04-26-2012, 08:36 AM
#16 | |
Oddometer: 29
You know from working on cars I wouldn't even have thought the block is aluminum. It certainly looks aluminum but I just didn't process that thought yet haha. Well that would make torquing a very careful practice indeed. Don't want to have to retap a block if I can avoid it.
04-27-2012, 08:40 PM
#17 |
Beemerholics Anonymous
Oddometer: 7,356
Most of us torque them to 25ft pounds, but do remember that if a fastener is oily, you'll need to reduce that figure by about a third.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
04-28-2012, 05:30 AM
#18 |
the thread-killer
Oddometer: 4,297
If you read the feedback for the seller, that should be enough reason to stay away.
That's what the feedback is for. In this case it explains alot about this fellows "quality". |
04-28-2012, 07:32 AM
#19 | |
Confirmed Curmudgeon
Oddometer: 3,900
Back in the day when I was a young buck, I took the book value of 28 literally and retorqued the heads frequently, even before valve adjustments. Ended up stripping 6 of the 8 studs, and 30 years later re-repairing those threads because I used a poor state-of-the-art insert at the time. Nowadays I retorque the heads infrequently, usually only when the rocker arms need to be removed ot adjusted. Live'n'learn...
'73 R60/5 Toaster |
04-28-2012, 08:40 PM
#20 |
Oddometer: 7,356
Funny, I always figured torque values were for clean, dry threads. Just checked, and neither the Haynes or Clymer says anything about this.
The 90S shop manual doesn't make a whole lot of sense to me on this point. It says: Tightening torques and preload forces Applicable only to bolts in accordance with DIN (a bunch of different ones follow) and nuts with a nut height of 0.8 X d in accordance with DIN 934 and exclusively for u ges = 0.14 (Bolts phosphate treated, nuts without aftertreatment or galvanized. Lubricated condition: either non-lubricated or oiled.) For cad plated bolts or nuts (u ges is roughly = 0.08 to 0.09) the tightening torque must be roughly = 30% less than in the table with the same utilization factor of the bolt material. Not applicable when another surface or lubricated condition of the thread is used or if there is a variation in the nut height. In such cases it is necessary to determine the values separately. When it says "either non-lubricated or oiled." is it referring to the nut? And under the Not applicable section is states "when...lubricated condition of the thread is used..." Seems something was lost in translation.
04-28-2012, 09:15 PM
#21 | |
because I can
Oddometer: 6,080
Myself and others I have known use to torque down heads to 28ftlbs no problem until I heard of everybody else stripping them. I now torque them to 26ftlbs per a BMW service bulletin. The bulletin was about reducing cylinder distortion on nikisil cylinders, not pulling the studs but . . . . I put 106,000 miles on a LS. Lots of fun! Good handlers but my setup always under steered. Siebenrock makes a cam for them. I would like to try raising the CR, a cam, and some carbs on one. Personally, I wouldn't go with a bigger bore. It's already short stroke enough IMO at 1.33:1. The same as a R100. And the shorter cylinders are my favorite part of them so I certainly wouldn't want to put a bigger engine in. supershaft screwed with this post 04-28-2012 at 09:25 PM |
04-29-2012, 04:59 AM
#22 | |
Oddometer: 3,900
Consider it in context: how often are you going to torque (or retorque) cylinder head nuts in a dry condition? 17 ft-lbs is an absurdly low value for head bolt torque. But use it if you want to... :)
'73 R60/5 Toaster |
04-29-2012, 08:07 AM
#23 |
Oddometer: 29
I've got a little update other than torque specs. I went cruising around for a few hours and noticed I have been hitting a false neutral between 2nd and 3rd. If I shift up from this neutral I go straight to 3rd. I will attempt to adjust the shifter lever because it has some play in it. I've read preloading the shifter lever helps too so I will practice that technique and see how it goes.
05-01-2012, 09:17 AM
#24 |
Oddometer: 74
welcome to the adventure of R65 ownership...
![]() have you signed up for the R65 forum too? http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl btw, is that ebay seat the one from Vietnam? |
05-01-2012, 10:53 AM
#25 | |
Oddometer: 29
A guy in a previous post mentioned the hondaclassic31 seller had terrible reviews and I can't entirely agree with that. He had about 4 reviews mentioning quality issues of a specific honda cafe racer seatcover and I would absolutely expect mediocre quality out of the seat I'm getting but as far as terrible reviews I don't see many. I'll sign up for the forum soon. |
