Old 04-27-2012, 06:34 PM   #16
D.Bachtel
D.Bachtel's Avatar
Location: Nipomo ,,,, Where HWY 101 and HWY 166 collide!
Oddometer: 490
Thumb
Originally Posted by Dakar Couple View Post
Speaking of variety parts and 15 mm axles, I've got two 15 mm axles the old wheel, the old tire, enough Velorex mounts to outfit 2 sidecars, and the fender sitting in a box. First local to come up with a reasonable take it off your hands number its gone.
I could use some Velorex mounts, the balls and collets.
I'd be interested in any struts and clevis's in excess to your needs.
I really like what you've done there in the basement, you have some talent and xlnt design ideas. This will end up on a Dakar? Big Dakar or little Dakar? Did I miss the picture of the tug?
Don in Nipomo
D.Bachtel is offline   Reply With Quote
Old 04-27-2012, 08:25 PM   #17
Dakar Couple OP
Oddometer: 33
Don in Nipomo
A basement full of bikes and bent pipe. My wife loves it. Il send you a list of stuff once I'm done.
Dakar Couple is offline   Reply With Quote
Old 04-28-2012, 04:39 PM   #18
Mr.Mellow's WildRide
Oddometer: 333
Thumb
Nice Design & Work..........
Mr.Mellow's WildRide is offline   Reply With Quote
Old 04-28-2012, 10:55 PM   #19
Dakar Couple OP
Oddometer: 33
Thank you. I appreciate the compliment
Old 04-29-2012, 04:27 AM   #20
pops
Oddometer: 1,576
Nice work .Thank you for posting
Cheers Ian
pops is offline   Reply With Quote
Old 04-30-2012, 02:03 AM   #21
val. h.
On the wrong planet
val. h.'s Avatar
Oddometer: 123
Ya, the original chassis is less than stellar on the Velorex, but I've upgraded the axle to a hardened 17mm, the use of the klr rear wheel left the 17 mm the maximum size i could accomidate due to the skinny little bearing on the cush side of the hub. As for the extra weight, you can accomidate allot of extra if the intended passenger is 37 lbs, even the roll cage and lg are together it still comes about a 100 lbs under the design weight for the original equipment. Leaves lots of room for a bag of groceries. The chassis as it sits was totaly unacceptable and has been modified and reinforced.
Glad you're ahead of me there. Thought it worth mentioning though.
Val.
The land you visit may be a beautiful place with extraordinary views and heavenly skyes, but it's the people of the land that make it truly worthwhile returning time and time again.
Ay! and the roads need to be bloody good too
val. h. is offline   Reply With Quote
Old 04-30-2012, 07:22 AM   #22
Dakar Couple OP
Oddometer: 33
Val.
I appreciate the input and need to thank the INMATES of ADV, becuase of the info they have put out there on side car building and installation not much of my build was a suprise, there is the occasional one but mostly attributed to my not paying attention ( like the klr bearing being two different sizes )
Old 04-30-2012, 07:43 AM   #23
Dakar Couple OP
Oddometer: 33
Did some work this weekend, made progress
So, fridays beginning post covered the first 5 months now you get stuff as hit happends.
Sub Frame comming together its 1" .120 wall, great stuff to work with.
I had to rigg the side car frame quickly at this point, make sure I wasnt going to gusset and reinforce in the way of one of the mounts.
FIrst time for a SANS kick stand kinda pic. A proud day !!!!!!
Old 05-01-2012, 06:38 AM   #24
Dakar Couple OP
Oddometer: 33
Busy Night
I had some time last night and was actually able to assemble some stuff, I had this horrific dream the night before that the roll cage interfered with the rear upper strut mount, Well the bike gods granted me a ONE FREE, it close but not in the way.
The largest feat of design with this thing is the simple fact that you cannot weld around the body, you need to be able to split.
Old 05-01-2012, 06:57 AM   #25
Rotten Ronnie
Crash
Rotten Ronnie's Avatar
Oddometer: 354
Did you get the attachment point for the rear top mount sorted out?
It's looking great!
Bikes I haven't managed to destroy yet:
2009 Kawasaki Versys 650
Ride Reports and other drivel:
http://rottenxxxronnie.blogspot.com/
Rotten Ronnie is offline   Reply With Quote
Old 05-01-2012, 10:41 AM   #26
Oddometer: 333
Thumb
Should be able to drive through brick walls unscathed.................
Old 05-01-2012, 12:37 PM   #27
Sidecarjohn
Sidecarjohn's Avatar
Oddometer: 731
Wow !
Correction - Triple WOW !
SidecarJohn
http://www.sidecarjohn.co.uk/
Sidecarjohn is offline   Reply With Quote
Old 05-01-2012, 01:31 PM   #28
Dakar Couple OP
Oddometer: 33
Color Options
Well, I've just had an interesting conversation with a friend of mine. He feels the sidecar ( gun metal gray ) roll cage ( flat black ) would look far more interesting if the bike matched it, rather than making the it match the bike. The intention was to always paint the car to suit one of the two Dakars, the only question was wich one.
Mine the 2006 ( Above ) ~ Its got some "love" on one side from a go down last year or hers ( the 2003 ) that is in immaculate condition.
I've always been a fan of the flat gun metal grey with clear coat on it look, it would be an interesting look, very Mad Max'ish.
Old 05-01-2012, 01:34 PM   #29
sparkymcgee
sparkymcgee's Avatar
Oddometer: 337
Yes.
2008 VFR800
2012 Super Ténéré
sparkymcgee is offline   Reply With Quote
Old 05-01-2012, 01:39 PM   #30
RAGBrian
jonesing for a ride
RAGBrian's Avatar
Oddometer: 1,020
Nice build going on. Gotta luv a wife that likes to ride her own...much less help drag a tubing bender downstairs to the basement!
RAGBrian :: NC700X ::1978 CX500 Standard :: 1976 CB360T ::
"Going where you don't belong, I decided a long time ago, is the root of all misery and the soul of all adventure." - Peter Egan
RAGBrian is offline   Reply With Quote
Times are GMT -7.   It's 08:25 PM.
