
Old 05-14-2012, 08:22 AM   #50
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
Suzuki TU Fender Rack thanks for the pix Norm
www.manracks.com
Old 05-15-2012, 08:17 PM   #51
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
manracks.com TU250X Blinker Re-Locater Brackets
www.manracks.com
jungleplant screwed with this post 05-16-2012 at 07:43 AM
Old 05-23-2012, 01:29 PM   #52
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
Thanks Pat Looks great
www.manracks.com
Old 05-24-2012, 07:41 PM   #53
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
getting some good feedback on install
Alright, finally figured it out. Thanks for the quick help, and I have to say that's a mighty fine quality rack you guys make.
A big tip to whoever else out there might be installing for a TU250x though, is to first remove the turn signals, then remove the both the front and rear saddles, install the rack (so that it's easier to lift the fender to realign the frame bolts) and re-attach the rear seat before attaching the rear bolt clip, because that one screw in the back of the rear saddle gets in the way. Had to figure this out by trial and error, but in the end it was fun., thanks Pete K
www.manracks.com
Old 06-06-2012, 06:30 PM   #54
chupa88
Oddometer: 66
How do I loosen...
Got the tail light rack! How do I loosen the bolt that the rack is supposed to attach to? Or rather, what do I use to loosen that bolt? The interior hex looks huge and I have nothing in my toolbox that will fit inside it.
Also, the loop bracket that is supposed to secure around the bar is too small! That bracket isn't big enough to go around the bar and line up with the holes on the tail light bracket and the rack. The bolts that came with it are too short to fit thru the loop bracket, tail light bracket and the rack.
I'm gonna have to go to Home Depot to find some longer nylon thread bolts and perhaps another loop bracket.
Old 06-06-2012, 07:32 PM   #55
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
we only have one size strap, sold a few hundred so far and they all fit , so get a allen wrench to take out the bolts then try again, and then if there is something wrong i can call you and see whats up ok, or if you cant figure it out we will buy it back no problem, get back to me mike
update
just got off the ph with chupp and damned if i didnt send the wrong clamp, must have fell in the box from shipper. thanks for keeping me on my toes, new clamp is in the mail, mike
www.manracks.com
jungleplant screwed with this post 06-06-2012 at 09:33 PM
Old 06-07-2012, 08:48 AM   #56
chupa88
Oddometer: 66
Yep! Just got off the phone with the Man from Manracks and he was very helpful in determining the issue was the wrong size clamp and has already dropped off a new one in the mail. Thanks for your diligence and quick reply! That's the right way to run a business!
CH
UPDATE 6/12/12
Got the new part from Manracks and everything fits perfectly. The tail rack is great and not very obtrusive so it fits the lines of the bike pretty well. And I got the blinker bracket as well. Everything looks and fits great! Definitely worth the money!
update
chupa88 screwed with this post 06-12-2012 at 09:26 AM
Old 11-09-2013, 07:42 PM   #57
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
checkout that Cigar Jon is smokin
www.manracks.com
Old 10-25-2014, 02:34 PM   #58
4doora
Moped guy
4doora's Avatar
Oddometer: 24
Got my rack in the mail and mounted up this afternoon. Thanks Manracks!
4doora is offline   Reply With Quote
Old 12-06-2014, 11:56 AM   #59
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
great , that was fun to build for ya
been really busy, thanks to all you great guys, thanks a bunch , Mike
www.manracks.com
Times are GMT -7.   It's 06:51 PM.
