Old 05-26-2012, 04:00 PM   #1
Tragic Image OP
Tragic Image's Avatar
Oddometer: 242
Suspension theory question.
So, about 2 months ago I bought an 04 525 EXC. I've gotten about 20 or so hours on it, roughly 250 miles or so? Really just familiarization miles.
This is my first dirt scooter, and so I'm pretty new to alot of the ideas present within.
Today, I decided that while I was doing general maintenance I would give my suspension a solid once over and verify the original settings via the owners manual.
I noticed that on the bottom of the forks, the two adjustment screws were not adjusted Symetrically. The right side was about 5 clicks ahead of the left. I balanced them out.
Next I came to the rebound dampners. Left side was 10 Clockwise clicks from the stop. Right side was in a nominal position.
There were issues with the rear as well, but not as confusing to me.
Did I undo some sort of suspension voodoo that the previous owner performed? Was there a specific result that he was trying to achieve?
He probably weighed in at 280+ lbs, and the bike is sprung with all Original Equipment. Has approximately 30 total hours on the bike.
Tragic Image screwed with this post 05-26-2012 at 04:42 PM
Tragic Image is offline   Reply With Quote
Old 05-26-2012, 04:26 PM   #2
yzmaico
Slacker
Oddometer: 314
I would have the suspension sag checked for your weight first.
You might need springs.
I would have the suspension serviced, at least a fluid change.
Mess with the clickers last.
yzmaico is offline   Reply With Quote
Old 05-26-2012, 04:41 PM   #3
Tragic Image OP
Oddometer: 242
thanks.
my question was "why did the last guy do this".
I'm not adjusting the clickers to get it to match my weight. I'm returning them to the factory settings. MY weight is within the acceptable range for the spring rates I have now, previous owners weight was well outside of the nominal range.
Old 05-26-2012, 04:54 PM   #4
baloneyskin daddy
bikaholic
Oddometer: 2,085
Maybe he only turned one way
baloneyskin daddy is offline   Reply With Quote
Old 05-26-2012, 07:05 PM   #5
ibafran
villagidiot
Oddometer: 1,287
It is not unsual for a rider to get 'lost' in his suspension set up after a series of adjustments. Tiny distractions and miss-rememberings are common. Thus settings become dissimilar after a time if care is not taken. Usually most of this can be controlled by keeping a suspension log. Keeping the log usually slows the adjustment wrenches down enough so that the job has a much better chance of being done correctly. The rule of thumb is that if you haven't got enough time to keep the log then you haven't got enough time to do the work well,
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 05-26-2012, 09:34 PM   #6
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,576
Buy this http://www.amazon.com/Techs-Motorcyc...8089652&sr=8-1 well worth the money
kenny61 is offline   Reply With Quote
Old 05-27-2012, 07:06 PM   #7
blues
Oddometer: 963
To answer your question, I'd say he screwed up.
8 year old bike? Did you r&r the fork oil? Air gap to spec? Very carefully align the front end and set up the steering head bearing?
Even though it's suppose to be ok I'd check the sag anyway. The shop that sold it might have set it up for a 280lb rider.
Originally Posted by Tragic Image View Post
thanks.
blues is offline   Reply With Quote
Old 05-27-2012, 07:29 PM   #8
viverrid
not dead yet
Oddometer: 30,482
Not likely, or if there was, it is a mystery to you. Returning to stock settings for a new-to-you bike is a fine place to start. Don't sweat what the other guy did.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 05-28-2012, 02:01 PM   #9
Tragic Image OP
Oddometer: 242
After two days of riding on the "new" set up there are definite things that I like more.
But the bike feels less planted in corners, while doing much better through less certain terrain.
Is this a common trade off
Old 05-29-2012, 10:20 AM   #10
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,186
On stock suspensions, yes. To get a cushy ride over rough stuff, the damping needs to be dialed back but the crappy stock springs don't maintain good control while cornering. A bouncier ride more prone to bottoming is usually the result. A suspension that offers a cushy ride AND appropriate damping and spring control is expensive.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 05-29-2012, 06:09 PM   #11
MrLebowski
MrLebowski's Avatar
Oddometer: 158
Slide your forks up a half inch. And check/set your sag.
MrLebowski is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
