Old 04-24-2012, 12:35 PM   #1
BuiltnotBought OP
Perpetual Project
BuiltnotBought's Avatar
Oddometer: 42
Suspension for your hack?
Just getting started building my own hack here and I've been lurking around the site a while gleaning some knowledge. Wondering if anyone who has built their own would be willing to share what they used for a shock? I had been planning on using a shock from an old ninja 250 I have in the spare parts bin. They are notoriously bouncy for a bike, but I'm wondering if it still might be too stiff for a hack. Anyone have any tips for other options? Gocart shocks, something like that maybe?
These hands sit not idle.
BuiltnotBought is offline   Reply With Quote
Old 04-24-2012, 02:09 PM   #2
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,959
Check out my build,should help with this issue!!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 04-24-2012, 05:33 PM   #3
BuiltnotBought OP
Perpetual Project
Oddometer: 42
I have thanks, and at one point I was planning on using the rubber shock setup you had used until I saw the issues you ran into.
I should also mention this is going to be a strictly on-road rig, no offroading at all.
Old 04-24-2012, 06:48 PM   #4
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,174
The shock I used was from the rear of some china made 4 wheeler.
cleatusj is offline   Reply With Quote
Old 04-24-2012, 07:20 PM   #5
NortwestRider
Oddometer: 3,959
I have twin shocks on the car now,and when my wife is in it OR I'm hauling stuff it works great.But when it's empty it's tooooo stiff.I'm going to make it so I can remove the top nut of the shock easily and lay it forward to a bracket so I can just run 1 shock most of the time.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 04-25-2012, 06:09 AM   #6
BuiltnotBought OP
Perpetual Project
Oddometer: 42
Ah! quads were something I hadn't thought of. I'll have to look into that. I'm building a leaner, so it will be a lightweight rig to start with.
Old 04-25-2012, 12:51 PM   #7
Pete-NZ
Pete-NZ's Avatar
Oddometer: 743
On my first leaner I used a cheap shock of unknowen make... I found getting
the right shock strength & ride height between loaded & unloaded was a prob..was always adjusting
the preload rings... I found in the end the rig worked better with a bit of weight in it...
That releaved the prob somewhat...
I'm building another leaner at the moment... both mine are off road units..
build links below
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 04-26-2012, 07:39 AM   #8
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,462
So, pre load the car....? Then keep it this way until you have weight w/ a heart beat.
Wolfgang55 is offline   Reply With Quote
Old 04-26-2012, 08:04 AM   #9
BuiltnotBought OP
Perpetual Project
Oddometer: 42
Very good looking builds there. I'm always keen to see what other people come up with for subframes, like you said, thats where the trick is.
One thing you said in your build made me think; you said the whole rig weighs under 80lbs. I pretty much heaved all my weight on this ninja 250 shock I have and didn't budge it. Granted only I'm not the most robust fellow at just 150lbs, but still; the reason I'm building this rig is for the kids to begin with.
I think I'll start keeping my eyes peeled for atv shocks.
Old 04-26-2012, 10:08 AM   #10
Billtr96sn
Flange Furtler
Oddometer: 393
As I will never carry people I didn't bother with suspension on the chair.
Billtr96sn is offline   Reply With Quote
Old 04-27-2012, 10:27 PM   #11
bubby-joe
Oddometer: 14
I used a shock from a 1980 yamaha beluga scooter it's a mono shock with 350 lbs capacity had no problem with 2 up 500 LBS but looked real funny from behind should have had the camera for FHVideo's.
bubby-joe screwed with this post 04-28-2012 at 06:57 AM
bubby-joe is offline   Reply With Quote
Times are GMT -7.   It's 04:43 AM.
