Old 06-27-2011, 05:51 AM   #121
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,452
Looking at the back of the bulb, the top diagram gives you the proper orientation.
With the bike off,, use a continuity tester to determine the ground. Then use a test light with the bike running to determine which of the other 2 are are low and high.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 07-17-2011, 02:52 PM   #122
OlyRider
Oddometer: 1,104
Trailtech conversions
Btt
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 07-18-2011, 04:29 PM   #123
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 1,469
Mounted on a Dirtstrom. Best of both worlds. Thanks!
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 09-19-2011, 12:53 PM   #124
bobbed06
Cavalera Conspirator
Oddometer: 981
Did you guys ever get a reflector cover designed for the open backside of this setup?
bobbed06 is offline   Reply With Quote
Old 09-20-2011, 07:15 AM   #125
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,452
Cyclops was working on that and if they have been as busy as myself, it may have gotten pushed to the back burner.
Call or email Daryll at Cyclops.
http://www.cyclopsadventuresports.com/
Old 12-07-2011, 09:28 AM   #126
jmangym
Explorer
Oddometer: 13
Bowl covers
Originally Posted by Pago Cruiser View Post
Just picked up Trailtech/Cyclops. Looks great, but the naked H4 reflector/housing really bugs me. The Cyclops guys indicated they are still working on a cover.
So the other day I was feeding the dog, and passed the light sitting on the table... Hmmm. While this may be rather simplestic, anybody done anything like this? Just need to make a companion flange, drill a hole in the back of the bowl for wiring, maybe drill some small holes in the bottom (or top, but I would like this to be waterproof) for heat, then powdercoat the bowl and the flange. Any thoughts?
Note: the site seems to have changed, so I can't post any pics; even though I deleted 900k worth. Anyhow, see some bowl options here:
http://i776.photobucket.com/albums/y...e/IMG_8436.jpg
http://i776.photobucket.com/albums/y...e/IMG_8435.jpg
Pago, did you ever get the bowl covers mounted? Any pics?
jmangym is offline   Reply With Quote
Old 05-04-2012, 08:09 AM   #127
Boatman OP
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,452
Bump,,,, been getting PM's lately asking if these are still available.
Yes, they are.
Times are GMT -7.   It's 03:11 AM.
