Old 05-11-2012, 05:52 PM   #17671
frog OP
frog's Avatar
Oddometer: 2,771
Originally Posted by miatre View Post
The noise increase's with speed.
So.. I took the valve cover off, poked and prodded. The valves are in tolerance all the way around. I cycled the motor through the strokes via the timing mark access, and didnt get the loud clank but a small one. It was caused by the compression cam. I took this out completely to eliminate probable causes.
I hooked the battery up and cycled the engine through use of starter motor. No loud or small clank.
I put an oil collector up to keep oil from everywhere and put the spark plug in and started it. I get loud clank. The noise seems to happen with a bit more rpm than turning by hand or electric starter.
If i was a guessing person I would now say it has something to do with the exhaust lobe/rocker arm.
Im too the point of completely disassembling the top end and starting again.
Here is a a hard description of the cycling of the cam. From 7-5:30 the cam moves smooth. Even with contact to the exhaust lobes its smooth. From the moment there is contact with the intake lifters there is 2 small pressure restrictions and then its smooth. Does this sound normal, about the pressure points on the cam lifters?
Thanks for the help guys and sorry for plugging up the BS thread with my tech questions.
Is the clank slower or faster Hz then the "pop" of the exhaust coming out the tailpipe?
Thank you MX1WEST, Highway Dirt Bikes Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
frog is offline   Reply With Quote
Old 05-12-2012, 12:34 PM   #17672
miatre
So yeah about that.
Oddometer: 88
Not certain what Hz is.
Well if you want a mechanics drama story.. read on. If not the updates are at the bottom paragraph.
My CRF Short story. Bought the bike with a hot cams in it. I rode the bike last season on and off and noticed the burning of the oil and often hard starts. Checked the valves probably too late and they were way off. I decided to open the machine up to see what would cause the burning and was expecting to replace piston and rings. Wrong. I have some cracked and missing valve seats hence the purchase of the new 250 r head. So read the prior posts to understand the current assembly experiences.
Well late last night i decide to pull out the current hot cams and replace it with the stock cam that was given to me by prior owner. Assembled it, started it, and wham... we are good to go, it purrs as it should. I should have stopped there. But no.. i wanted the spiffy more powerful cam and was curious as to the problem. I stopped working and waited until this morning. I took it out and measured tolerances between the 2 and seen they had big differences. I reduced the shims by one as I had installed them more on the tight side and not the loose side. Got the hot cams back in and buttoned up and started. Crazy loud same drive me crazy noise. I say screw it and start to put the Honda original on in. Once that decision was made i was happy with an end in site. In the process of assembly i drop the cam chain. No biggie get a pick an pull it up and re-assemble as I have done no less than 10 times before. button it up and go to turn it over by hand. It seizes up.. WTF
I go look at the marks and they are off. pissed as hell i uninstall everything and reassemble everything verifying everything 2 times. button it up and turn it over. It seizes up again. Again... wtf. I step away to consider my assembly and think i must have dropped something. So i go to disassemble the cam and chain to rotate the bottom end alone. With the cam off and turning the crank it locks up. Turns out i dropped the chain off the bottom gear. So i pull off the left hand assembly to realign the cam chain and leave the bottom case off during the whole process. Get the chain cam and other bits and pieces on yet again and rotate it by hand. Boom we are golden. Again.. end in site, again. Well i button up the bottom left hand side again and check everything again then rotate it again and all is smooth. Its now time to hear this baby purr.
I add oil my temp oil splash guards and insert the spark plug wire and turn the key push the e-start button and the motor spins and spins. It spins so nice with the starter pushing it. Problem is it should be running like the other 7 times it has in the past 24 hours after being all buttoned up.
Frustrated, I check fuel, yup got fuel. Check air, yup not in a void of that at the moment. check spark, no spark. Im assuming I did something to the wiring along the way when I removed the bottom left hand case. I reseated the connections and checked with prod light and nothing. So now I am off to get a multi meter. Fun stuff. Thanks again for the suggestions so far.
miatre is offline   Reply With Quote
Old 05-12-2012, 01:35 PM   #17673
frog OP
frog's Avatar
Oddometer: 2,771
Hz=frequency. Sometimes you can pinpoint an engine noise based on how many revolutions the engine does per clank or knock. The valves, piston/crank, cam chain etc all move at different speeds.
257x Solo Baja 1000
Old 05-12-2012, 02:29 PM   #17674
miatre
So yeah about that.
Oddometer: 88
I understand now. Thanks for the explanation and it makes sense.
Old 05-12-2012, 05:05 PM   #17675
frog OP
frog's Avatar
Oddometer: 2,771
Did an oil change on the ktm today. Its a little more involved then a jap bike.
257x Solo Baja 1000
Old 05-12-2012, 06:09 PM   #17676
SuperSize
Oddometer: 152
KTM manual states:
Step 1 remove footpegs
XR650R
WR250F
Super Tenere
SuperSize is offline   Reply With Quote
Old 05-12-2012, 06:29 PM   #17677
harcus
harcus's Avatar
Oddometer: 1,317
Looks like you changed the oil to air...Lighter that way...
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 05-12-2012, 06:48 PM   #17678
harcus
harcus's Avatar
Oddometer: 1,317
Spring
Since spring is here it is time to tune up the BADB. Here is the start...
The front wheel resembled a decagon so it was replaced with a rounder version from Warp 9. This is a 1.8 in wide rim vs the stock 2.2 in item. Theoretically much tougher. Also, a new 606 replaced the howling TKC80...
And, since the 908 had become a slick, a new Motosteel Teraflex was installed...
I read every tire thread on this forum. There was absolute consistance: no one agreed on anything. So, my conclusion was...pay your money & take your chance.
It will be interesting to see how the T'flex does. These knobs are .76 in high & quite long. Will they stay attached on a 90+ HP BADB? At least it is 1/2 the price of a 908 and they are quieter on pavement that the previous combo. As always, this is a test...
PS: I have a plow on order.
Old 05-12-2012, 07:56 PM   #17679
HickOnACrick
Groovinator
HickOnACrick's Avatar
Oddometer: 2,507
Is Warp 9 making wheels for BADBs now?
KTM 500 XCW, BMW K1600GTL
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
HickOnACrick is offline   Reply With Quote
Old 05-12-2012, 08:08 PM   #17680
frog OP
frog's Avatar
Oddometer: 2,771
With 908s costing more then an expensive hooker I'll be interested in what you think of it.
257x Solo Baja 1000
Old 05-12-2012, 09:18 PM   #17681
harcus
harcus's Avatar
Oddometer: 1,317
So to speak. They got the DID rim from Buchanans & anodized it here, laced it on. Nice work, nice wheel. The wheel & tire all balanced in within 1/2 oz. I think they have long term plans to fab their own rims but they are not there yet. Kevin says he has been running this same rime for some time on his BADBs & they seem to stand up better than anything else.
So far, so good...
Old 05-12-2012, 09:20 PM   #17682
harcus
harcus's Avatar
Oddometer: 1,317
You apparently know more about hookers than I but I will keep you posted.
Old 05-13-2012, 09:45 AM   #17683
a1one
a1one-numero uno-saucy
Oddometer: 303
Eh? BADB Acronym or whatever
I googled BADB and the only google hits were Utards and ADVRider regional forums proving you guys are making up this shit up. BADB sounds like 'Bad Boy' or 'Bad Bike' but either seems fitting considering all the lewd and crass postings and
orange parts namely KTM spread all over this forum. 'Bad' can mean 'good' like we learned from the gangster rappers of past so don't get bent. Pretty soon the Utard thread will have its' own bike gang ebonic is what I am predicting and you're all criminals anyway! Happy Mothers Day brothas
a1one - 1 definition - numero uno. ... A1 Grand Prix · A1 Sauce · A1 Thick-N-Hearty NATIONWIDE·
a1one is offline   Reply With Quote
Old 05-13-2012, 10:33 AM   #17684
HickOnACrick
Groovinator
Oddometer: 2,507
Originally Posted by a1one View Post
Happy Mothers Day Bitches!
Fix'd...er, I mean...translated to Utardish.
950 SER 300 XC
Composites 101
Utarded in Baja
Circumcising Utah
Old 05-13-2012, 03:08 PM   #17685
The Walrus
Gone and back again.
The Walrus's Avatar
Oddometer: 8,951
HickOnACrick • Today 10:33 AM
a1one • Today 09:45 AM
harcus • Yesterday 09:20 PM
Bitches, hookers and Big Ass Dirt Bikes (registered trademark by TrailTwister).......
You FF's been overeducated....and I'm starting to feel at home again.....in the sandbox.....
Everbody's preachin' at me that we all wanna git to heaven, trouble is, nobody wants to die to git there.-BB King
Reality is what does not go away when you stop believing in it. -Philip K Dick
I wanna be skinny, but my ass is too big. - Charles Barkley
When choosing between two evils, I always like to try the one I've never tried before. - Mae West
Experience is what keeps a man who makes the same mistake twice from admitting it the third time around.
The Walrus is offline   Reply With Quote
Times are GMT -7.   It's 07:59 AM.
