Old 04-13-2012, 08:00 PM   #1
rusty44 OP
rusty44's Avatar
Oddometer: 416
Teutonic qsl 1000 mile seat spring
I have only the seat for a Teutonic QSL 1000 Mile Solo Seat and am trying to make a bracket to fit my BMW R75/5.
I am lacking the spring.
Does anyone have any information on these springs?
What type/size of spring?
Where to get one?
Have one for sale?
Thanks....Al
rusty44 is offline   Reply With Quote
Old 04-16-2012, 10:19 PM   #2
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Darned things are near impossible to find. I've had three different QSL seats, luckily with springs. The spring is an odd ball "mouse trap" looking affair.
I've seen two different types of mounts. One was a little unstable. The one I'm currantly using was the better of the two designs.
I could pull my seat and take some photos of the suspension assembly if that would help.
The bracket is pretty simple....slides into the frame back bone tube, then clamps to the sub frame cross member. You'll lose your tool tray in the process as it needs to be removed for the mount to fit.
You could probably build a rigid mount and delete the "mouse trap" spring, or come up with some sort of alternate method.
I teamed up with a fabricator acquantance a few years ago and we toyed with the thought of reproducing some "knock off" QSL seat assemblies. He thought the spring would be the toughest thing to reproduce.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
bmwhacker screwed with this post 05-03-2012 at 05:47 PM
Old 05-03-2012, 03:16 PM   #3
Knee Dragger
Knee Dragger's Avatar
Oddometer: 100
I had a few of there seats before. I had a spring break on one of them, but I had a back up seat..so I was good. I had put them sidecar rigs useing 60's /2's with /6 drivetrains in them. I have been thinking a QSL 1000 might not be bad on my GSA.
Anyway.. Maybe some how you could use a car motor mount to take the place of the spring...
Knee Dragger is offline   Reply With Quote
Old 05-03-2012, 08:03 PM   #4
rusty44 OP
rusty44's Avatar
Oddometer: 416
While I was at an antique tractor show I had a "bright " idea.
Tractor seat spring!!
They're too big,but,a lawn tractor seat spring might work.
I just received my IH Cub Cadet 582 seat springs from Ebay and will report back....Al
Old 05-03-2012, 10:46 PM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,477
Can you find a picture?
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 05-04-2012, 04:47 AM   #6
rusty44 OP
rusty44's Avatar
Oddometer: 416
here is a picture.
the height was my main concern so the seller measured for me, 2" which I think is about right.
I can cut to length and I am going to put the springs side by side with space enough between them for the seat bolts to fit so I adjust the seat back and forth
That is the plan.
Any suggestions or criticisms are welcome,I'd rather measure twice and cut once ....Al
Old 05-04-2012, 08:14 AM   #7
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Originally Posted by rusty44 View Post
here is a picture.
That is the plan.
Could you make the picture smaller ?....
ABC# 1992
Old 05-04-2012, 08:44 AM   #8
rusty44 OP
rusty44's Avatar
Oddometer: 416
Here you go Mr. Smarty Pants
these aren't the ones I bought but, close, and the picture is bigger.
there are plenty of 2 inch Enfield type coil seat springs to mount on the back if needed..Al
rusty44 screwed with this post 05-04-2012 at 09:02 AM
Old 05-04-2012, 09:14 AM   #9
Boxer Metal
Mad Scientist
Oddometer: 3,477
go to an old iron working shop and have them made.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-04-2012, 10:00 AM   #10
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
If you use high grade steel and don't weigh 300 lbs. those oughta work....maybe even better than the originals that have a tendency to break.
ABC# 1992
Old 05-04-2012, 11:48 AM   #11
Boxer Metal
Mad Scientist
Oddometer: 3,477
I smart metal person could make them out of mild steel and then temper them so they wouldn't break.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-05-2012, 04:42 AM   #12
isdt BMW
willserv@aol.com
Oddometer: 252
solo spring
I broke mine years ago, couldn't find one so I welded it back together. Springs are cheap, setup on a winding machine is the money. A Ural rubber seat or sidecar suspension unit would work. I heard that a Volvo motor mount could work. I looked at a couple of farm equipment places, but no help.
isdt BMW is offline   Reply With Quote
Old 05-09-2012, 07:23 AM   #13
rusty44 OP
rusty44's Avatar
Oddometer: 416
WARNING!!!!!!
Anyone with Fabrication skills may want to look away!!!!!!
I tack welded my QSL seat frame and will soon be fitting the spring on it.
Old 01-23-2013, 08:14 PM   #14
PoorPete
PoorPete's Avatar
Oddometer: 2
Repop Spring
I know this thread is a bit old, but I thought I'd pass along info on a company called Phast by Phillips that is making repop seat springs for the 1000 mile Teutonic Seat:
http://shop.phastbyphillips.com/1000...1000Spring.htm
A friend in Tampa ordered one and said it is great, so I'm ordering one, too.
PoorPete is online now   Reply With Quote
Old 01-23-2013, 08:20 PM   #15
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,344
Thanks for the link. Not too many options to replace the original part.
Luckily mine is still "hanging in there" after all these years / miles.
ABC# 1992
Times are GMT -7.   It's 08:36 PM.
