Old 04-26-2012, 07:54 PM   #1
TMeiries OP
Oddometer: 1
Question lc8 use oil
do LC8 use oil
TMeiries is offline   Reply With Quote
Old 04-26-2012, 07:57 PM   #2
Katoom119
Mmmm....Orange Kool-aid
Katoom119's Avatar
Oddometer: 1,841
I'm assuming you mean does it burn oil?
Mine doesn't use any at all. You might find some that burn a very small amount after they have 50,000+ miles but for the most part no, they don't.
Those who dance are considered crazy by those who do not hear the music.
I am not the same having seen the moon shine on the other side of the world. - Radmacher
5 Cylinders vs. Moab..........My East Tennessee.........Internships may go to Hell and I will go to Alaska
Katoom119 is offline   Reply With Quote
Old 04-26-2012, 08:01 PM   #3
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 710
Mine is at 35k+ and does not burn a drop ... So I agree...
Pistolero is offline   Reply With Quote
Old 04-26-2012, 08:14 PM   #4
Mad Kaw Disease
Dual Sport Diseased
Mad Kaw Disease's Avatar
Oddometer: 534
+1......40,000 miles and never added a drop of oil between servicings.
2007 KTM 990 Adventure
2014 BMW R1200RTW
"I was going faster than I ever went in my whole life and I fell off...." Little Fauss
Mad Kaw Disease is offline   Reply With Quote
Old 04-26-2012, 08:27 PM   #5
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Well, ktm considers normal oil consumption to be 0.3 to 0.5L per 1000km. Below that level they won't warranty a fix.
Plenty of bikes here are consumers of oil. Obviously plenty are not also.
crazybrit is offline   Reply With Quote
Old 04-26-2012, 08:29 PM   #6
JOKER650
JOKER650's Avatar
Oddometer: 1,560
The first 3000km the SE used about 1/2 L then nothing ever since.
Life's short...ride far
Over 2000 plated dirt riders...Digg'n up the dirt every other day, all over BC
http://www.dualsportbc.com/
JOKER650 is offline   Reply With Quote
Old 04-26-2012, 08:29 PM   #7
imgonnasnap
Motard wrecker
imgonnasnap's Avatar
Oddometer: 808
Whats the proper way to check the oil level on these things? the SE is a tad different than my adv so I'm not totally used to the servicing differences.
Originally Posted by HappyGoLucky
lots of guys make excuses - it must be the tyres, it must be the weight, it must be the power, it must be the water pump.
ride the $*#(@) thing, and you'll quickly learn that the stain marks in your brooks were firstly from fear and then from ecstacy.
Scuderia: LB to SF
Bradshaw Bombrun 2007, 2008, 2009
Stupidly long road trip of 2009
imgonnasnap is offline   Reply With Quote
Old 04-26-2012, 09:28 PM   #8
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 5,897
Mine doesn't burn any between changes. I've ridden behind some that do, and some that don't.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is online now   Reply With Quote
Old 04-26-2012, 09:54 PM   #9
Tooltech
Oddometer: 132
990 oil check...
I start and run at idle until 4-5 bars light up on the temperature gauge. Shut the engine off and place the bike on the center stand so the bike is level. Wait 4-5 minutes then unscrew the dip stick, remove same and wipe clean. Install the dip stick and screw all the way down. Remove the dip stick and check the oil level making sure the oil level is between the limit lines. I run my oil near the upper limit line on the dip stick. Do not over fill the oil tank.
My '08 990 used very little oil between oil changes. My '11 990R does not use oil currently ( 5,000 miles ). I use Motorex 20-50 oil and KTM factory filters.
2013 KTM 500 EXC
2012 KTM 990 SMT
6 NOVEMBER 2012 DARK DAY FOR USA
Tooltech is offline   Reply With Quote
Old 04-26-2012, 11:00 PM   #10
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 755
depends how often u change it
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 04-27-2012, 12:59 AM   #11
Sumi
Sumi's Avatar
Oddometer: 1,796
Mine was burning half a liter every 5k miles - so during the oil change periods basicly - (20k miles in the bike).. Changed oil scraper rings (one was out of spec), and it haven't burnt any since that..
Old 04-27-2012, 06:05 AM   #12
skipman
skipman's Avatar
Oddometer: 175
23,000 miles and mine burns about 1/2 gt .per 3,000 miles. always has
Not responsable for broken windshields.Please stay back 300ft.
'10 KTM 990r
skipman is offline   Reply With Quote
Old 04-27-2012, 01:28 PM   #13
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 518
Checking the oil level on the 990 Adv
Note when checking oil level.
When checking oil on the 990 adventure manuel says level the bike. Check the dip stick. Does not mention center stand.
If you put the bike on the center stand the oil level will show lower fill on the dip stick. about 8 ounces. If you top the level up on the center stand and check the bike on a level surface (not on the center stand) the oil will show over filled!
How do I know this?
KJ
Oh... I have had to top up my oil once but the bike was down for awhile, as in crash testing! Don't know if that could have affected it.
2008 990 Adv 13,000 miles
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe screwed with this post 04-27-2012 at 01:55 PM Reason: OH
knobbyjoe is offline   Reply With Quote
Old 04-27-2012, 01:59 PM   #14
bigkuri
bigkuri's Avatar
Oddometer: 730
In normal riding mine uses no oil, 2011 Adv R with 14,000 miles.
But, everytime I do highspeed motorway slogs it uses about 0.5l per 1,000 km. This is at 95mph constant throttle on a loaded bike.
But as said "normal" riding uses no oil at all (that I can tell).
---------- Current Bike: 2006 Honda XR650R ------------
bigkuri is offline   Reply With Quote
Old 04-28-2012, 01:20 AM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,918
Sorry but I cannot follow
Originally Posted by knobbyjoe View Post
If you put the bike on the center stand the oil level will show lower fill on the dip stick. Why? about 8 ounces. If you top the level up on the center stand and check the bike on a level surface (not on the center stand) the oil will show over filled! Why?
Can you explain?
thnx
gefr is online now   Reply With Quote
Times are GMT -7.   It's 06:05 AM.
