Old 04-29-2012, 01:44 AM   #16
SS in Vzla. OP
Totally Normal? I'm not!
Oddometer: 1,029
Originally Posted by crashmaster View Post
Make sure you keep a couple of bungee cords handy for when you start jumping the bike, the tank flexes inward and the swing arm rips the metal mounting plate right off the tank.
Already have a deep scratch on my swing arm The tank is still in place and in one piece, so I'll look into mounting some kind of braket to keep it away from touching the swing arm
SS. '98 BMW F650 / '05 KTM 450EXC / '03 KTM 950 Adv
Caracas, Venezuela
SS in Vzla. is online now   Reply With Quote
Old 04-29-2012, 01:46 AM   #17
SS in Vzla. OP
Oddometer: 1,029
Originally Posted by Just Paul View Post
can someone please post the link to Lobbys tank install?
I own lobbys 990 now and the rear tank worked perfect for the last 3 years (taking the gas in the rear tank first when the petcock is turned on) .
I took the tanks off to install a scotts automatic chain oiler and check the valves and the fuel lines were rotting so I replaced them along with the tline and when removing the fuel line off the petcock those broke to because the fuel line was so hard... anyways after I got everything reinstalled I have the same problem now. The fuel light comes on with 1.5 gallons in the rear tank and 1.5 gallons in the front tanks.
this drives me crazy.
http://www.advrider.com/forums/showthread.php?t=424400
Thanks for the photo of the "bracket" ... I'll go that way
Caracas, Venezuela
Old 04-29-2012, 09:10 PM   #18
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 1,942
thanks for the link
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
THE BEST THINGS IN LIFE ARE NOT THINGS
Just Paul is online now   Reply With Quote
Times are GMT -7.   It's 10:19 AM.
