04-15-2012, 06:56 PM
#331 | |
Lost Armadillo in Heat
Oddometer: 142
Point taken. I did not mean it to read that I do not worry at all about being killed or injured. I am constantly doing whatever is in my power to prevent such a thing from happening. Unfortunately, sometimes that is not enough. So, while I do not want to be killed in such a manner, I do not let it keep me from riding and enjoying it (frankly, I am more worried about what may happen to my s.o. when riding two-up, since I can account for what I do and how I react to certain situations, but not her, and to have something serious happen to her would be personally devastating for me). That said, I have learned to put such things as FD failures well down the list of things to worry about when I suit up and ride, for the very reasons mentioned in my last post, and in this one. Btw--I generally enjoy reading your well thought-out posts. So keep em comin'
Geografo Current Rides: 2007 R1200 GS Past Rides: 1972 Yamaha 60 Mini-Enduro 1971 Yamaha 125 Enduro 1974 Suzuki GT 750 "Water Buffalo"--like a true water buffalo, big and heavy, but deceptively fast 2006 Harley-Davidson XL 883 (traded-in on Corolla... )
04-30-2012, 04:57 PM
#332 | |
XPLORER
Oddometer: 1,126
"If you're going to be stupid, you've got to be tough" -N.E.R.R. |
04-30-2012, 05:15 PM
#333 |
XPLORER
Oddometer: 1,126
Now, I would like to add, the roller bearing in the EVO Hex-head and on, is a sealed bearing, not bathed in gear oil as the previous FD's were. When BMW replaced the first bad roller bearing, the FD fluid and everything inside, checked out fine... I learned that BMW outsourced the roller bearing then, sometime in 07, realized they needed a better bearing.... well, I'm about to do another one, I hope..... we'll see what I find when I open her up!
06-13-2012, 07:08 AM
#334 | |
Mean SOB
Oddometer: 373
Last year at the BMWRA rally I met a rider with exactly the same bike as mine. A few years before, I am not exactly sure when, he told me he was in a bad single vehicle motorcycle accident where the cause of the accident was that his rear wheel came off his bike for no apparent reason. Is this the type of incident that would be possibly caused by a catastrophic final drive failure?
"I have approximate answers and possible beliefs and different degrees of certainty about different things, but I am not absolutely sure about anything." Richard Feynman, Scientist. |
06-13-2012, 07:25 AM
#335 | |
"Cool" Aid!
Oddometer: 41,488
There are multiple reasons for FD failures, and especially one following the other like yours. The original failure could be from poor initial assembly, overlaoding the bike, riding in very rough conditions, while overloaded, and getting water in the Fd through streem corssings. Or, it could simply be a defective FD from the start. As for a FD actually falling off, not unless the owner was so out of tune with the bike that he never noticed major self destruction impending. They do not simply grenade with no warning. Jim
06-13-2012, 10:52 AM
#336 |
Oddometer: 83
![]() Just picked up a 2012 R1200GS. Where do new BMW GS's stand in this thread's light?
06-13-2012, 10:55 AM
#337 | |
Oddometer: 144
Dude you're screwed....Better turn it back in
Rides: 2009 F650GS; 2010 R1200GS
06-13-2012, 12:26 PM
#338 |
Oddometer: 83
Somehow I doubt your conviction!
06-13-2012, 12:58 PM
#340 | |
"Cool" Aid!
Oddometer: 41,488
![]() Jim
06-13-2012, 01:23 PM
#341 | |
Tuscan rider
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here. Renting out motorbikes in Toscana, Italy Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index. IBA: 33616 |
06-13-2012, 01:40 PM
#342 | |
Mean SOB
Oddometer: 373
06-13-2012, 02:10 PM
#343 | |
Tuscan rider
That is, if you run your bike at about 200 km/h about 100 HP passes through the FD. 100HP is about 80 KW. So, at full power, you can expect a few KW (let us say 5) of heat to be generated down there. 5KW will boil 180 ml of oil in seconds. However, this is the full-power situation. Regardless of hard you ride your bike, the full-power situation is a few seconds at the time. Furthermore, the heat occur on the surface of the shafts. They have good cooling. One end connect to the hub of the wheel, the other to the shaft that passes up though the swing arm, all bearings are attached tot eh housing. Finally, quite some air passes by and keeps the house cool. I have tried it. After a 10 km run in 180 km/h (my 1150 didn't go faster), the FD was hot to touch but not at all boiling. I could touch it, but not let my hand rest on it. Obviously, reducing the volume from 220 to 180 (on the 12GS) didn't help on cooling. But when we talk 5KW, volumes that small without external cooling can hardly play any significant role in any case. [TaSK]
06-13-2012, 03:32 PM
#344 | |
Mod Squad
Oddometer: 53,450
One thing's certain, BMW got rid of the hole on the K1600. It remains to be seen when the watercooled boxer comes out if the FD has the hole or they do away with it. I'd be in favor of one less seal to leak, and many fewer of the sky is falling / my FD is leaking threads
ADV decals, patches & flag? Here |
06-13-2012, 05:13 PM
#345 | |
Oddometer: 4,474
Two Different Topics
I know, I know this has been discussed ad naseum but while a seal leak may lead to bearing/race failure if enough lube is lost and then a true "FD failure" might occur, a seal leak alone does not constitute a FD failure....yes, many have reported seal leaks but many have reported "stop right there" FD failures within the FD without seal leaks. Nothing will ever be gained by our endless posted speculations about 180 vs 220 ml or sub-standard bearings or incorrect lash/set-up or wrong lube [whatever in the hell that is] or overloaded [?] and mistreated bikes [that must be a joke] being the cause of the true FD failures. ONLY BMW can answer why FDs have failed over the years and continue to fail....but guess what boys and girls...BMW refuses to divulge the extent of the problem or the cause of the problem [s]. True story. I had a call yesterday from BMW NA Customer Service, they called me! An inmate had forewarded a PM email I sent him to BMW Motorrad. Motorrad in turn kick the letter to BMW NA. I had a great chat with the Customer Service Rep and asked him if BMW had ever released any information concerning the FD failure or if they were ever likely to do so....No nothing had been released and nothing could be expected. Why I asked. He said he honestly did not know and in essence that was above his pay grade. Oh yes, I asked if he owned a BMW...no, he owned two Yamahas. Hence, why I call BMW the "Black Hole of Information"; it goes in but never comes out. What waste of time...if we had the data we could make informed decisions. But then we might not buy BMWs. I would never again buy any BMW product, not because I don't love the performance of my '07 GSA but I do not trust the company and by extension the reliability of their bikes.
"In Wallowas" ==================== 2007 R1200GS Adventure " ...to explore off-road, alone in my case, way out in the boonies...that feeds the soul!"
Wallowa screwed with this post 06-13-2012 at 05:20 PM |
