Old 04-30-2012, 10:06 PM   #1
Scribe OP
£Bob£
Scribe's Avatar
Oddometer: 7,417
Rotor problem: Why is this happening?
Front right rotor on my 950 Adventure. It looks like it is so close to the caliper bracket that it is actually scraping the rotor. Why would that be?
* I tried loosening the axle clamps and pumping the fork to align the legs. No difference
* Brake pads don't look wonky or unevenly worn
* caliper seems to slide just like it should
* Could I have bent the caliper bracket somehow? I have dropped the bike recently, though I don't see any obvious damage.
I'm stumped. What you got?
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 04-30-2012, 10:30 PM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Have similar issues on my -04, its the right side caliper scraping right? I simply push the front axle so its like 1 mm in the right side clamp rather then flush with it.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 04-30-2012, 10:30 PM   #3
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,091
Check that your axle is pulling in all the way. I've seen this problem before when there was a ding on the end of the axle, and it wasn't seating in the right side fork leg far enough.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 04-30-2012, 10:41 PM   #4
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,022
Your forks are still out of alignment. I'll bet the right fork clamp is hanging up on the axle.
Loosen the clamp, pry back the brake pads, kick the fork leg over, pump the forks without using the front brake, tighten the clamp, then check it.
If that doesn't get it back in line, you'll need to pull the front wheel and check whether the fork axle clamps are not lined up. Put just the axle in the left clamp first, then slide it back over to the right hand clamp (left/right is as you are sitting on the bike). It should slide right over with no hangups. You may need to slide one of the fork legs up or down in the triple clamps to get them exactly in line. Remove and nicks on the clamps that hang up the axle. Use a tiny amount of grease and try the assembly again.
"Son, you can't do both"
Old 04-30-2012, 11:13 PM   #5
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 855
I agree the forks are out of alignment, make sure your axle is lubed with a waterproof type grease and it should not be such an issue.
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 05-01-2012, 03:04 AM   #6
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,470
Yup, I'm with Zuber on this - the key part of his post is "pump the forks without using the front brake". If the brake pads are touching the discs, it'll stop the forks moving into their correct place on the spindle.
Furthermore, I try and nip up the spindle clamp while holding the forks in a slightly compressed position. If you let them extend fully everything can pop out of alignment again.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 05-01-2012, 03:20 AM   #7
Sumi
Sumi's Avatar
Oddometer: 1,799
Also make sure that you are using 950ADV spacers and they're installed on the correct sides..
I would think that it'd be nearly impossible to bend the caliper bracket... And if you've droped the bike recently, it's most likely that the forks are out of alignment, as others have said already.
Here is a good writeup on how to realign the forks (ofcourse you don't have to remove them, so just scroll down until the reinstallation part begins):
http://ktm950.info/how/Suspension%20...orkleg_rr.html
Old 05-01-2012, 04:28 AM   #8
zedtours
zedtours's Avatar
Oddometer: 362
Take out axle spindle and bevel off RH end as it burrs after being knocked in a few times.
zedtours is offline   Reply With Quote
Old 05-01-2012, 06:18 AM   #9
Scribe OP
£Bob£
Scribe's Avatar
Oddometer: 7,417
Thanks for the replies. On my way out to the garage to try again.
— Yoda
Old 05-01-2012, 08:38 AM   #10
1stiski
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,637
my 04., FOLLOW THE mounting procedures from the service book. Be sure your spacers are on properly. Never had that issue.
"04" 950 Adventure S 37,000+ miles
2003 Harley XL883 converted to CAFE (2013-14)
"Grim Brother" #1
1stiski is offline   Reply With Quote
Old 05-01-2012, 08:44 AM   #11
BoulderGuy
out ridin'....
BoulderGuy's Avatar
Oddometer: 433
As stated earlier, don't think your axle is in all the way. It should be 1 m or so inboard of the face of the aluminum, not flush which is where I would guess it is. Pull it and grease the crap out of the axle and try again. And yeah, follow the owners manual as to the correct way to install the front wheel......
BoulderGuy screwed with this post 05-01-2012 at 07:56 PM
BoulderGuy is offline   Reply With Quote
Old 05-01-2012, 11:07 AM   #12
newbaumturk
Oddometer: 89
I had same problem ....
My issue was largely due to the fork bushings being worn out causing the fork to not line up when compressed.
Also if the fork lengths are not the same it can cause issues
newbaumturk is offline   Reply With Quote
Old 05-07-2012, 08:37 AM   #13
Scribe OP
£Bob£
Scribe's Avatar
Oddometer: 7,417
Bingo! I deburred the axle and made sure it was in all the way and everything lines up all nice and pretty now. Thanks for the info
— Yoda
Times are GMT -7.   It's 06:08 PM.
