Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 04-29-2012, 01:08 AM   #196
advNZer?
advNZer?'s Avatar
Oddometer: 2,831
Originally Posted by Box'a'bits View Post
Michael asked me to post this given he doesn't have a third party hosting site. Originally this discussion was in the Schmiddty thread. Thought it might fit better here.
1978 Grumman AA-1C
Picture was taken at Lake Station airstrip (the glider strip running parallel to the State Highway West of St Arnaud) a month or so ago. We had stopped here for lunch before heading off to 6500 foot Mount Owen for a look. I have owned a share (1/3) of it since 2005. Great for reconnaissance of adventure ride prospects, so long as you don’t want to land anywhere too short or rough (take off performance is not scintillating). Special feature of this design is that it made of traditional aluminium but bonded (glued) together rather than riveted.
so is it a flat four or radial or??Surely it aint a twin!?...edit its def not a radial
aka BMWST?
advNZer? is offline   Reply With Quote
Old 04-29-2012, 01:17 AM   #197
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Originally Posted by msmckeon View Post
Did my own "airhead' trip last weekend, except I took the four cylinder airhead down for a look at Farewell Spit on Sunday, with stops at Nelson (fuel and 2nd morning tea), Takaka (lunch), Motueka and Nelson (fuel). Michael
A 1978 Grumman Lynx, powered by a staunchly 2 valve, air cooled four cylinder Lycoming O-235 (235 cubic inch). 125 hp at about 2750 rpm. Twin plugged!
Michael
Just because its you.... I assume its a flat four, configured like a VW, ie 2 left, 2 right
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 04-29-2012 at 01:23 AM
Box'a'bits is offline   Reply With Quote
Old 04-29-2012, 02:04 AM   #198
Padmei
enamoured
Oddometer: 3,604
Intersting what other riders are into when they're not riding.
Igormortis has his Wolwo, Michael his plane, Nordie his emporium...
Im sorry Michael but from now on I'm going have to refer to you as Wing Commander or wingco for short.
I can see your moustache twitching from here.
Chocks away Ginger
Padmei is offline   Reply With Quote
Old 04-29-2012, 04:24 AM   #199
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 312
Originally Posted by Mark_S View Post
the heavy clutched wr would be a pig in tight stuff without mr rekluses assistance
Hi mate, I am curious to hear what sort of kms are you are getting out of a fresh friction plate pack with the Rekluse clutch
Cheers
Josh
www.RemoteMoto.com
RMOTO is online now   Reply With Quote
Old 04-29-2012, 03:14 PM   #200
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,777
1978 Grumman AA-1C
well perhaps you could tell Micheal to get a hosting account and start a 'my other adventure rides (the ones that use reliable transport - not a bmw)' thread
Cheers
Josh
Hi Josh
I put 200+hrs on my first WR and the plates where still within spec and functioning fine (although they were discoloured as a result of me overheating/abusing the clutch)
The new WR has about 50-60hrs with same rekluse fitted and is fine despite being set up 'looser' (higher engagement rpm and wider engagement spread) than on the last bike.
its very easy to abuse the clutch as the traction is vastly better slipping it in 2nd rather than wheelspinning in 1st....
I have acute girlyness of the left wrist (chronic tennis elbow) and I simply could not ride the WR in tight going without the rekluse (I'd become another boring squid on a ktm 300 then...).
These are the best days
Mark_S is offline   Reply With Quote
Old 04-29-2012, 07:07 PM   #201
RMOTO
Doing secret stuff
RMOTO's Avatar
Oddometer: 312
Hi Josh
Cheers for that, very interesting, I love my Rekluse also but with it being a new addition to my bike I am yet to see how long the unit lasts and how quickly it will consume friction plates on average. I just chewed through the friction plates on a DRZ400 at 7,500km/133 hours. Admittedly the first ride was a 4,000 km trip around the South Island on stock Rekluse EXP springs with full engagement a little too high for general adventure riding of which I believe definitely caused initial premature wear. After returning from that trip I changing the EXP unit springs to get a lower RPM engagement which has overcome that problem plus makes it a lot nicer for general ADV riding. Hopefully it will now accommodate for 15,000km+ out of a fresh pack of friction plates when riding fully laden with gear and tackling the rough stuff, time will tell...
Cheers again
Josh
www.RemoteMoto.com
Old 04-30-2012, 04:03 AM   #202
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,777
Cheers again
Josh
FWIW I have done 25K KM on my klr with a rekluse fitted without problems.
Both my rekluses are the pro versions so may not be comparible to your exp
Old 04-30-2012, 05:51 PM   #203
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,010
It's a boxer 4. A Lycoming 0-235: http://en.wikipedia.org/wiki/Lycoming_O-235
I started training in a grumman cheetah. (AA-5) which has a bigger version of the same engine.
The most common engines in small aircraft (post war) are Lycoming and Continental. The vast majority of their engines are air cooled boxer 4's and 6's.
http://en.wikipedia.org/wiki/Contine...piston_engines
http://en.wikipedia.org/wiki/Lycomin...Piston_engines
kiwipeet is offline   Reply With Quote
Old 04-30-2012, 07:33 PM   #204
bart-nz
bart-nz's Avatar
Oddometer: 688
Mmmmmm....4 cylinder boxer 2 stroke
Some silly Kiwi put one of those in a bike, and came 2nd in the world GP's
Kim Newcombe. What a story....
bart-nz is offline   Reply With Quote
Old 04-30-2012, 08:31 PM   #205
igormortis
igormortis's Avatar
Oddometer: 1,304
Yup. Watch it here: http://www.nzonscreen.com/title/love...-and-loss-2007
igormortis is offline   Reply With Quote
Old 05-01-2012, 02:13 AM   #206
Padmei
enamoured
Oddometer: 3,604
Originally Posted by igormortis View Post
Watch the first half - the second half jst gets really depressing
Old 05-01-2012, 03:29 AM   #207
msmckeon
Just ahead of the sweeps
msmckeon's Avatar
Oddometer: 88
It is your basic (bottom of the range) model flat 4 horizontally opposed, a Lycoming O-235. The number refers to the capacity in cubic inches.
Yes - configuration is like a (king sized) VW.
msmckeon is offline   Reply With Quote
Old 05-01-2012, 03:43 AM   #208
bart-nz
bart-nz's Avatar
Oddometer: 688
You should try reading the book. Took me months, but worth it.
Yes Mark, I do know how to read.
Old 05-01-2012, 04:37 AM   #209
Mark_S
Fair Weather Faggot
Mark_S's Avatar
Oddometer: 1,777
a word a day is about the typical dr riders limit
Old 05-01-2012, 05:14 AM   #210
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
What
DR650 Wiki
NordieBoy is online now   Reply With Quote
Times are GMT -7.   It's 09:46 PM.
