05-11-2012, 09:56 PM
#46 | |
Sporting Foole
Oddometer: 27,595
Satan's nine-fitty is back together and workin well according to Stewy. ![]() Drif might get to ride this thing tomorrow afternoon. ![]() Check yer freewheel rotor bolts. just do it
There is absolutely NO EXCUSE for what I'm about to do! The Second Amendment - it ain't about duck hunting. You heatherns needs some churchin up - http://www.landoverbaptist.org/ |
05-11-2012, 09:59 PM
#47 |
Sporting Foole
Oddometer: 27,595
verstehst du?
05-25-2012, 01:56 PM
#48 |
Oddometer: 161
uuuh....I'm about to replace my starter torque plate...
What does the conventional forum wisdom say about this...to just check the torque values (and possibly break the locktite seal) or to pull the bolts, clean and retorque with 648? |
05-25-2012, 03:22 PM
#49 |
MotorcycleMayhem
Oddometer: 2,154
remove bolts, clean both thread surfaces throughly, reapply 648 liberally to bolts, install and torque to spec.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla 2008 KTM 690 ADV- 2006 KTM 970 frankinADVsmSD ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
05-25-2012, 05:03 PM
#50 |
Oddometer: 161
Thanks for the info...is the problem that these bolts were not 648'd at the factory or that the locktite starts to lose it's effectiveness after a certain amount of time?
05-25-2012, 06:13 PM
#51 |
Oddometer: 161
OOH...also, it seems difficult to find 648 locally, is there a permatex equivalent?
05-25-2012, 07:24 PM
#52 |
Oddometer: 822
648
Can get it easily on the web. This is some serious shit
05-25-2012, 08:56 PM
#53 |
Nothing to see here.
Not having mine apart ever I was wondering if the gasket is one of those that must be replaced or if it will survive r&r. I realize having one I on hand is a good idea.
05-26-2012, 06:02 AM
#54 |
Oddometer: 209
Safety Wire?
Can these bolts be safety wired? Haven't opened mine up yet and a quick search didn't find any pictures that would tell me. If there is room enough that the safety wire wouldn't interfere with anything I'd buy a set of bolts and have them drilled for wire and replace the existing bolts. With locktite 648 and safety wire there'd be no worries. Has anybody done this?
"Life is either a daring adventure, or nothing." -- Helen Keller Stranger 315 '04 KTM 950 Adventure S '04 BMW R1150RT |
05-26-2012, 06:56 AM
#55 | ||
MotorcycleMayhem
Oddometer: 2,154
05-26-2012, 07:02 AM
#56 |
MotorcycleMayhem
Oddometer: 2,154
05-26-2012, 07:14 AM
#57 |
Oddometer: 161
Thanks for the tips, H2W!
I did a search and found that Permatex sleeve retainer is a similar product and possibly easier to find locally. |
05-26-2012, 10:41 AM
#58 |
Oddometer: 294
Hole Punch the bolts
These stator bolts is a cell known issue on V-twin aprilias and we use locktite together with hole punching the side of these bolts, to prevent any movement
05-26-2012, 12:03 PM
#59 | |
Sporting Foole
Oddometer: 27,595
McMaster Carr's got it. I ordered a bottle for SStewart and I one day, had it the next. Not sure why everyone is convinced it's so hard to get?
05-31-2012, 09:22 PM
#60 |
Oddometer: 161
FWIW...I just did this tonight on my 2006. I took one bolt out and it was definitely 648'd. I decided to not bother the rest of the bolts and re-648 the one I took out and torque down to 15 nm.
