Old 05-26-2012, 12:43 AM   #46
walkingbear OP
walkingbear's Avatar
Oddometer: 3,432
exactly
Caleb really had the wrong shoes on .. for the inspection
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 05-26-2012, 08:10 AM   #47
walkingbear OP
Oddometer: 3,432
plans
To the inmate who emailed me about the plans. Please PM me with your email address. You email ended up in the spam and erased.
I can send you the PDF if that helps
Old 05-26-2012, 08:13 AM   #48
walkingbear OP
Oddometer: 3,432
Lighting for the Project
I am thinking of using LED spots on tracks to light the space.
There are high intensity sodium lights that could be had but they are
expensive to burn.
Suggestions please
Old 05-29-2012, 07:37 PM   #49
walkingbear OP
Oddometer: 3,432
Tues 5:30 AM
The first of the trucks rolled in. Pickup truck with the cement mixer towing behind.
First order of business was to dust the concrete floor with sand and stacking loads of cinder blocks inside the garage. Sand will catch any of the mortar that is dropped during the building of the walls.
The electricians showed up to place the boxes in place ( all the outlets will be 4 feet off the floor) We talked about the placement of the out door lights and we added another outlet in the middle of the garage door (motion detector )
The plumber showed up to back filled the ejector pump and run the sewer piping connect to the house. He also had to adjust the height of the water pipe leading to the garage .. he was a little short
The task today was to build the corners and have them inspected Wed afternoon after they are filled with slurry.
Had to go to hardware store to buy a box of snake shots. A little visitor to the site and it got under the pallets before I could hit it with a shovel.
I have a dog and 13 month old. Hate rattle snakes.......
walkingbear screwed with this post 06-03-2012 at 04:36 PM
Old 05-30-2012, 09:23 PM   #50
walkingbear OP
Oddometer: 3,432
Wed May 30
Lots of cinder blocks going up. Finished installing the ejector pump. Moving the existing sewer clean out on a sink other wise it would be buried in the back fill.
Met with framing crew today. We are adding an additional door to the upstairs and decided to build a 12 x15 deck of the second floor. Clear view to
Phoenix and South Mountain. Will be connecting it to a treehouse being built later.
Under the deck will be a play house for kiddies. (sand box and tire swing)
Green cover of the pump, a delivery of rebar and elec. boxes taped and ready to be installed in the wall
Gordon the owner of the compamy is in his 60's and still sling mud. (guy in the straw hat)
They finished at 3:30PM and they had almost all the walls done for inspection at Noon Thurs.
walkingbear screwed with this post 06-03-2012 at 04:37 PM
Old 05-31-2012, 08:01 AM   #51
dirtdiver
Oddometer: 2,035
That is some good progress!
DD
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 05-31-2012, 08:15 AM   #52
walkingbear OP
Oddometer: 3,432
New occupant for the garage
Sold my firebird .. so I replaced it with this sweet ride
X5 4.8 Alpina built motor......
Old 05-31-2012, 08:20 AM   #53
walkingbear OP
Oddometer: 3,432
Early arrival
What is happening today.
Block delivery Noon
Grout / slurry 11AM
Special grout inspector 11 AM
Pay to
Cinder block installers second draw
Plumber final for main water line
General contractor 3rd draw
Electricans 2nd draw
Pictures to follow this afternoon
Old 05-31-2012, 08:35 AM   #54
John E
Oddometer: 802
Just for fun...
Block delivery Noon
Grout / slurry 11AM
Pay to
Could you total up just how many inspections you'll have to go thru by the time it's all said and done?
Do you have to pay for each of them?
" ...that was the river, this is the sea..."
This is the Sea
The Waterboys/Mike Scott
John E is offline   Reply With Quote
Old 05-31-2012, 08:51 AM   #55
Minnesota
Conform or be cast out
Minnesota's Avatar
Oddometer: 3,953
I was thinking the same thing. There sure are a lot of inspections going on with this little project.
To learn who rules over you, simply find out who you are not allowed to criticize. -Voltaire
Minnesota is offline   Reply With Quote
Old 05-31-2012, 10:11 AM   #56
walkingbear OP
Oddometer: 3,432
Inspections
I asked the same thing...
General contractor said 12....... The city no longer will do wall inspection
We have to hired a special inspector since we are using Omni block. ( we pay out of pocket)
$$ just keeps going out. The extra inspection was for the ejector pump otherwise would be only 10 inspections (part of the permit fees)
Old 05-31-2012, 10:17 AM   #57
Minnesota
Minnesota's Avatar
Oddometer: 3,953
I just built a house a year ago and I remember the money flowing out like water. You soon become numb to it.
I think our house was inspected maybe two or three times. And I thought I was over-regulated.
Old 05-31-2012, 11:39 AM   #58
walkingbear OP
Oddometer: 3,432
Electrical F..K up
Some yahoo.. in the past missed wired the main box.
Electricians opened the box this morning and this is what they found.
Called the home warranty insurance company and said this wasn't cover because everything is still working. My electricians said .. if it is black inside it is not safe. HATE INSURANCE COMPANIES
It's been a long day..
Update on the progress, passed inspection on the second level build before the next inspection.
Lumber will be arriving next Wed. Framers are hoping to have rafters up within a week.
Arrival of the grout truck (3 yards ordered but could only use 2.5 , wasted 1/2 yd)
Pictures taken from finished 6 foot wall...
Window facing the east side in lower level of the garage. Lots of natural light without the heat
walkingbear screwed with this post 06-03-2012 at 04:29 PM
Old 05-31-2012, 12:52 PM   #59
Minnesota
Minnesota's Avatar
Oddometer: 3,953
It sounds like you need to strong-arm your insurance company. Don't take no for an answer. It's easy for them to tell you no and then you go away. If you keep hounding them they may change their mind and cover it.
Old 05-31-2012, 01:19 PM   #60
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,861
My dad took the family to pinnacle peak restaurant (steakhouse) and I remember the ties they used to cut off if you came in with one. I'm assuming it must be up there somewhere and still open. good times!
Just paid... now I can upload all I want.
North looking toward Pinnacle Peak and my garage door
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Times are GMT -7.   It's 11:41 AM.
