04-30-2011, 02:52 PM
#1 |
Oddometer: 3
Honda CB350 losing power at higher RPMs
Hey yall. So i've been wading thru the internet the last few weeks trying to solve the riddle of the month. I've been seeing a lot of information and am hoping someone can help pin down what might be going on with my bike.
Basically i can get it to idle fine but when it hits beyond 4k it loses power and starts to make strange noises as if maybe its out of sync of something. I'm new to bikes in general but have learned a lot about mine in the last month as I've thus far: changed the oil and cleaned the centrifuge changed the spark plugs set the points and timing cleaned and oiled the spark advancer cleaned the carbs and set to manual settings the carbs open at the same time and the mix and idle screws are set equal so im not sure how else to sync them. i do notice that the left exhaust has more pressure coming out of it. oh and its a 1973 Honda CB350G if that helps. anything helps! thanks! |
04-30-2011, 03:04 PM
#2 |
SILENCE.....i kill you
Oddometer: 796
Make sure you gas cap is venting properly. Next time you have it oiut and are running it up, have the gas cap loose to allow more air in. You could have a partial obstruction.
Other thing could be bad diaphrams in the CV carbs. Pull the slides, clean them good, then use WD40 and spray liberally on the top side so it puddles. Check for leaks on the bottom side.
2004 Harley Sporster 1200C, 2001 Ducati M900, 2001 Honda XR650L, 1994 Harley Heritage, 1978 Honda CB750K with sidecar, 1977 Moto Guzzi 850 LeMans, 1976 Honda CB750K, 1965 Honda 305 Dream, 1973 Norton 850 Commando, 1971 Triumph Trophy 650, 1970 Honda Trail 90, 1970 Triumph Tiger 650, 1973 Honda Z50, 1984 Yamaha Virago 1000, 1981 Honda Passport 70, 1970 Suzuki T250, 1971 Yamaha RT1 360 |
04-30-2011, 03:14 PM
#3 | |
Oddometer: 179
recheck your timing with an automotive type timing light. set your valves. its likely to ba a carb issue. i think your plug read may reveal wet plugs.but study plug reads and you will learn alot. good knowledge for anything with spark plugs. is there a mouse nest in the muffler or air filters... http://www.advrider.com/forums/showthread.php?t=189436 - check in there too |
#4 |
REMF
Oddometer: 8,546
I think the books actually say to synch them by judging how much is blowing out of each exhaust
I just did as you did.I second the notion of checking the carb diaphrams - I've seen a lot of them bad on 350 twins. What exhaust is on the bike? I had a '69 CB that I put different mufflers on. It would cut out at higher rpm, I think I ended up going richer on the main jets.
Mike S. '09 Bonneville Black AMA MSTA STOC http://autos.groups.yahoo.com/group/...orcycleriders/ |
04-30-2011, 08:34 PM
#5 |
Ran when parked!
Oddometer: 373
Try pedaling faster thats what I do
Motorcycle = Mind eraser 78 R100/7 / 70 CL350 / 71 CB350 94 Duc 900ss / 63 Suzuki 80 K10 |
04-30-2011, 08:55 PM
#6 |
We are the luckiest guys
I had a couple of CB350s when they were new, a '68 and a '70, as best as I remember.
Here are a few items that I experienced: * One problem in my experience was similar to yours, no power at mid-to-higher RPMs. The plugs were dark and for a while I was convinced that somehow the mixture had gotten richer all on its own. Of course it hadn't. The problem was very high resistance in the spark plug caps. New caps solved the problem after about a month of head scratching. * Another problem was starting difficulties. Turned out that I had set valve clearances too tight and burned several valves. * One of the bikes developed a vibration and noise. Oddly, the alternator rotor had started to break up in small pieces and was out of balance. * The points can be tricky to set and don't seem to maintain their position for any length of time. Often, misfiring at higher RPMs can be traced to bad points or point-springs that have lost their tension. New points are cheap insurance and then check and re-check timing. Good luck. |
04-30-2011, 09:05 PM
#7 |
Circling the drain
Oddometer: 153
Maybe check the gas flow through the petcock[s] [maybe the tank screens are dirty/full of rust] Are the petcocks vacuum operated [maybe closing down if you are under load and engine vacuum drops] Air cleaner clean ? Points adjusted ? Advance working ? [timing light]
Too soon old......Too late smart. Paved roads are another example of wasteful govt. spending. [borrowed form a local off-road race team] The hardest lesson I've had to learn is to keep my mouth shut. [still working on this one.] |
04-30-2011, 10:40 PM
#8 |
Oddometer: 114
So, at the risk of being captain obvious... Are you sure the choke is off? That means the choke lever is down? I only ask because, well... I got a bit confused when I first got my CB350... thought it was running like crap, turns out it ran a *lot* better with the choke off. And I'm not the only one this has happened to, so I mention it just so you make sure, not to insult you:)
05-03-2011, 09:35 AM
#9 |
Oddometer: 55
^^ What he said. I screwed with mine for 2 days before finding out that the bike was pulling the choke "ON" when i rode it. It would run perfect until it hit 4,000 rpm then it would start poppin and fartin. Ziptie the choke open and go for a ride. I promised I wouldn't tell anybody what was wrong with mine to keep from lookin like a goober.
05-03-2011, 09:42 AM
#10 |
PUI Offender
Oddometer: 8,381
Battery! The CB has to have a strong battery to run properly.
If the battery is weak, it will lose spark to one cylinder and bog at high RPM.
Southeast Weather Map "I might as well keep going, there's no 'effing way I'm going back the way I came" Moran Nation 21 Club. |
05-04-2011, 02:49 PM
#11 |
Oddometer: 3
thanks for the replies!
but nothing worked!
with everyones suggestions i have (on top of what i had already done) blew out the stock, reusable air filter with compressed air cleaned the fuel petock filter and installed inline fuel filters made sure the choke was closed pulled the diaphragms and inspected (they were in good cond) set the static timing and point gaps checked the timing with a timing gun (fine at idle, though not hitting the advance area at all when i rev it gets just before it) put in new plugs and adjusted the carbs again (the book says to get the right idle then toy with one of the mix screws to get that carbs max RPM then go back and forth until the mix is optimum and the idle is 1200 with equal exhaust pressure. messing with the mix screws didnt seem to do much so i left them at factory setting (3/4 out) and just messed with the idle screws until the exhaust pressure was equal at 1200) the exhaust smoke is not colored but it still does it! if i go much beyond 4k it actually dies when i release. the battery should be pretty well charged but i guess ill charge it again. the only other thing is that the advance must not be working right and not allowing the spark to hit when it should. the plugs are coming out dark and powdery-ish which i know means they are rich or not sparking on time. the thing is i checked the advance. i cleaned it and gave it a couple drops of tri-flow lubricant. the springs seemed strong. maybe i should stretch out the springs a bit? thats all i can think of. any more ideas? thanks! secondbreakfast screwed with this post 05-05-2011 at 10:47 AM |
05-18-2012, 06:03 PM
#12 |
Oddometer: 1
Hey did you ever get your Scrambler running? I just picked up a pretty sweet '73 350 Scrambler with low miles and it's got a similar problem--idles all day long, but once I drive it and get up to 4,000 RPM or so, it loses power and almost sounds like it's missing.
I haven't yet replaced the contact points or taken apart the carbs to clean them out (just new plugs, new oil, carb adjustment, new battery) but I plan to do carbs next. Found this thread and I thought I'd see if you got your working cleanly. |
05-20-2012, 06:30 PM
#13 |
Thumper Crusader
Oddometer: 1,024
For both of you, I'd check your carb boots. Old rubber tends to crack. Pull your carbs off and get a good look inside. Any sort of air leak or tear in those boots will wreak havoc.
Second thing to check would be your air filter setup. Things like to live in there. A friend of mine had an XT600 that would do the same issues; we pulled the airbox, and sure enough, found a host of things in there, including a rats nest. Check for leaks in your air boots coming off the carbs as well.
"Living just to keep going, goin' just to be sane." - The Black Keys I prefer kick starters, air-cooling, and carburetors over anything. |
05-20-2012, 08:12 PM
#14 |
Rumble, rumble
Oddometer: 260
Have you done a compression test yet? I would start there.
TC Lead us into the land of Dirt and Beer. |
06-01-2012, 07:17 PM
#15 |
Oddometer: 122
advancer
Check the advancer behind the points plate. I have seen them stuck. Note how they are assembled before you take them apart cause you can get them 180 off.
