Old 05-21-2012, 05:08 PM   #2236
bikecat
bikecat's Avatar
Oddometer: 1,117
I'll send the pics to a friend of mine in the IT industry and see if he has any leads. Frankly I am not optimistic because the original lead is only 8-pin and the GS's is 30-pin, I can't see how the conversion can be done.
Will reply ya by PM, likely take up to a week or so.
Cheers
bikecat is offline   Reply With Quote
Old 05-21-2012, 05:37 PM   #2237
ludger
Oddometer: 29
akro pipes
Originally Posted by Megaman View Post
Here are some picks of the bike with HPN tank and Akrapovic system.
http://www.hpn.de/bilder/high_resolu..._megamoto1.jpg
obivously y.ou haven't ridden it yet.no colour on the pipes
ludger is offline   Reply With Quote
Old 05-21-2012, 10:04 PM   #2238
GSMarc
GSMarc's Avatar
Oddometer: 1,105
Originally Posted by bikecat View Post
Will reply ya by PM, likely take up to a week or so. Cheers
Thank you in advance,
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 05-24-2012, 04:08 PM   #2239
johnny moped
learner
johnny moped's Avatar
Oddometer: 155
selling my hp2
http://advrider.com/forums/showthrea...&highlight=hp2
johnny moped is offline   Reply With Quote
Old 05-27-2012, 05:00 PM   #2240
bikecat
bikecat's Avatar
Oddometer: 1,117
GS Marc,
As I suspected, the connectors are different and it is hard to replace with a adaptor because the number of pins are different. It looks like the LCD screen was changed by BMW for GS/MM or for different production years.
Sorry that I can't help ya. Looks like an actual MM cluster is your only option.
Cheers
Old 05-27-2012, 09:43 PM   #2241
GSMarc
GSMarc's Avatar
Oddometer: 1,105
Thank you Bikecat
The HP2E cluster and R1200GS have the same 30 pins connectors.
The MM has only a 8 pins
I'm still searching a LCD but it's quite difficult to find...
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 05-29-2012, 11:12 PM   #2242
diranne
Oddometer: 32
Carbon Belt Cover
Just installed a carbon belt cover - these used to be a nigh on A$1200 option at new in Australia and for some reason they are now down to $400 - and thats from the local BMW dealer!
Australia - BMW HP2 Megamoto
diranne is offline   Reply With Quote
Old 05-30-2012, 01:24 AM   #2243
bikecat
bikecat's Avatar
Oddometer: 1,117
My experience with CF being in that area is that it is prone to pitting and damage.
Cheers
Old 05-30-2012, 12:56 PM   #2244
hawideri
hawideri's Avatar
Oddometer: 47
b[/IMG]
Some serious eyecandy
I hope they will throw that in the discount corner here in the EU as well.
Regards, hawideri
hawideri screwed with this post 05-30-2012 at 01:08 PM
hawideri is offline   Reply With Quote
Old 06-04-2012, 04:33 AM   #2245
GSMarc
GSMarc's Avatar
Oddometer: 1,105
Originally Posted by GSMarc View Post
2007 MM speedo LCD
I'm searching a new LCD for my speedo.
Does anybody know where I can find it before buying a new tachy ?
LCD connector is under the green light.
I have opened another MM tachy to see the LCD.
Written on the LCD upper left side : 07 12 25 MA
only 8 connectors
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 06-04-2012, 08:29 AM   #2246
bikecat
bikecat's Avatar
Oddometer: 1,117
Anyone used or using a BoosterPlug or Wunderlich controller?
I am curious ... very curious .... I know the BMWs run lean, and want to improve on that.
Cheers
Old 06-04-2012, 11:20 AM   #2247
GSMarc
GSMarc's Avatar
Oddometer: 1,105
Hi Bikecat,
I went with RapidBike EVO 019L and K&N filter and Full Remus exhaust.
I'm VERY satisfied
http://jemelapetenflat.xooit.be/t322....htm?q=dyno%2A
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
Old 06-04-2012, 06:37 PM   #2248
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,238
Cheers
+1, especially in the blast radius of that front wheel. Lay on some 3M stone chip film, you'd protect it as well as be able to enjoy the carbony look.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is online now   Reply With Quote
Old 06-04-2012, 09:24 PM   #2249
Ron50
Ron50's Avatar
Oddometer: 179
Cheers
I'm very happy with the results from the Accelerator, especially at the price. Check out my post from 6 September last year. No noticeable increase in fuel consumption either.
Ron50 is offline   Reply With Quote
Old 06-05-2012, 06:48 AM   #2250
Macroenie
Macroenie's Avatar
Oddometer: 206
Cheers
See my post here
The wunderlich controller gives you more options over the rev-range. The other one just fools the injection by use of a temperature related resistance, making it think it is about 10 degrees celsius colder en thus it will richen the mixture.
If you take away the cat. or put a 'sport' exhaust on the MM you will have to take measures for it not running to lean.
Macroenie is offline   Reply With Quote
Times are GMT -7.   It's 01:48 PM.
