Old 04-12-2012, 04:24 PM   #2461
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
supermoto wheels to taiwan
Originally Posted by Bigtoe22 View Post
Hi Woody
Just wondering what the latest price is for supermoto 17" wheels for my Xchallenge, with RAD hubs, superlaced stainless parts, sealed, with tires and shipping to Taiwan?
Cheers
Zach,just informed me that he'll clue you in tonight,,for starters there are no billet hubs available,,hence we use th eoem units[which we have in stock]
FYI,, the Superlace n true etc will work just fine on them
same one year warranty and a free t-shirt or hat
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 04-17-2012, 09:13 PM   #2462
MJS
MJS's Avatar
Oddometer: 1,897
Woody,
Received the xt225 wheel yesterday. Looks awesome, thanks for the great job and quick turn around. I don't think my wife will be able to break this one.
And I really like your ad on that advlife website.
Thanks,
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 04-18-2012, 04:43 AM   #2463
Torbido
Oddometer: 6
Wheel Polish
Recently bought 2011 Bonneville with alloy wheels. Triumph couldn't advise if aluminum or alloy. Wheels have corrosion(?) specks. Specks are whitish in color. Tried Wenol, S100 metal polish, and Never Dull. None removed the specks but cleaned around specks. Boms Away has good write ups but figured if anybody could recommend a product you could. Thanks in advance.
Torbido is offline   Reply With Quote
Old 04-18-2012, 10:57 AM   #2464
Built to Last
Oddometer: 3,426
thanks for the kudos...
Originally Posted by MJS View Post
Woody,
Thanks,
yeah,i like how that one turned up,a collaboration between my internet wizzrd nd m'self..
regarding that wheel we built,,worry not there's not a one of the hundreds we've done that has veer returned for anything...
now if you're really happy here's alink for picsnd comments,,we like seeing your smiling mugs,,,it's kinda tuff building stuff for folks out there in the ozone...in the old days ,folks tracked me down,,i knew who they were and what they needed...you get the drift.. so here's a link
http://www.advrider.com/forums/showthread.php?t=646947
enjoy
woody nthe gang
Old 04-18-2012, 11:09 AM   #2465
Built to Last
Oddometer: 3,426
white specs on anodized Triumph Bonneville wheel
well without seing it ,,possibly send a hoto on the macro mode...my guesstimate ids that thee specks are chips out of the anodizing
FYI,,we see it all th etime in corrosive environments...we've found that whe we strip the old anodizing off and rebuff em theylook super fine,either re-anodizing or powdercoating will reveal how deep the corrosion actually went ,,,hence some folks just leave un-anodized ,,and maintain their wheels wit mother's or never dull,,,some use a quick coat of Xrystal clear krylon...protects a bit better than wax and can readily be removed by spraying the clear with carb cleaner and wiping it of,,buff/polish th erim and start over with another coat of Xtal clear
hope that helps for now
holler
woody
woody's wheel works screwed with this post 04-18-2012 at 11:18 AM
Old 04-29-2012, 04:38 AM   #2466
dakarchef
Oddometer: 295
Hi woody
Re BMW f650gs single
Can you lace a 17 inch rear rim on to the front hub of this bike. Looking to make a 17/17 sm setup and I already have a spare rear hoop.
K
07 F650 Dakar,09 Husqvarna wr144, 01 Husaberg Fe650, 01 Husaberg FC650
dakarchef is offline   Reply With Quote
Old 04-29-2012, 05:16 AM   #2467
Built to Last
Oddometer: 3,426
can rear 17'' rim of F650gs be used on front???
Originally Posted by dakarchef View Post
Hi woody
K
hi,,
we have a broad range of tricks to re-cycle/swap rims and hubs
everyhting from re-drilling nipple holes,,re-angling the nipple seats,,changing lace patterns to accommodate different indexing etc,etc
i believe in your case if the indexing is the same as the front you can get by with a custom spoke kit and re-angling the spoke hole and countersinking the rim to accommodate the different spoke angles,,,the rear hub is wider and bigger in diameter than the front
if we superlace or custom lace it,,that cost gets factored in ,,otherwise we charge $30 for this process
holler if we can help
woody
Old 04-30-2012, 03:00 PM   #2468
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
Got my Excel A60s on Thursay, and rode the bike for the first time yesterday...fantastic finish, quality and they look build for anything! Been wanting to say this for 5 years: finally got me some wheel-wood!
(currently on a business trip so pictures this weekend)
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 04-30-2012, 03:45 PM   #2469
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,982
Question Tubeless WR250R
No doubt this has been asked before, but I can't find it... so my apologies if you have answered it a thousand times.
Is there a good way to convert a Yamaha WR250R to run tubeless tires? If so what do you think is the best way?
I may have a line on a nice WR250R (have always wanted one), but since a ton of its use would be getting to-and-from the trails, and I already have all the pump, plugs, etc. to fix tubeless flats that I carry on my other bikes, I thought is might be worthwhile to do the conversion.
Of course, that assumes there are decent tubeless dual-purpose tires in 18" and 21"...
Also wondering if you are aware of any way to mount up a larger diameter front disc to the little Yamaha other than fitting the WR250X front hub?
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara screwed with this post 05-02-2012 at 08:18 AM
Dallara is offline   Reply With Quote
Old 05-02-2012, 01:00 AM   #2470
everett
everett's Avatar
Oddometer: 212
WR250R Excel A60's
Not sure if this has been covered. Sorry if it has.
Can Woody build me a set of Excel A60's for my WR250R?
I heard the hubs and rims don't match.
Thanks,
Everett.
everett is offline   Reply With Quote
Old 05-02-2012, 05:39 PM   #2471
Greenflyfarmer
I'm better now.
Greenflyfarmer's Avatar
Oddometer: 1,776
This winter I had Woody's build a new front wheel for my 08 990. The oem was ben tup! Well I took my first ride this weekend and the new 50/50 sticks much better on fire roads, much. In fact it was great. I did not feel the need to stand as much to get weight on the front.
Great improvement Woody's.
I ain't a going without my hog, my gun, my whisky and my Bible.
Greenflyfarmer is offline   Reply With Quote
Old 05-02-2012, 07:58 PM   #2472
Built to Last
Oddometer: 3,426
Thanks,
Everett.
DON'T WORRY;;;FRET NOT!!!
if anyone can you're talking to him
call Zach at the whel works ,number belowmmi#m in germany with äm family...
he'll take care of ya
prosit
wody
Old 05-02-2012, 08:01 PM   #2473
Built to Last
Oddometer: 3,426
tubeless on a WR250R,,,why not
Dallara
essezially the same answer as previous post:
prosit
wody
Old 05-03-2012, 12:51 PM   #2474
x-man727
x-man727's Avatar
Oddometer: 10
Originally Posted by woody's wheel works View Post
yes send it all in and when we return it we say we rebuilt your wheel on warranty....
holler when you are ready
woody
I read to ship my front wheel. is it cheaper to me if I cut the spokes and send only the hub?
And where I ship the wheel?
x-man727 is offline   Reply With Quote
Old 05-03-2012, 10:34 PM   #2475
Built to Last
Oddometer: 3,426
if you send your whole wheel,,you will have supporting evidence that you sent the wheel in for repair,,and at the same time we can inspect /analyse vour wheel,,confirm offset etc,,the long range savinng will offset the couple dollars extra IMHO..you all have pretty stiff import rates from what we hear,,nothing compared to the folks in Scandanavia
hope that helps
woodz
Times are GMT -7.   It's 03:38 PM.
