Go Back   ADVrider > Riding > Mapping & Navigation
Thread Tools Search this Thread Rating: Thread Rating: 468 votes, 4.94 average. Display Modes
Old 05-17-2012, 10:31 AM   #3526
Tourmeister
What's that funny noise?
Tourmeister's Avatar
Oddometer: 1,065
Originally Posted by moto-treks View Post
You can update the maps to the GPS directly assuming the map update program can access the server. I prefer then installed in the computer.
Have you tried turning off the internet from your computer? Just an idea but I would think the install program should install without an internet connection.
The install program accesses the server to do its verification stuff, kind of like the unlock codes from older versions of the map software. On my two desktop computers, it would run, make the connection, the GPS had to be hooked to the computer, it would prompt for the code on the back of the DVD package, and finally it would install and activate the maps for that GPS. So I am pretty sure it has to have internet access.
Scott Friday
05 BMW R1200 GS - 10 KTM 530 EXC
Two Wheeled Texans
Tourmeister is offline   Reply With Quote
Old 05-17-2012, 10:48 AM   #3527
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,601
Have you called Garmin customer service yet? Powered your router off/on? Turned off web blockers/anti-virus/malware software? Are the XP service packs up to date? Someone else had this exact problem a couple weeks ago and the solution was in this thread. I would search for that interaction in this thread...
The other optional solution, since it sounds like you already have the maps loaded on the Montana is to just use Basecamp which does not require CNNA to be loaded onto your laptop. Basecamp will recognize and use the maps installed on the Montana so your laptop does not have to have CNNA loaded onto it, but you would have to use Basecamp. Basecamp is just as easy as Mapsource for creating simple routes as you describe, so that is a viable option if you run out of time before your trip and cannot successfully load the CNNA DVD onto your laptop.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance screwed with this post 05-17-2012 at 11:08 AM
FatChance is offline   Reply With Quote
Old 05-17-2012, 10:57 AM   #3528
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,808
You are right. I just tried the install with the network shut off. That sucks! what if you don't have internet?
Well, I'd turn off my fire wall on the PC and try again. If that fails I'd move the PC to the DMZ of your router.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 05-17-2012, 11:38 AM   #3529
Tourmeister
Oddometer: 1,065
I have not called Garmin yet. That usually results in LONG hold times, which I can't do while at work. I only started messing with this last night around 11:00pm. As to all the other questions, yes. I did all those things, including all the latest XP updates, JAVA updates, Adobe updates, and every other update that I could find, hehe. XP firewall is off, Anti-virus is off. The one thing I did not try to do was hook the laptop directly to the DSL modem.
I've never messed with Basecamp, so let me see if I understand. I can load the maps from one of the desktops that has CNNA 2012 installed onto my unit. Then, I can install Basecamp on the laptop. Then when I hook Basecamp to the laptop, it should use the maps from the unit? If so, that is may solve the problem for now. Is Basecamp free?
Thanks for the suggestions.
Scott Friday
Two Wheeled Texans
Old 05-17-2012, 11:50 AM   #3530
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,974
I have not called Garmin yet. That usually results in LONG hold times, which I can't do while at work. ...
Wait times with Garmin are usually only 3-5 minutes these days. That's all I spent waiting the last two times I called them, this year.
And yes, if you can get the maps on the gps some other way, then Basecamp should be able to see and use the gps maps when the gps is connected to the computer.
Basecamp is free.
Old 05-17-2012, 11:53 AM   #3531
Tourmeister
Oddometer: 1,065
Basecamp is free.
So as long as the maps are already on the GPS, then I should be able to use any computer with basecamp installed to create routes just as I would in Mapsource? I'll get right on installing Basecamp on the laptop. Thanks!
Scott Friday
Two Wheeled Texans
Old 05-17-2012, 12:18 PM   #3532
Tourmeister
Oddometer: 1,065
One more question. Is there any advantage to loading smaller sections of the total map set versus just loading the entire map set at one time? For instance, if I am going on a trip, does the unit process any faster if I only create a small map set based on the area where I will be on the trip versus just always having the entire country loaded on the map? I generally like to have the Topo maps loaded along with the City Nav maps for when I am exploring out of the way places and I frequently switch back and forth between them. Does it slow things down on the unit itself to have the whole map set for both the Topo and CN on the unit all the time?
Scott Friday
Two Wheeled Texans
Old 05-17-2012, 02:48 PM   #3533
Tourmeister
Oddometer: 1,065
I am sure I am missing something, but I have Basecamp installed on the laptop, have the GPS plugged in and Basecamp sees it, but for the life of me I cannot find the maps!? I can see all of my routes and tracks. Under "Devices" it shows the Montana 600 and under that it shows, "All Data" "Memory Card" and "WorldWide Autoroute DEM Basemap". I have a 16GB card in the unit. That is where I have my Topo map and CNNA 2012 map stored. Do the map sets need to be stored on the internal memory in order for Basecamp to see them?
Scott Friday
Two Wheeled Texans
Old 05-17-2012, 03:10 PM   #3534
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,601
It should not matter if the maps are on the memory card or internal memory. You should be able to go into view>map product and select the map set you want to use from the Montana. Sometimes it takes a couple minutes for Basecamp to recognize the map set so start Basecamp, plug in the Montana and walk away for 5 minutes, then check. Is the CNNA map set that you loaded onto your Montana listed there? That works for me. If it doesn't, when you go into map setup on the Montana, is the CNNA map set listed there to enable/disable? Is CNNA enabled on the Montana?
Durango, Colorado
Old 05-17-2012, 03:32 PM   #3535
AirLock
Adrift
AirLock's Avatar
Oddometer: 24
Share Wireless Update
So i though i would post this in case someone found this thread having the same problem. Yesterday i deleted all tracks and waypoints from my gps. I then reloaded them from base camp, sending and receiving seems to be working reliably now. Looking at the files i noticed some of the tracks did not have the same number of points as they did in base camp. It seems one of the version of base camp or firmwares on the gps caused a loss of data during the transfer to the gps. It's working now...
AirLock is offline   Reply With Quote
Old 05-17-2012, 03:53 PM   #3536
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,808
BaseCamp uploading map from Montana
I just loaded a map img file onto my Montana that was not previously loaded in BaseCamp. When I opened BaseCamp and plugged my Montana in, BaseCamp recognized the GPS was plugged in and started reading the map from the Montana.
Moto-Treks
Old 05-17-2012, 04:22 PM   #3537
Tourmeister
Oddometer: 1,065
I finally got CNNA 2012 to load. Kaspersky Anti-Virus does not like to be disabled and kept re-enabling itself and screwing up the connection to the server but nothing else I was doing on the net.... I finally just shut the stupid program down and tried one more time and it finally worked. Sometimes it just sucks to be me
Anyway, CNNA shows up in both my Mapsource install and in BaseCamp, but it is not pulling it off the GPS as some of you mentioned. I never could make that work, even after moving the loaded mapsets from my external memory card in the GPS to the internal memory. Doesn't really matter now though. I should be good for the trip.
Thanks for the suggestions and patience with my fumbling. Basecamp looks pretty cool so I will keep playing with it anyway.
Scott Friday
Two Wheeled Texans
Old 05-17-2012, 04:55 PM   #3538
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,358
Trying to create a new profile.
But I go to Setup
Then to Profiles
But I have no "+ Profiles" at the top
Just list of the current profiles available
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 05-17-2012, 05:23 PM   #3539
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,808
But I go to Setup
Then to Profiles
What version of the Montana software are you using? You might try a master reset and see it the "+" returns.
Moto-Treks
Old 05-18-2012, 06:04 AM   #3540
cablebandit
Web Adventurer
cablebandit's Avatar
Oddometer: 706
Montana Power Consumption
Does anyone have an idea, or a way to measure, how many milliamps the Montana draws in the rugged mount with the screen brightness cranked all the way up?
I left mine on for a day or two with the bike parked and came back to a dead battery. I know my old 60CS didn't draw too much, but the back-light was also nowhere near as bright as the Montana.
IBA #33260
cablebandit is offline   Reply With Quote
Times are GMT -7.   It's 06:48 AM.
